Page 49 of 395 FirstFirst ... 394546474849505152535999149 ... LastLast
Results 961 to 980 of 14348
    Pwede naman pdr yan kaso kailangan parin magrepaint
    Quote Originally Posted by halimaw View Post
    Tama ser pag pdr muna manipis na lang masilya...
    yun kasing mga nakikita kong pdr di na nila nirere-paint, yun nga lang walang gasgas sa paint.
    if ipa pdr ko naman and at the same time kelangan pa pala masilyahan plus paint, mas better option siguro wag na i-pdr and direcho na lang sa latero (pukpuk)+pintor.
    anyway, thanks for all your suggestions!
    Quote Originally Posted by blue View Post
    Mura lang naman pdr. Less than 500 siguro yan. Ang maganda sa pdr, very minimal na ang masilya if ever kailangan. And at least back to original yung form nung fender mo.
    thanks, 'will go for that!
    Oct 2011
    Mga sir question lang..
    Ilan po ba ang engine support ng local fieldmaster? and ilan din po ang transmission/transfer case support niya?
    and san banda ang locations nila? ill be having it checked tomorrow, para mabilis makita and wala ako ma-miss.
    Thanks
    Quote Originally Posted by 7009 View Post
    Thanks
    if im not mistaken... engine support 2pcs, transmission support 1pc, transfer case support 1pc... medyo mahirap i-explain location, pero visible naman yan... masmaganda i-lifter mo paj para masmadali
    Oct 2011
    Thank you.. at least i know how many
    Nov 2004
    Mahirap lang kasi ser sa banawe boys swertihan kung magaling talaga gagawa, atleast kahit may patong po yung shop na pinagdalhan nyo kilala nun kung sinong banawe boy ang marunong talaga kasi sila babalikan nyo kung palpak. Try nyo ser kay jemson sa banawe dami siya good feedback referred by doc otep.
    Nov 2004
    Ok na ser tagas sa filler plug ng rear diff ko check na din mt, transfer case, front diff pati general checkup ok naman daw lahat, sa wakas na meet ko na din si ser joseph atotubo. nagpakabit na din ako ralliart grill badge sa kanya.
    Nov 2004
    San ba best buy magpa undercoat? Yung reasonably priced na pulido gawa...
    Nelany, san ka nakahanap nung fitting and hose? 18mm nga yung fitting?
    Mar 2012
    Mga sir Meron na ba dito na naka pag retrofit ng foglamps sa fm natin
    Kasama sa set up ng Devilsown yan sa Speedlab.
    Jul 2005
    salamat sa mga replies. Sayang napagawa ko na sa Banawe boy. Anyway, lagi naman ako pumupunta sa building na tambayan nya kaya mababalikan ko kung sakali.
    Sir bakit kelangan ng stainless tube? di ba kakayanin ng OEM hose?
    Yung nozzzle spray doon nakalagay, kailangan meron thread para full fit yung nozzle spray. Yung OEM ay rubber lang.
    Yung kay joseph atutubo ganyan din... AFAIK, yung OEM connecting hoses can expand when they get hot, which can lead to decreased cooling abilities and the connections becoming loose. steel pipes are also sturdier than rubber hosing and are less likely to wear down and leak... for better performance to sum it up
    Mar 2012
    Quote Originally Posted by junerski View Post
    Ok yan Pagawa me na Lang ng Ganyan Kay joseph para Ganda lalo takbo ng fm ko
    Nilagay yung stainless tube dahil kailangan i thread doon yung nozzle spray ng devilsown sa stainless tube kaya yan ang purpose kaya napalitan siya.
    Ah kaya pala, kala ko dati pang japorms lang... parang gusto ko nito... hehehe
    Mar 2012
    Mga bosing sino na naka retrofit na foglamps dito sa fm? Mas malakas ba Siya sa stock foglamps? Tnx
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
