Page 40 of 718 FirstFirst ... 303637383940414243445090140 ... LastLast
Results 781 to 800 of 14348
    #781
    pajd, yung nabili ko na 15mm di pumasok, mas malaki pa kailangan na hose. di ko sinukat yung hose na kasama sa oil catch but nakalagay sa box 15mm. di pa din ako nakakahanap ng rubber hose, natutuwa kasi ako makita yung oil droplets sa chemical hose, hindi na pala kulay blue yung chemical hose na nilagay ko,medyo kulay grey napero transparent parin, kaya di na gaano pansinin,
    ganon ba sir, mukhang maganda siguro mga 1/2 inch.
    d1 spec oil catch tank
    pajero fieldmaster
    http://s4sautohub.multiply.com/photo...photo%2F38%2F8
    montero
    http://s4sautohub.multiply.com/photo...hoto%2F38%2F13
    pics from s4sauthub
    #782
    Quote Originally Posted by Pajd View Post
    pajero fieldmaster
    montero
    pics from s4sauthub
    hmm.. yung sa fieldmaster anong hose kaya gamit niya.. ang mukhang may converter/adapter pa siya na gamit ah.
    #783
    silicon hose samco sport. HTH
    #784
    sir, would you happen to know the size?
    kasi based sa nakikita ko sa picture, yung part na nagmeet yung blue and black na hose. wala bang adapter yun? check ko engine ko mamaya hehe.
    mag DIY lang kasi ako eh. kaya gusto ko sana malaman yung size.
    ito galing sa HCP. (not my picture)
    Jun 2004
    #785
    San ka nag pagawa? mura naman ng pa transtech mo... I'll have mine done this january
    dito lang sa amin, TUAZON sa marikina.
    650 for the transtech machine/labor
    tapos mga 8 liters of MOBIL 220 * 250 each ata
    so far parang once a year dapat ang transtech ko, after a year masama na shifting and medyo maitim na ung atf. rock and roll uli tranny ko, swabe hehe
    #786
    Quote Originally Posted by archijardy View Post
    ito ba yung Alpha?
    #787
    ito ba yung Alpha?
    alpha nga yang may atf machine sa tuazon/gil fernando ave...
    meron din sila bleeding machine for brake fluid.
    Jun 2004
    #788
    Quote Originally Posted by junerski View Post
    yup! alpha, dito din ako nagpapapalit ng brake fluid ko as junerski said.
    libre pa kape
    Mar 2003
    #789
    CB, wag mo gayahin yung fuel filter as oil catch, sakal yan for sure, ang laki ng hose na kailangan sa 4m40. pag nasakal yan mag kaka presure build up sa top cover, dapat yan malakas ang vacume para may circulation ng vapor. oil leaks yan sa mga gaskets, yung silicon hose na kasama ng oil catch ko sobrang nipis at natutupi.
    ang itsura ngayon ng chemical hose hindi na blue grayish na siya dahil sa langis, check mo 2nd pic compared sa first pic, masgrey na siya, kaya di na gaano pansinin, then nilagyan ko narin ng steel wool yung loob ng canister para mag condense yung langis, meron parin kasi lumulusot na oil galing oil catch, namiminimize lang but hindi totally mawawala
    #790
    Quote Originally Posted by gioravelo15 View Post
    ganun din sakin dati nabubulunan tapos mamamatay pero after magawa nawala na yung ganung pangyayari mas mabilis naring umangat temp gauge ko. ano kaya difference kapag sa throttle papainitin kesa sa pedal?
    kahapon nagpa-calibrate na din ako... 3 days ng namamatayn FM ko sa umaga... kahapon nag-start pero namatay ulit... kaya dinala ko na sa calibration center...
    *gioravelo - pinalitan din ba yung nozzle tips ng FM mo nung magpa-calibrate ka???
    #791
    libre pa kape
    sir, meron din ba sila for Power Steering fluid? mejo mabigat na kasi power steering ko eh.
    #792
    promdi, ilang mm yan? para kung bibili ako ng catch can, yung tama na mabili ko.
    #793
    kulang pa ba yung 1/2 hose sir?
    Sep 2010
    #794
    Sir magkanu po ba ang catch can? Meron ba neto sa banawe?
    #795
    Quote Originally Posted by GoNeIn60SeC View Post
    sir try mo dito.
    pero tumitingin din ako http://www.dollarparts.tumblr.com/ e. mukhang mas mura dito.
    Jun 2004
    #796
    un ang wala, mano mano pag P/S fluid sila, kahit DIY pwede. tanggalin mo lang hose sa pwet ng baso then labas na lahat fluid. ikot ka konti then do it again.
    #797
    Yung ATF filter hindi na ba nilinis? or pinalitan? Thanks
    #798
    Ask ko lang, me specified ba or recommended na tyoe ng power steering fluid ang pajero natin? I use texamatic 8888 ok lang ba yun?
    #799
    sir try mo dito.
    crazy boy sir ....wow, ang ganda ng model...este ng oil catch tank....magkano ba ganito? significant ba increase ng horsepower?
    sirs, tanong ko lang, 10 years old na fm ko, A/T, lately napapansin ko pag bagong start, say in the morning or matagal nakapark, parang ang tagal niya magshift ng gear pag bagong andar. tapos after about a minute, shift na siya normally. nangyayari ba ito sa inyo? tks for any advise
    #800
    kaya pala swabe sya sa mobil 220.
    nasayang pera ko sa caltex kainis ang pangit ng shifting
    archijardy, nung nagpalit ka sa mobil 220 naayos ba shifting mo?
Mitsubishi Pajero Fieldmaster (Gen 2.5) [continued]
