Di kaya yung speedometer mo me problema? If me GPS ka compare mo muna sa GPS speed reading ang Speedometer mo. Di naman accurate kasi yan. Even mine is Under by 5-7 kmh * speeds around 100 kph based on Speedview app On Android phone. Or maybe meron nakialam ng Tachometer needle mo, dali lang tangal at ibalik yan even yung speedometer Needle... Hehehe![]()
Yup yung mga contacts ang nilalagyan, not so sure kung lithium yun, need to read yung Tech Sheet niya or yung MSDS niya. Yung mg relay yan ang nilalagay para fi mag corrode yung mga contacts.
Gamitin muna yung naka crimp na hose sa PS mo para sure. Di mo alam kung lumuwag yung clamp mo kasi nasa ilalim yan ng sasakyan mo yan.
No dashboard indicators light up man. The battery is two months old. It's a motolite gold. I also upgraded the alternator when I had the battery changed. I tried starting again earlier and it won't start again. Where can I get a starter motor? Is it expensive? And can anyone recommend a mechanic who can fix it at my house? I'm from the South. I'm not sure if I'd be able to start it again.
Thank you.
Hmmmm, last question, have you checked already if your battery was drained or has no charge? If ever it is, then we'll go back to the alternator problem. Try to switch on your car first but don't start it. Then try to honk your horn. If it sounded weird or it sounds like it lacks power, then your battery is drained, meaning your alternator is not charging. But if it sounded ok, then it's the starter most probably.
I'm sorry if I cannot help you with the mechanic since I'm not familiar of your area. Maybe others can help you with your problem.
Mga masters, have a slight problem with my FM matic. Di sya makatakbo above 60kph. Brought it to casa last dec due to mabagal magshft, they said baka ATF change lang. Before thAt i already did my change oil pero napalitan lang ng pekeng air filter (150petots). Now with d changes ATF and engine oil, possible kaya na due to d air filter kya hirap tumakbo? Pls advise, thanks.
Try to isolate the problem by borrowing a usable battery and have these jump start your rig. If hindi pa din nag "crank" then you have an electrical prob. Basic possible checking "ulit" are Alternator, Starter, Fuses, Grounding Cables, Electrical Wirings for loose or cut lines. Medyo madugo ito but kelangan mahanap ang culprit (and it not only happens to our beloved Pajs but to all cars as well). If bihira lang gamitin yun rig (like mine) then possible na binisita na din ito ng daga.
HTH!
BTW, i was able to find projector fog lights. check ko lang kung kasya ba siya sa stock FM butas hehe
