sir zix.. hehe one man can do your tire change? or pwede one man pero dapat si arnold swartz.. hehe
im assuming it will also have effect on acceleration braking and fuel consumption? how bad po?
sir blue... i was googling for the writeup kayalang hehe di ko napo mahanap... hehe.. i think nabasa ko yun sa pajero australia websyts na may study na ganun.. hehe
dito sa forum madami nga din po ganun.. loyal sa mitsu... or baka mitsu fanboys tayo? hahaha jk
Pwede sya I adjust to LHD spec. pag tinanggal mo yung hood cover me butas sya na abang pang LHD mounting. Just like the steering wheel. Pero kelangan mong butasin and plug the old hole sa hood garnish. I converted mine last year, di ko matiis kasi... hehehe
Nice Gen. 4 sir AC!
Sir testa ask ko Lang nung n adjust ko n ung headlight unit ko d p din Maganda ang liwanag ng headlight ko, nag palit n me ng bulb Philips extreme power h4
sir testa pinalinis ko n po ung headlight ko, nag palit n me n bulb n philips exreme power h4 yung plus 80% ung lakas s stock
you mean po sir mahina? ano po kulay ng luma niyo? yung parang white na yellowish? and yung ngayon po super white po ba?
sir paj.. ah ic.. akala ko kasi baka from yellowish to superwhite.. akala ko baka yun ang cause.. hehe
ako din sir ry..
i love the pajero..
sadly a mitsu fanboy.. hehe jk
Hmmmm, pwede mo ba kunan ng picture yun bato ng ilaw mo against a plain wall o kahit sa gate lang ng bahay ninyo? Di namin kasi mapicture-out kung paanong hindi solid yun bato ng liwanag.
Reminder pala sir, bawal po sa tsikot ang text speaking. Please type the words in full po. Baka ma-ban kayo ng mods dito.
Sir if yung bulb ninyo is just 55/60W, even if it says 80% more output eh mas malakas ang buga, huwag kayo maniwala sa mga nakasulat diyan. Basic, if you want a higher output, you need a higher wattage bulbs, say 110/180w, but syempre ang draw back, you need to upgrade the wirings, plus prone sa darkening yung lens if plastic. Or you can just install an Hid, but then again our headlamp are not designed for that, meaning ang cut-off is not good, bad for our kasalubong. Best way is what sir testa's upgrade, projector type, medyo madugo nga lang. Here is what i think the most economical, just get a halogen bulb, 65/80W , no need fir wiring upgrade, not that hot to make the lens go dark easily plus try to stay away from laminated bulbs, ang laki ng hinihina sa output nun sir.
sir.. ano po ang laminated bulb? how do i know if its a laminated bulb? thanks
Same dilemma here sir paj... before my bulbs ay yung mga generic lang, then kinuha ko ng stock bulbs ng tucson which is osram din though hindi osram NB, pero sobrang layo ng diff as compared pag nakalagay sa tucson.. Ang ginawa ko dito is pinalagyan ko ng relay yung high/low ng headlights, pinasabay ko lang dahil nagpalit din ako fusebox that time (as suggested by electrician sa rey's).. helped a lot.. pero hindi pa din kasing lakas nung "bato" nung sa tucson..
palagay ko ok ung mag lagay ng mas mataas ng konti na wattage, pero still, plgay ko ndi pa din ganun ka satisfying.. ipon nlng tyo for projectors! sabay sabay tyo pagawa para may discount! :D
