Page 9 of 330 FirstFirst ... 56789101112131959109 ... LastLast
Results 161 to 180 of 6591
    #161
    Promdiboy, PK, OTEP
    Thanks for your inputs. Very well noted.
    Nakaktakot pala yun paginstall as puputulin yun grill... TY
    #162
    Yung sa Jaffas di nakakatakot coz the dude who does the cutting knows what he's doing. ;)
    #163
    PK,
    I went to jaffas kanina to have the foglamps installed. 4K na raw sya and hindi raw siya essuse. I told them about your pajero and ayaw talaga sa 3.8. unang hirit nga 5.5 daw as orig pajero daw???
    At first masama kabit kasi they installed the foglamps too near. Nakaluwa 1-1/2" medyo nalakihan yun butas. I asked them to redo the brackets so that lapat sya like the orig. okay na rin. Switch is pushbutton parang oem na rin with amber light.
    By the way, ginaya ko rin yun location ng rear a/c switch mo, it is now beside the suspension switch (tama ba?)
    Thanks for your advice.
    #164
    Talagang mas luwa ang non-oem foglamps.
    Advantage nito is it disperses light better.
    #165
    lancelot, san naka mount yung switch? sa gilid ng instrument cluster? If yes, oks na yan.
    Nakaluwa talaga. Yung oem nakapasok sa loob yung foglamps. Oks lang yan, very few would notice ;)
    Ikaw ba naglipat nung Rear A/C switch? ang saya no? Just make sure you route the wirings well kasi it may interfere with the proper functioning of the accursed cupholders.
    #166
    PK,
    Yun A/C switch yun taga jaffas ang naglipat. He extended the length of all wires then nilusot sa tabi ng suspension switch. OKs naman yun gawa. TY for this
    Yun foglamps switch sa tabi ng antenna switch. Pero looks oem naman kasi almost same sa antenna switch pero cheap plastic. Pwede na rin for the price...
    Do you mean oem switch is located dun sa defogger?
    When my wife saw nakaluwa, sabi nya nag pangit daw. So balik uli sa jaffas para ipasok yun lens para mukhang orig na rin.
    Problem ko lang dito sa foglamps ang hirap iadjust as brackets are in place. Medyo mataas yun right sa left ng konti pero pwede na rin.
    Mar 2003
    #167
    lancelot diba tama na mas mataas sa right ng konti . pinsadya ko na gawing mas mataas yung right.
    I think sabi ni sir otep same owners din procars and jafas. diyan din nila tinawag yung taga kabit. longhair siya,
    #168
    promdiboy,
    youre right, same owners daw procars and jafas.
    Long hair yun nagtabas ng bumper, short hair and nadinstall.
    Bakit dapat mattas yun right? Just curious
    #169
    lancelot, baka pumangit pag totally naka-recess yung foglamps, kasi kita yung lagari marks. YUng OEM switch is positioned at the opposite side of the defogger switch.
    #170
    PK, mine is tabi ng antenna. Push button with amber light. Pwede na rin pagtyaagan.
    Yun foglamps ok naman yun appearance. Inusli ko mga 1/4" so halos lapat lang sa butas. OK naman ang appearance as kinompare ko sya orig. Pwede na rin
    #171
    Yung electrician ng Jaffas ay si Jameson. Siya ata yung may pagkalong-hair.
    Yun yung nagpapaandar ng kotse ko ng walang susi para lang gulatin ako. hehehehe.
    #172
    lancelot, yup pang lancer itlog nga yun, same as mine when after intial install.
    Mar 2003
    #173
    mga sirs
    tama po ba yun na dapat mas mataas ng konti sa right ang ilaw?? nabasa ko yata sa isang article.
    sir pk may remedyo pala akong ginawa sa transmission support. nilagyan ko sa gitna ng additional rubber para medyo iangat niya yung transmission andd transfer case, mga 2 weeks na siya. nabawasan ng konti yung vibration. nasuya na kasi ako kakapalit. pwede ko po ba mahingi ang iyong expert opinion.
    Mar 2003
    #174
    heres a pic of my lancer foglites. compare compare nalang any diffference?
    sir pk inenlarge ko yung avatar mo para masilip yung fogglites. bakit may parang black outline yung llens? pinalakihan mo ba yung butas?
    #175
    Ang ganda ng pagka-install sa fogs mo PROMDIBOY!!! Yung sakin meron black outline kasi naka-usli yung foglamp assembly, unlike yung sayo na parang stock ang dating!!! very nice!!!
    Regarding yung transfercase support, oks lang yung as long as it does the job. ;)
    Feb 2004
    #176
    ang ganda ng maga pajero ninyo dalawa. gamitin ko muna itong gen 2 ko for a year and a half to two years and then change naman ako to the gen 2.5.
    so kayo dyan na papalit from the gen 2.5 to the gen 3, keep me in mind a year and a half from now.
    andy
    #177
    Promdiboy,
    Sabi ko na nga nalakihan yun butas ng akin.
    Una inusli din nya yun foglamps then pinapasok ko uli para magmukhang orig.
    Pero not as good as yours. Galing ng installer na yan. Can't do anything now kasi butas na. Did you guide him through the installation process?
    #178
    Promdiboy,
    Orig ba yun overrider mo? Jaffas is selling it to me at 5.8K? OK ba yun?
    Mar 2003
    #179
    lancelot. ARAY! masakit yung info mo. 9,500 kuha ko sa casa ng overider nakasale pa yun from 11th. very good price nayan.
    sir pk, lancelot lucky truck thanks sa bola hehe, si jameson "longhair" lang gumawa. sa ddulo lang ako nagtingin tingin..
    #180
    Ok yang si jameson. Siya naglagay ng footwell lamps sa Pajero ko. Parang BMW na ang dating. Hehehehe. Pagbukas ng pinto may ilaw ang sahig.
