Page 109 of 660 FirstFirst ... 95999105106107108109110111112113119159209 ... LastLast
Results 1,081 to 1,090 of 6591
    #1081
    Hanapin mo lang sa Mitsubisishi section ng 4x4wire.com . Andun yun. Torsion bars can sag over time. Pero wala pa kong nakitang failure. You just crank the adjuster until you reach the desired height. Too much cranking will stiffen the ride and get your alignment out of spec.
    I cut down the upper bumpstops to have the size to regain some down travel after I cranked my bars.
    May 2005
    #1082
    Otep,
    Patanung lang tungkol sa Montero ko, when igot it lifted na sya ng silipin ko yong susp. arm sa front sagad yong rubber stoper and stiff na yong ride nya sa front. Gusto ko sana mas malambot na ride sa rear walang problem but sa front medyo matigas nagpalit narin ako ng shocks sa front KYB lang na fluid type medyo matigas parin. Pag ni lower ko naman parang pangit ang tindig nya subsub mataas ang likod. May iba pa bang way to have i better ride sa front? Thnks
    Jan 2003
    #1083
    salamat boss otep! another query! may alam ba kayo na shop sa blumentritt na nagbebenta ng rims saka gulong na ok? nagtanong kasi ako dun and di ako makapaniwala na kukunin lang yun set ng rims and tires ko for 10 k 5 pcs kahit na bago daw yun mga gulong ko. Kaya tuloy naudlot yun plano ko magpalit ng size 16 rims... huhuhu!!! baka 15 rims na lang din saka sound setup na lang
    #1084
    larshell,
    Bawasan mo yung upper rubber stopper. Meron talagang low profile na nabibili niyan kaso mahal ata dahil polyurethane. Ganun ang gamit ni woodfire. Kaya nilagare na lang namin sa bahay ni GlennSter. Ok naman.
    BS,
    Mababa talaga ang trade-in value ng wheels and tires. Better do the selling yourself if you want fair value.
    May 2005
    #1085
    Otep, Yong shock na pinalit ko single action pag pa-diin walang laban pero pag pa-hatak may laban di-kaya kung putulin ko yong rubber masira yong arm?
    Feb 2006
    #1086
    I have read all your posts here and i learned a lot of things. By the way I just bought my FM last december 2005.medyo mataas pero satisfied naman ako at sariwa.problema ko lang now is yung vibration sa pedal ng brake when I tried at 160Km/hr sa NLEX.sabi ng mekanoko ko palitan daw rotor disc.di ba advisable reface like what I did in my corolla?san makabili mura na magandang klase. thanks in advance.
    Feb 2006
    #1087
    By the way mga guros I am planning to change my rims,katataos ko lang sa sound set up ko gumastos.how much ba ang aabutin sa 20" with series 50 na gulong?I saw here in Jakarta and they gave me 18,000,000.00 rupia more or less 96,000 Php set of 4 rim and tire na. yung rim may apat na designs but price are all the same. the rims are Made in Taiwan.Mura na ba to?I need your inputs kasi nilililgawan ko pa si kumander baka pumayag bibili na ako sa paguwi ko dyan sa May. thanks
    Mar 2003
    #1088
    Quote Originally Posted by pajerokid
    promdiboy, ok pa ba glow plug relay? do you hear the 'click' that kc is talking about?
    Pk yup meron pa nung click sound. nagtest light din kung may power yung metal na nagcoconect sa apat na plugs. ok pa. tinest din niya each plug by removing the connecting rod then connected a wire sa positive terminal ng batt, tapos kiniskis niya yung end ng each glow plug meron spark pag dinidikit. meaning daw nun ok pa plugs. tama ba itong way ng testing?
    #1089
    Quote Originally Posted by larshell
    Buhay pa ba ang single action shock in this day and age? hehehe. All shocks have damping in both the compression and extension phase. Mas mahina lang sa compression because there is a torsion bar (or spring depending on suspension type) to further control motion.
    #1090
    vikoy: reface muna before replace rotor. as for the rims, that price seems reasonable enough :D
