spec3, diffs 75w-90 yata kung tama alala ko, gl-5 sa diffs the gl4 sa transfer case. forgot ilang liters,
Ac, daming leds ah,
map lights, sikwat lang sa gilid, 30mm na festoon bulb
tail lights, may screw sa sides, kalas buong tail light.
park lights, may isang screw sa taas, then may alambre na hook sa loob ng engine bay, nasa fender. peanut bulb
sir rols sa china eh.. canton fair... nagdisplay mga supplier..
8 sets nga hid binili ko eh.. hehe pero 4 lang dun saakin... yung iba pabili.. buti nalang di ako nagoverweight.. hehe
actually di ko alam size ng led sa sasakyan natin.. hindi naman mahal(and alam ko mabebenta naman pag mali nabili ko) kaya dampot ako ng dampot.. hehe..
sana magkasya... pero puros high end nmt and hi power pinili ko.. hehe...
pk,
sayang,bad trip talaga d komannabili yung a pillar mo. was looking 4ward to it pa naman but congratsa sanew paj 2.5 mo. atleast same kulay na tayo.
Glenn, i got them from Jaffa's this morning. Kicker na kinuha ko para match dun sa subs ko. Present were Pres. Ungas, VP Otep and Treasurer afrasay
sir Promdiboy, oks na oks po yung foglights! For the price of P3,800 maliwanag naman and may harness and OEM looking switch. kaya lang hindi swak yung switch sa dash (beside the Pajero's antenna switch), but still fairly stock looking.
kc, kuha ka na ng bnew. Nasa P4500 lang naman for two assist grips and two pillar garnishes.
Dont worry guys, hahanapan natin ng remedyo yung leather seats ;) Check ko yung TCase support ko mamayang gabi. medyo maalog nga yung auto tranny.
Actually pare mas maganda yung JBL, kaya lang ang liit masyado nung tweeter niya. wala pang tatak. Pero hanep itsura nung midbass. i'd go for quart kaya lang mahal. Im not a hardcore audiophile naman e. Basta moderately nice, its perfect for me.
By the way, i just came from under the Paj. As expected, the TCase support is kaputz. I heard an unnerving noise while backing up earlier..... turns out the Jaffas boys forgot to tighten one of the screws on my skidplate (whew.)
sir pk
nung pumunta ako mga 6 months ago 3th lang bakit naging 3,800 na? kuha narin pala ako pag makaluwas. ddiba dapat nasa tabi ng speedometer yung switch ng fog lightts? buti nalang sir naka gen 2.5 kana para maturuan mo mga naka gen 2.5 sa tsikot.
lancelot
800 yung transfer case support sa eldorado. labor 100 pesos sa suking mekaniko mga 15 minutes ok na.. BTW iano yr model ng ride mo?
sir Promdiboy, sa ibang shop ako kumuha, hindi sa Procars. Sarado kasi. Yung foglamps, mukhang pang Lancer Pizza, ginawan lang nila ng paraan para magkasya sa bumper enders natin. Pero maganda naman tlaga kinalabasan and maganda yung buga ng ilaw. Stock 55W pa yun
actually punta uli ako mamaya sa Banawe. Hanap ng transfercase support and pa-install ng sound system.
My ride is 99 4x4, mura lang pala itong transfer case support. Could this be the annoying sound i was referring to pad ni rerev mo parang vibrating sound sa likod ng a/c? Nakakainis yun tunog?
Plano ko rin nga magpakabit ng fog lights for my bumper and overrider. Same with originals ba yun looks ng fog lamps na 3th? Where is it located again procars? Paano nila binutasan yun bumper di ba may grill yun?
As you could see, nakalabas yung projector assembly nung taiwan lamps as compared to the OEM, na nakapasok sa loob ng corner protector. Also, there is no way to adjust the lamps unless you remove the bumper protectors.
Pero yun nga P3800 siya, sa Procars P4000. Hinala ko talaga is that this kit is for the Lancer. Yung switch nga hindi doon sa malapit sa gauge cluster nakakabit. Pero sulit coz maganda talaga lighting.... hindi lang puro porma.
Eto naman, pinaghirapan ko nung Dec31.... Di ba nakakainis yung placement nung rear A/C switch? Hindi mo makita while driving dahil nasa opposite side nung super laking center console?
Well, what i did was extend the wires to the jack switch and relocate the said rear a/c switch beside the suspension adjustment switch. cool na tignan madali pang abutin DIY lang pero you need a lot of IQ to do it, kasi medyo masikip. What i did was use a hard wire to guide the individual wires to the switch. matagal isipin yung procedure, but once i got the hang of it, mga 30 minutes natapos na ako. Note the big scratch on the side of the console. Dumulas yung screwdriver ko while i was trying to remove the switch blank.
Pero again well worth it.
Oks talaga Pajero in terms of maintenance. Kanina naputulan ako ng Stud Bolt sa gulong. P75 yung bolt, P200 labor to replace. hehehe. Samantalang sa Honda ko dati, kelangan pa press-out, press in.
Yup. I had it installed in Jaffas in Banawe, kasama ko sila Otep, Ungas and afrasay kaya hanep sa audience impact hehe.
Pero kung papakabit ka, check mo muna yung sa procars (as mentioned by ser PROMDIBOY), kasi they might have the OEM looking switch (mounted above the alarm LED). And do try to haggle kasi P3000 lang yan before.
Kasama na yung wiring harness, relay and installatiion. Mga 2 hrs lang naman kinabit.
Isa na lang papakabit ko and then tapos na ako.... bumper lights. Kaya lang im having trouble picking which to put it.
by the way, i had my second fulltank fillup yesterday. 7.3km/L aint bad. Aint bad at all. considering A/T ito and 2850cc engine. My old Pajero averaged mga 8.5km/L.
