mga boss meron ba kayo alam na heater for fieldmaster surplus lang sana. hirap kasi magstart pajero namin.
thanks mga boss!![]()
I remember na 2.5K yung pa install ng boost gauge at kasama ng Hallman manual boost controller. Hindi DIY yung installation. Inabot din sila ng more than half day pa pag install. Bought mine sa abroad.
Hindi magalaw yung needle ng gauge ko, steady lang siya. Gagalaw lang pag mag boboost then return back sa zero pag natapaos na yung boost.
http://www.alibaba.com/product-free/...ll#breadcrumbs
hey guys may nakita ako fake transformers action figure ng pajero natin.. hehe wala lang...
I have resorted to that idea before, but nalibot ko na halos buong surplus banawe & sauyo, wala, buy na lang replacement, it is your call if you want cheap brand(P165)or the expensive brand (+P1400), kaya lang expensive brand will not guarantee how long it will be working kung ang problema is in your ECU relay.
RTs
Bumili si dad ng Bosch Snail Horn. I still like the OEM horn. Papalitan ko kaya into Hella Supertones?![]()
Napalitan ko stock ko with Hella Twin Tone (the red-boobs-looking-horns) happy with it naman the pitch sounds higher than the Bosch horns na pinagpilian ko hehe. parang gusto ko tuloy pagpalit sa fiam ko sa corolla ko hehehe!
Update lang sa A/T tranny "tug" sound, now i'm trying to put it in Neutral, then set the hand brake, the set it to Park. I'll try it lang parang hindi nape-puersa yung transmission that way, just my 50 centavos hehehe. Have a nice day guys.
The P1400 is in Banawe when I did the canvassing sometime ago, likewise ,ako nagpalit ng glow plugs about 4 times in less than a month from the cheap brand to expensive one, still same result keep on busting, then one day I said enough is enough, pumunta ako sa auto elect. & pina by pass ko ang relay and now almost two months w/ the cheap brand still intact. Relay in ECU can be check by good electrician(auto),mind you my relay is ok when checked but keep on busting, kaya pumayag na lang ako sa elect. suggestion to by pass the relay.
RTS
Paj4x4
Thanks! pa-check ko na lang pag paubos na laman ng tank ko.
I'm still looking for a power seat switch for my Pajero. May mabibilhan pa kaya nito dito? Meron akong nakita sa ebay sa states para sa diamante ganito itsura.
uubra kaya ito kung convert na lang? Medyo mahal din kasi.
hi guys, re bypass glow plugs, eto yong ginawa ko since I noticed that my glow plugs from cold start, (using a tester) received current for more than 2 minutes, which maybe the reason why it got busted early (in less than a monthI already replaced the heater sending unit and relay but of no avail.
Reading from another forum, I eliminated the ECU from the pre-heat system, and then switch-on the glow plugs manually. Since manual, its up to me how long I will allow current to pass to the glow plugs. Normally, I pressed push button switch for 5 seconds only (vs 2 minutes, as mentioned above). What I did was to disconnect the wire connecting to the relay from ECU, and replaced it with wire directly coming from the battery, which passes to a push button switch (in the cabin) and then to glow plugs relay, and thus eliminates ECU from the system.
this is the push button switch
added feature, a light to indicate that current is flowing to the glow plugs
DIY lahat and cost me around Php 200.00So far, 3 weeks na ok pa ang glow plugs ko.
mga idol, need help po...ask ko lang saan ba pedeng magpakabit ng windshield frame para sa pajero natin? nagcanvass kasi ako sa isang shop, ang turing sakin ay 8k all in. brandnew orig. ganun ba talaga ang price nun? mahal pa sa brandnew windshield. my leak at deform na kasi ang windshield frame ko. tnx
Mga bro kung ma ugung ba wheel beraing ang sira? at hindi ba sya delikado?
john, afaik bearing pwede mag seize, pwede rin madurog. pag bumigay di ka aandar. baka mas mahal pa yung towing charge sa bearing mismo.
thanks..... Do you have idea magkano wheel bearing? kasi front lang around 2k tama ba?
kung mayroon please let me kno kung saan.
Yung sa dash board ko pa regarding sa shifting ng shocks ko soft, mideium and hard wlang light but i feel that the shocks are still working sa light lang. Do you have suggestion kung saan pwedeng electricain pagawaan?
TYVM
