Page 292 of 330 FirstFirst ... 192242282288289290291292293294295296302 ... LastLast
Results 5,821 to 5,840 of 6591
    Jun 2009
    #5821
    Quote Originally Posted by gioravelo15 View Post
    salamat sa reply sir RTS! pinalitan ko glow plugs ko Federal Mogul tatak sana tumagal. ok na ung pag start:D
    Sana nga natumbok mo ang problema, In my case, as I've said halos apat na beses akong nag palit, finally na feed up na ako binay pass ko na lang iyung relay( done by auto elect) ngayon almost 2 months na wala akong problema, mind you ang nakalagay ngayon are yun cheap brand. Any way gud lak.
    RTS
    Aug 2007
    #5822
    mga sir! ano kaya problema palagi nag blink yung 4 wheel indicator sa odometer ko. yung parang dalawang gulong sa itaas. steady lang yung dalawa sa ibaba. thanks
    Aug 2006
    #5823
    good evening sir's.
    6 months ago, I replaced my compressor w/ a new one, cleaned the whole system, replaced the drier, expansion valve and surplus aux fan, pero I still experience a not so cold aircon especially sa harap. it only gets cold pag bukas na yung aircon sa likod, pero pag super traffic, nbabawasan na yung lamig kasama yung sa likod.
    In a short description, mas malamig yung aircon sa likod compared sa harap.
    ano po kaya problem? I know mejo nagbabawas ng freon pero yung mas malamig sa likod e questionable sa akin.
    sabi ng EEB aire mktg, may maliit na leak and at the same time baka daw mahina na yung aux fan. Also consulted another aircon technician, possible daw yung expansion valve.
    may naka experience na ba nito? at sana hindi compressor, at sana konti lang palitan.
    thanks mga sir's, would really appreciate your comment and recommended shops that would offer 1 year warranty, medyo malayo kasi ang eeb sa akin.
    Thanks
    Aug 2006
    #5824
    good evening sir's.
    Thanks
    #5825
    [QUOTE=promdiboy;1424785]nelany, based sa reviews ng tire na yan, its way better than the stock bridgestone HT d689 natin, not bad yung treadwear score niya. yung stock HT ko tumagal din ng 40k kms. baka yan kaya ng 60k kms.
    PB hindi ganong gamit itong FM ko so tatagal sa akin tong bagong tires.
    Blue gambit, hindi ko pa naitatakbo sa highway so hindi ko pa alam kung maingay. Yung review niya base sa link ni PB ay ok naman. Score ko sa apat na brand tires ay 10K.
    Dec 2009
    #5826
    blue gambit thanks,
    Just replaced my tires with General Grabber AW. Nice and very affordable one.
    10kfor all 4? Good deal!
    Jun 2009
    #5827
    Hi,
    Kanina on my way home nagstuck ang busina ko, ayaw mamatay, this is not my first encounter, I had several experience & can be corrected by a strong thud sa center ng wheel but today ayaw talaga mamatay only, I had to disconnect para maka uwi. Tomorrow I will try to tuklap the wheel cover where the horn botton is situated. It seems na malambot na plastic lang ang naka cover. Has anybody tried lifting the center wheel cover without disturbing the mechanism of the airbag?, is it just simple lifting that plastic cover, it seems locking hook lang ang humahawak but I felt stiff resistant when I tried this evening fearing that if I continue it may trigger accidental activation of the air bag.
    Thanks in advance for any info you can share or shall I desist the attempt & bring it to the expert.
    Rgds.,
    RTS
    Jun 2004
    #5828
    stadaenko - thanks for the tip. Do you remember the price Seatmate quoted you back then? Is the 3rd row jump seat OEM na ni-leather lang nila or is it a fabricated one? I don't mind having front facing 3rd row seats. The 3rd row seats on my other rigs are all front facing. Itong Gen 2.5 lang ni wifey ang hindi.
    Jun 2004
    #5829
    RTS,
    I personally would not mess around with that. Baka ma activate ang airbag niyan.
    #5830
    Quote Originally Posted by paj4x4 View Post
    if i remember correctly, mga 14K sya at that time. i didn't ask wether the seats had oem frames or not.
    Mar 2003
    #5831
    nelany, grabeng mura nga ng tires mo, did you check the production date? just to be safe
    rts, nung nagpa align ako they removed my steering wheel. mabilis lang nila nakalas. dinisconnect muna nila negative terminal for the airbag, after 5 minutes tsaka kinalas yung dalawang alen screw sa gilid ng manibela. ayun kalas na,
    #5832
    sir san mo na kuha yan, ang mura naman? pm mo naman ako where? thanks. pag 10K lahat, pati spare ko papalitan ko na rin
    [quote=nelany;1425309]
    May 2008
    #5833
    Ako naman nawala yung responsiveness ng horn button. May lag between pressing it and the horn engagement. Palit steering wheel?
  14. #5834
    blue gambit thanks,
    sir, kindly PM me where i can get cheap general grabber tires. i just need one though for my spare.
    Jun 2009
    #5835
    *promdiboy
    Thanks for the tips, kung madadala ni kumander ngayon sa auto elect,I will pass your tips, kung hindi naman maybe I can do the tinkling this saturday ,I will just keep clear of the trajectory path of the air bag in case things goes awry(joke only ).
    Rgds.,
    RTS
    Aug 2007
    #5836
    Quote Originally Posted by janrye26 View Post
    follow up ko lang po
    #5837
    mine is a 7 year old pajero (2003), matic.. so far, the problem I'm facing now is a bad turbo, trying to look for a surplus to fix it...
    My friends suggested that it's time to sell my pajero and get a new unit because they say that it's starting to show it's wear and tear na. Left upper balljoint needs replacing na rin, the tire pressure sensor is busted na. Shocks were replaced years ago (but not orig, yun may sensor kaya wala na rin ang S-M-H options)...
    what you think guys? Is this worth keeping pa?
    for trade in, hyundai valued it at 500T while Kia valued it 700T only. Ganun na lang po ba ang price ng 2003 pajero?
    Apr 2008
    #5838
    Quote Originally Posted by RTS View Post
    RTS
    RTS magkano total damage mo nung pag bypass? may switch ka na ba sa loob pinipindot for that?
    Apr 2008
    #5839
    nelany sobrang mura tlaga nung tires mo! san mo ba nabili yan?
    #5840
    Quote Originally Posted by Dudee View Post
    you have to understand that these car dealers still have to sell the unit that you are trading in. in which case, they obviously need to sell it at a price higher than how much they valued it to you for. realistically its the dealers price that is the fair market value of your pajero.
    i know i'm selling my pajero but for reasons not similar to yours. if the world were just up to me, i'm keeping the paj.
