Gary, hanap ka ng 'antenna stalk' or 'antenna core' sa mga banawe boys. That's the toothed white plastic thingie inside the power antenna. P500 lang yan with install.
I've also experienced such engine performance with my gen 2.5, and it's due to ambient air temperature. The cooler the ambient air the better the engine performance.
grabe naman yun! 2K for the stalk!!!
FOr P3700 meron ka nang antenna assembly complete with motor![]()
wala rin atang half height mode yung mga replacement antennas kaya better have it repaired na lang. mas tipid.
meron ba dito yung parang sa ebay na Euro style na antenna na non-retracting tapos kulay black? ok ba yun?
PK: yung 500 sa tabi-tabi yun, banawe boys?
diy ko lang kinabit stalk. mahal nga talaga for 2k. dito kasi province para makuha manila stations, kailangan naka full extend antenna. :car:
paj4x4,
yung mahinang hatak happens anytime of the day. i'm also experiencing electrical problems, kasi right now my side mirror adjuster, lighter and the automatic transmission button (pwr and hold) doesn't work too. even the rpm reading is sometimes pointed to zero (no engine activity) and will suddenly jump to normal level. does this have something to do with the performance of the engine?
mga sirs,
ask ko lang...ilang kilograms safely pwedeng dalhin ng pajero?
in short, ilang sacks of rice pwede ikarga sa pajero?
750kg sa unbraked trailer (kasama weight ng trailer dun). Around 5000 lbs. if you have trailer brakes.
I carry 14 sacks per trip on an unbraked trailer.
Sa loob hindi ako sure. Around 350kg-500kg yata. Check mo yung mga ex-JDM units. May label sa tailgate ang mga iyon ng load capacity.
Nangyayari din sa akin yung mahinang hatak, pero I got so use to it na that im not bothered by it anymore. Although when I do get home sa pinas Ill be trying out that washer mod. Subukan mo rin it might help. Yung electrical problems mo like the lighter and mirror adjuster sounds like a blown fuse to me.Just check out the fuse box and replace the fuse that needs replacing. With regards to your tachometer, do you mean at normal engine idling sometimes zero pa rin siya? Have you installed aftermarket gauges like indiglos? If so baka hindi lang ayos yung pagkaka-install. Baka sumasabit-sabit lang yung needle.Originally Posted by Mcmanster
Originally Posted by OTEP
thankz po sir otep...
medyu ot:ganito po ba ito computed:
Gross Vehicle Weight - Curb Weight = weight na pwedeng dalhin
di ko sure,guess ko lang...sa mga trak kasi parang ganito ang gawa...
Yup. Same computation as the trucks.![]()
voltes_V,
thanks for the info!I have a question, might sound stupid but what is a washer mod?
Washer mod is 1 way of maximizing the performance of a TDIC engine. Just type "Cranking up the boost" on the search function. May mga explanation doon on how to do a washer modification.
Guys, Is any one installed rear set of light on rear stainless bumper? I saw some fieldmaster has them (US/Australian version yata) , tough it looks redundant to me with all the OEM back light working. I just need it to cover the bump marking on my bumper. May naatrasan akong steel post kahapon which damage my metal bumper and corner fiberglass bumper. I bought it to body repair shop and told me that the corner bumper could be restored perfectly but not the metal one (P3K ang body work). Magkano kaya yun rear light set?
What kind do you have? Yung combination brake/turn or yung reverse?
May replacement mura lang. Orig mga 7k
Hi PK, I don't have it yet. Balak ko lang magpalagay para ma-conceal yun "pukpok" dent marking ng stainless bumper ko. Combination light nga yun parang three lamp in a row. Siguro I will opt for replacement lang kung di naman halata na di ito original. Any idea where could i buy them? Thanks..
field master pics ah after mo pakabit. meron dati nagbebenta sa lumang classifieds ng tsikot. kaso nalimot ko na yung price. baka ma search mo pa. bumperlites yata ang tawag niya. pag dimple lang back up sensor nalang.
I'm going to manila tomorrow, kinabit ko yung lock ng pang stante sa rear quarter windows ko. corny tignan, dami na kasi ninanakawan sa manila. baka mainis lalo yung magnanakaw pag makita yung locks. gawing extra challenge yung paje ko. :car:
