Page 186 of 496 FirstFirst ... 86136176182183184185186187188189190196236286 ... LastLast
Results 1,851 to 1,860 of 4959
    #1851
    Quote Originally Posted by first_light View Post
    Let MMPI prove that it’s not their fault by making an investigation on the control & safety system of those MSs that have been buy-backed in the presence of the third-party investigators and some certifying bodies. Check the event log of the following input signals:
    1.Accelerator pedal (not the 0-5V signal or whatsoever as this can also be triggered by any external factors).
    2.The shifter P, N, D, R.
    3.Brake pedal.
    4.Other signals relevant to the acceleration of MS.
    Criteria for checking the event log:
    1.If the accelerator pedal was ON at the same exact time the car moved in the CCTV footage, then, driver is at fault.
    2.If the brake pedal was ON at the same exact time the car moved in the CCTV footage, then, the MS is faulty.
    3.If the shifter moved to D or R while the accelerator pedal was ON at the same exact time the car moved in the CCTV footage, then the driver is at fault.
    4.If the shifter remained in P at the same exact time the car moved in the CCTV footage, then the MS is faulty.
    Question: What if there’s no event log for the above indicators? Can the accusers sue MMPI?
    The problem is, the media has sensationalized the issue and many other MS users are now afraid because of this.
    I’m not against or pro MS. All of us want to know the TRUTH.
    Tapos na po investigation. Back read ka sir makikita mo post na picture ko from mitsu. Yup. Lalo lang nila pinasikat MS. Nagkalat tuloy GLS V SE sa daan which is nakakatuwa pa din kasi hindi naman nila sinoli unit nila. 😊
    #1852
    Quote Originally Posted by ClaNker View Post
    Wow so any electronic or mechanical issue is ruled out.
    Brilliant.
    I think niky already pointed out that the 3 main causes of SUA is posiibly present.
    Sent from my LG-H818 using Tapatalk
    #1853
    Quote Originally Posted by dishcom View Post
    Sino ba may pic or nakaka alam ng process ng brake light ng MS. LIke pag baba ng brake pedal e anong type ng switch or sensor ang makakaramdam noon, then saan dadaan bago mapunta sa break light at umilaw..
    Kung ang connection kasi ng MS ay gaya sa manual jeep na may di hilang switch na naka kabit sa break pedal, then naka wire pa fuse, then break light i think masasabi kung hindi nag break si white montero. Pero kung dumaan sa ECU doon may duda pa akong nag break siya at walang effect sa auto.
    May nakita na ako na manual. Google it na lang.
    Mar 2013
    #1854
    Quote Originally Posted by frostmourn View Post
    That is what you call experts! Diba ganun naman talaga. Pag may opinion experts na. Hehehe kung alam nyo lang ano kakayahan ng ECU ng montero. ☺
    That makes you an expert as well.
    Ano ba ang kakayahan ng ECU ng Montero?
    #1855
    Yup AtoD then DtoA... Inherent chip function...
    Sent from my Nexus 7 using Tapatalk
    Sasabat na sana ako kasi Dota basa ko. Iba pala. Continue pls.
    Mar 2013
    #1856
    I'm just playing with the fanboys.
    #1857
    Quote Originally Posted by Juan Martinez View Post
    so many theories and theorists that are coming out. next time we know this SUA is blamed on the moon. where's OB?
    May thoery na siya. Bading daw mga nagdri drive nang nag-SUA na monstero... OB and his err mind. 😛
    #1858
    Im not and its not an opinion sir. Wala naman ako argument na binanggit. wala po sir. Weak lang po kasi talaga montero. Hehe
    Mar 2013
    #1859
    Oh so if that's not an opinion then that makes it a fact.
    Just playing.
    #1860
    GG ka dun Ry_Tower! Lol. Balik sa SUHA. tama nga si sir glenn kasalanan ni PNOY pinili kasi sumakay sa montero during inauguration of mitsubishi vs. Saf 44. Epic failed!
Mitsubishi Montero Sudden Acceleration Accidents [MERGED]
