Results 1,951 to 1,960 of 4959
June 8th, 2017 04:27 PM #1
- 54,226
June 8th, 2017 03:54 PM #3
And do note: Horiba found at least one competitor with pedals just as offset or further offset. Will the DTI now demand that car have its pedals rectified as well?
I've driven many vehicles with weird pedal or steering offsets. What matters, in the end, is proper orientation of the driver, and a quick run through of the controls each and every time you get into the car. Pump the brakes a few times, tap the gas, make sure everything is in working order.
A lot of these SUA cases, again, have people just getting in the car or subbing out another driver... which can lead to ergonomic confusion as the seat and controls are not in a relation they're accustomed to.
Is the Horiba's speculative cause a probable cause? Yes. Is it proof of criminal negligence? Without safety standards prescribing proper control placement, no.
In the Toyota USA SUA case, they sawed off a portion of the accelerator pedal to prevent mat entrapment.
In this case, you can adjust the pedals by simply fixing a new pedal assembly over the posts. Would cost Mitsubishi under 1k per car for the "fix".
If you've got butterfingers... errh... toes, changing out to a set of pedals that is more aligned to the seat is a good idea.
BANNED BANNED BANNED
- May 2017
- 210
June 8th, 2017 05:33 PM #4Best way for mitsubishi to cut cost on recall is just put sticker sign " watch your step" on the steering wheel and at the bottom of HU.. cost less than 100 per unit..🤣🤣🤣🤣
June 8th, 2017 08:02 PM #5
Out of curiosity, compared the brake and accelerator pedals of the MS AT with three other brands, and I did not see any significant difference in pedal sizes and positions.
They're adequately spaced apart and the brake pedal is placed higher relative to the accelerator pedal.
June 8th, 2017 08:12 PM #6
How about comparing a 2009 MS AT to a, say, 2015 MS AT?
Will there be a difference in the positions and placement of the brake and accelerator pedals?
Like I said erlier, it's strange that DTI did not order a recall on the 2009 models.
2010 to 2015 models only.
Are they saying 2009 models got it right, while 2010 to 2015 models got it wrong?
Lahat naman yan 2nd gen.
June 8th, 2017 08:14 PM #7
June 9th, 2017 05:33 PM #8
June 9th, 2017 07:22 AM #9
If the pedal needs to be idiot proof then something is wrong with the driver..
June 9th, 2017 05:43 PM #10
Hahaha, natawa naman ako na specific AT units pa talaga lang ang pinupunto ha. Parang magkaiba pa pedal nung low end at sa totl. Ayos talaga.
Sent from my LG-H990 using TapatalkFasten your seatbelt! Or else...Driven To Thrill!
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
