Results 61 to 70 of 2039
June 5th, 2009 10:34 PM #61
- May 2008
- 289
June 6th, 2009 11:18 AM #62hi guys,
i want you to update on my complaint of thug thing when starting. the casa has quit dealing with it. it is just my uniit among thousand that has the problem. after changing the rubber support for the engine which did not solve the problem.
the casa told me not to bring the unit yet to their service because they have no solution yet comming from the plant (mitsu plant in phil).
so please, when getting nes GLS SE. feel the starting at least 5 times and road test. beacuse it (thug) hapens when the body engine is hot. i presume the rubber support for the trany and engine gets soft when heated. Thus the engine vibrates to hit the chais and body.
- May 2008
- 289
July 1st, 2009 08:13 PM #63Thanks to c5.... the above problem is gone...... they made some putol yATA. i take some pics and post
July 2nd, 2009 08:44 PM #65
i has some rattles at the back pag nalulubak (can be heard when the audio / music is off) i think parang sa glass window/s.
dunno kung saan really or is it a result from low sound frequency when i'm listening ng medyo malakas?
July 3rd, 2009 08:27 AM #66
July 3rd, 2009 10:32 AM #67
July 3rd, 2009 11:46 AM #68
Try also checking the suspension.. Cause i had that too then it turned to something like a metal hitting each other which automatically pointed me to the suspension. And true enough, the shock absorbers were broken... lukily they admitted that it was a factory defect so they'd change it for me even if its a non warrantable part.
- Apr 2009
- 72
July 4th, 2009 11:42 AM #69helo mga sirs just got my silver montero yesterday, problem is ng moist kagad ung headlights kagab after k ginamit ung oto. meron na ba nakaexperience ng ganun problem sa mga monty owners? tnx.
July 4th, 2009 12:41 PM #70
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
