Page 142 of 205 FirstFirst ... 4292132138139140141142143144145146152192 ... LastLast
Results 1,411 to 1,420 of 2048
    Sep 2011
    #1411
    Quote Originally Posted by altec View Post
    Re inhibitorswitch, yun din sabi sa akin ng casa, change. Ang mahal pala ng hayop. Forgot how much but i am sure over 10k. Dinala ko sa outside shop, nilinis nyw wng switch. Ok na. Running on the cleaned switch for over 5k mileage.
    Sir saan ka nagpalinis ng inhibitor switch? Medyo nagkakaroon narin ng symptoms yung amin kanina lang e.
    Aug 2003
    #1412
    Nasa probinsya ako eh. Try to ask your favorite repair shop kung naka trabaho na ba rin sila ng inhibitor switch. I called up my shop to inquire. Sabi nya, marami na raw siya nalinis na switch: isuzu trooper, honda crv, nissan, mitsubishi. So its a common problem. Ang ginawa niya, dismantled the switch, then niliha ang bronze contacts, stretched the coil spring, then re-assemble.
    Jun 2013
    #1413
    Sir altec saan shop yung sinasabi mo? Tingin ko ganyan din problem ng montero namin. Nawawala yung display sa gauge pag naka drive ako. Parang naka neutral na tapos kailangan mo ipasok sa N para kumagat sa drive.
    #1414
    While driving my montero Gls v automatic 2011 model, suddenly shifts back to neutral. We don't have casa in our area so I had it checked in a car shop, the mechanic said to have adjusted something and for 2 weeks it's ok, but now the problem is back!. It's risky because it just suddenly shift back from drive to neutral, I have to stop and place it to park then drive again before if works. Any comments?
    Feb 2007
    #1415
    Inhibitor switch or Neutral Safety switch malfunction and needs replacement for peace of mind.
    6-7k pesos sa suking casa.
    Sep 2010
    #1416
    Quote Originally Posted by vromvrom View Post
    The thought just scares me... Imagine the scenario where you are overtaking and the gear shifs to neutral!!...catastrophic indeed.What's worse is that you have shift to P before engaging the D again. So is this an isolated case or others have experienced it?, haven't heard this issue with any automatics of other brands, correct me if i'm wrong.
    No fail safe feature??!!.
    Jun 2012
    #1417
    Na experience ko yan bro, pa overtake ako *60 kph biglang nag jerk or parang nag engine brake yung engine.
    Anyway sira nanaman ata aux fan ko, mukang nirepair lang ng casa at Hindi ni replace. Kasi mas naging malamig ung buga ng ac pag dating ng hway though pag naka max setting naman ang fan at temp gauge e todo ikot ang aux fan. Any advice?
    #1418
    Quote Originally Posted by fredgimed View Post
    Oh man,- nakakatakot iyan,- wala bang ginagawa ang Mitsubishi para i-correct iyan once and for all...?????
    Hindi puwedeng palit lang ng piyesa ang solusyon diyan.
    Kung failsafe ang intention nila riyan- i bypass na iyan...
    And there will be no peace of mind here,- because it could happen any time..... Deym!
    It's an accident that is waiting to happen....
    I have been driving A/Ts (various makes/models for years,- and I have not encountered a similar issue)
    25.8K:shazam:
    [/COLOR]
    Dec 2014
    #1419
    Whoa. I drive a GLS automatic also. This is scary indeed. I'll ask Mitsu to check during next PMS.
    Jun 2013
    #1420
    Mar04 may ginawa sa akin dati sa casa parang pinukpok lang ung motor ng aux fan gumana ulit, ilang araw lang ayaw na ulit umikot. Ginawa ko pumunta nalang ako sa aircon shop supplier ng mga parts. May replacement sila kaunting modification lang sa housing. Wala pa ata 800php sanden replacement assembly na pero motor lang kukunin mo hindi mo kakabit fan na kasama kasi maliit ata.
ISSUES FOR THE MONTERO SPORT. Please post them here.
