Page 152 of 205 FirstFirst ... 52102142148149150151152153154155156162202 ... LastLast
Results 1,511 to 1,520 of 2048
    Apr 2005
    #1511
    Help naman, sirs. I bought on 09 GTV 6 months ago and had been very happy with it. 2 weeks ago, the airbag icon lit up persistently. I brought it to Amcar Sta Rosa. After 3 days, they said they didn't have the tool to fix it. I then brought it to Citimotors Alabang. They replaced the clock spring which they initially said was the problem, but it didn't help. After 3 days, they said they didn't have the "test part" to fix the fault since they said that even if my unit was locally purchased, it was sourced from Ukraine and not Thailand. Now I'm afraid all my airbags wouldn't work in case, God forbid, I get into an accident. I hope you have any leads on how I should proceed? Thanks.
    Jun 2012
    #1512
    I just changed the battery last week(motolite excel), kaso napansin ko is may times na hindi nag sta start kagad. madalas pag pangalawang try dun lang nag sta start pero may times na umabot gang 3 try. Ano kaya problema? TIA
    Jun 2015
    #1513
    For those who have their MonteroSport equipped with TPMS, do you have issues with it? Mine have false reading (i.e. Right Front tire registers 7-9psi more than actual). I know this because I have repeatedly cross checked with digital and manual tire pressure gauges with front tires at 32psi only and 35psi at the rear. Ok naman sa ibang gulong at almost tally sa actual with (+/- .5psi difference), except that Right-Front registers 39-41psi na sobrang laki. I brought it to casa (DCT-Caloocan) and I was referred to Winterpine techinician at sabi baka module (located in the dashboard) daw sending erroneous signal to the monitor. Because I suspect na yung sensor mismo sa gulong ang culprit. For those who have experienced it, ganoon din po ba naging remedyo nila?
    Jul 2015
    #1514
    Quote Originally Posted by *redlantern View Post
    Im taunting some of my filipino collegues for buying montero. They have problems with their faulty montero.
    I told them before not to buy mitsubishi. Worst they bought a diesel engine.
    For its size its the cheapest car in the philippines. You get what you pay for.
    Montero owners might get mad.
    #1515
    Quote Originally Posted by zix888 View Post
    ac fan motor replace
    *ZIX
    Magkano ho gastos palit ng fan motor?
    Nov 2012
    #1516
    Quote Originally Posted by mar04 View Post
    kung bago battery tapos matagal mag start better check yung mga heater plugs baka may busted na
    Sep 2011
    #1517
    Sirs, may nagpalit na ba ng horn switch sa inyo?
    Yung sa amin kasi, malambot parin yung busina pero need mo talaga idiin yung pag press para tumunog siya.
    Yung sa left side ok naman. Ang problemado lang is yung sa right side.
    Asked a shop and sabi niya medyo delikado daw kasi may airbag.
    #1518
    Quote Originally Posted by babynos01 View Post
    basta remove battery terminals, pwede na ayusin yan. make sure lang plugged lahat ng sockets after. bago reconnect battery
    Sep 2011
    #1519
    Pinapalitan lang ba yung switch nun sir? First time ko lang din kasi naencounter yung ganito. If switch siya sir, may idea ka sir magkano?
    Feb 2013
    #1520
    Mga Sir, just want to ask if kelan ba dapat magpalit ng Aux Belt?
ISSUES FOR THE MONTERO SPORT. Please post them here.
