Results 1,411 to 1,420 of 2048
- Sep 2011
- 626
February 7th, 2015 08:17 PM #1411
Tsikot Member Rank 3
- Aug 2003
- 1,251
February 10th, 2015 04:17 PM #1412Nasa probinsya ako eh. Try to ask your favorite repair shop kung naka trabaho na ba rin sila ng inhibitor switch. I called up my shop to inquire. Sabi nya, marami na raw siya nalinis na switch: isuzu trooper, honda crv, nissan, mitsubishi. So its a common problem. Ang ginawa niya, dismantled the switch, then niliha ang bronze contacts, stretched the coil spring, then re-assemble.
- Jun 2013
- 244
February 23rd, 2015 06:26 PM #1413Sir altec saan shop yung sinasabi mo? Tingin ko ganyan din problem ng montero namin. Nawawala yung display sa gauge pag naka drive ako. Parang naka neutral na tapos kailangan mo ipasok sa N para kumagat sa drive.
February 25th, 2015 12:32 AM #1414
While driving my montero Gls v automatic 2011 model, suddenly shifts back to neutral. We don't have casa in our area so I had it checked in a car shop, the mechanic said to have adjusted something and for 2 weeks it's ok, but now the problem is back!. It's risky because it just suddenly shift back from drive to neutral, I have to stop and place it to park then drive again before if works. Any comments?
February 25th, 2015 12:39 AM #1415
Inhibitor switch or Neutral Safety switch malfunction and needs replacement for peace of mind.
6-7k pesos sa suking casa.
- Sep 2010
- 81
February 25th, 2015 07:16 AM #1416
The thought just scares me... Imagine the scenario where you are overtaking and the gear shifs to neutral!!...catastrophic indeed.What's worse is that you have shift to P before engaging the D again. So is this an isolated case or others have experienced it?, haven't heard this issue with any automatics of other brands, correct me if i'm wrong.
No fail safe feature??!!.
- Jun 2012
- 269
February 25th, 2015 08:11 AM #1417Na experience ko yan bro, pa overtake ako *60 kph biglang nag jerk or parang nag engine brake yung engine.
Anyway sira nanaman ata aux fan ko, mukang nirepair lang ng casa at Hindi ni replace. Kasi mas naging malamig ung buga ng ac pag dating ng hway though pag naka max setting naman ang fan at temp gauge e todo ikot ang aux fan. Any advice?
February 25th, 2015 08:19 AM #1418
Oh man,- nakakatakot iyan,- wala bang ginagawa ang Mitsubishi para i-correct iyan once and for all...?????
Hindi puwedeng palit lang ng piyesa ang solusyon diyan.
And there will be no peace of mind here,- because it could happen any time..... Deym!
It's an accident that is waiting to happen....
I have been driving A/Ts (various makes/models for years,- and I have not encountered a similar issue)
25.8K:shazam:
[/COLOR]
February 25th, 2015 09:16 AM #1419
Whoa. I drive a GLS automatic also. This is scary indeed. I'll ask Mitsu to check during next PMS.
- Jun 2013
- 244
February 25th, 2015 12:32 PM #1420Mar04 may ginawa sa akin dati sa casa parang pinukpok lang ung motor ng aux fan gumana ulit, ilang araw lang ayaw na ulit umikot. Ginawa ko pumunta nalang ako sa aircon shop supplier ng mga parts. May replacement sila kaunting modification lang sa housing. Wala pa ata 800php sanden replacement assembly na pero motor lang kukunin mo hindi mo kakabit fan na kasama kasi maliit ata.
