Results 21 to 30 of 2048
April 24th, 2009 05:32 PM #21Yes i did. the mechanic sid that they also notice one from the other but the owner did not notice. after fixing that unit, ako din daw. pinababalik sa akin dahil no time na when i went there.
May i know kung saan casa ito? I want my montero to be checked din for this issue. thanks
- May 2008
- 290
April 28th, 2009 05:05 PM #22update lang po. The casa seems to unable to fix the "Thug" sound when starting. They quit fixing it.
The culprit is the engine hitting the chasis when starting. I sent the unit to them 3 times already and the Thug is still there but lessened. BUT the thing is: it still there. Once in a while it "thugs". If this not usual to other GLS SE 4x4, then our unit should be replaced if not corrected.
According to the attendant of the other forumer who has same unit told him it is normal because it has a bigger engine. Grabeeeee...... i will write Mitsu thailand and japan and philipines to complain.
i keep you all updated.
April 28th, 2009 05:27 PM #23
So if the engine is hitting the chassis during starting then it would only be a matter of time before it might also hit it when shutting down.
I think there a design defect on the engine mounts and clearances.
- Jan 2003
- 40
April 29th, 2009 05:21 PM #24Ako issue ko sa front aircon.
May air leak sa ilalim (towards your feet, both sides - driver and passenger) even if the setting is Air to the Face mode.
I've tested 2 other MS units, 1 GLS SE and the other was a GLS 4x4, parehong meron din.
Last week went to the CASA for my 5KM PMS (btw, 2,100 pesos sya top up of 2 liters na synthetic oil and air filter) and had it checked, NORMAL daw yun. They can't find anything wrong.
Ganyan din ba mga units nyo?
Aside from this, wala akong complaints (not weird sounds as posted in Page 1 nor wiper issues).
April 29th, 2009 06:42 PM #25
- Jan 2003
- 40
April 30th, 2009 12:50 PM #26Hmmm. pasensya na. Now ko lang napansin sa Mitsubishi vehicle kasi ang ganito. I have a spacegear, no permanent vent (unless you switch to AIR to FEET mode), also had a GSR coupe, same thing. Same case with my past cars Toyota, Isuzu, etc.
Weird lang for me and nasasayangan sa air flow kasi the front vents are not only for the 1st row but for the 2nd row as well, the higher the airflow the better for the 2nd row passengers.
April 30th, 2009 01:41 PM #27
sir dapat wala. nabuksan na ba center console mo like HU upgrade or amp installation? baka lang di naikabit mabuti yung cables for a/c switches particularly for the air distribution setting. when my amp was installed, i see to it that all cables and switches are in place and working prior to closure.
April 30th, 2009 02:12 PM #28
bro, wala pang ganyang issue na lumabas sa strada thread (as far as i can recall)...
yan ang advantage if you have a club... you can compare your unit with one another so alam nyo ang 'normal' o hindi. but i can attest may mga complaints na driver na ang may problem hindi yung vehicle (proven na yan sa strada club, hehehe). naalala ko tuloy si steve, yung british na member ng TSCP, when asked kung may complaints siya sa strada. eto reply nya:"its a damn pick-up, not a bloody ferrari!"Last edited by ThePatriarch; April 30th, 2009 at 02:15 PM.
- Jan 2003
- 40
April 30th, 2009 02:18 PM #29Sir XTO, di ko pa pinapabuksan ever since binili ko. Baka nga ayusin ko na lang pag nagpainstall ako ng amp. Mukhang tinatamad lang talaga sa CASA since baklasan ang mangyayari to fix it.
I did however noticed the same thing with 2 other units, although I have to admit mas mahina yung buga ng hangin ng unit nila.
Thanks for the reply.
- May 2008
- 290
May 12th, 2009 04:00 PM #30another issue.... fog lights..... trany hitting metal when starting....steering wheel.......
i will not be surprised if the company will recall all..... but with this financial crisis around the world, highli impossible...... i should have gone to Toyota for a second look before i got my MS4x4GLSse....
I use imgur.com. Upload the picture there, then get share links, choose bbcode and paste here.
Mineral , semi synthetic or fully synthetic?
