Results 21 to 27 of 27
- Mar 2006
- 11
January 21st, 2015 06:30 PM #23Hmm i didn't know pwede pala sa wet pavement yung 4H ng strada. I thought sa gravel and mud lang. You learn something new everyday! Thanks sirs.
- Mar 2006
- 11
January 21st, 2015 06:45 PM #24
January 23rd, 2015 12:31 AM #25
Sir Gambit1976,
Ok naman po i-engaged yung 4H sa easy select, as long as po na wet road condition/gravel condition, pero pag dating sa 4LLc. extreme road condition katulad po sa mud/rocky road.
BTW:
Sirs, ask ko na rin po? during towing condition? lalo sa 4wd system, kailangan po ba naka-activate sa 4H? or nasa 2H mode pa rin?
January 23rd, 2015 09:24 PM #26
Keep in Mind that super select is essentially a fulltime 4wd with a 2wd mode. The unlocked center diff allows it to operate on high traction surfaces (pavement)
Easy select, on the other hand, is a conventional direct drive system with no center differential. Hence it should not be operated on high traction surfaces. Binding will occur if it is operated on high traction surfaces.
The claim to fame of easy select is the ability to shift into 4H at reasonable speeds without having to be at a complete stop. But its still a conventional system in terms of power delivery and drive characteristics.
- Mar 2006
- 11
Exactly. What about due process, right?
