Results 11 to 20 of 27
- Apr 2009
- 429
January 20th, 2015 11:22 PM #11Also, using 4H on dry pavement will not only wear out your tires faster, but more importantly, your gears (the 4WD system that is) will bind or it will grind on itself.
If you want full control during high speed with twists and turns on dry or wet pavement, all-wheel drive is the way to go...
January 21st, 2015 12:38 AM #12
The Strada uses a conventional 4wd system designed for use on surfaces with adequate slippage (loose surfaces, mud, slippery surfaces). Otherwise, 'binding' will occur and can damage the drivetrain.
The Montero Sport uses the Super Select system and can operate on paved roads in 4H because it has a viscous center differential to eliminate binding on dry surfaces.
Lock the center differential and it operates no differently from a conventional 4wd system.
January 21st, 2015 12:44 AM #13
Sir niky & Sir LN106G,
Applicable lang po ito sa Part time 4wd? or even sa mga full time 4wd? sa super select po, pwede sa 2H at 4H, in dry road condition. (yun po ang nakalagay sa manual even dun sa sticker na nakadikit po sa gilid ng pinto sa driver seat)
Since under-used po yung sasakyan namin, minsan ginagamit ko po yung 4H, sa dry pavement para ma-lubricate yung gear sa transfer case, (80 KPH Max) then sa wet road condition naman, nasa 120KPH, in a short period of time. (5mins)
- Apr 2008
- 6,235
January 21st, 2015 12:58 AM #14I have tried using the 4H on our Strada GLS Sport V on our way to Sorsogon last December. The steep and sharp twisties were a real proving ground for the car. It felt very much more planted and secure than in 2H mode. There seemed to be less body roll and corners were taken with confidence and poise. On the straights I was able to push it upto around 110km/h. Acceleration was definitely not as quick as in 2H. According to the MID, FC increased from around 9+km/L in 2H to around 7+km/L in 4H. Same driving style, in the twisties.
Sent from my GT-I9100 using Tapatalk 2
January 21st, 2015 01:31 AM #15
January 21st, 2015 01:48 AM #16
January 21st, 2015 11:14 AM #17
If the Montero Sport is a viscous system and full-time, then there is no problem... as you can't switch to 2WD, anyway.
But such systems can still benefit from a 2H switch. The Nissan X-Trail comes with one, and that actually makes a huge difference in economy and power.
If there's less roll, then the car isn't cornering as hard. Hmmm... don't recall ever slaloming the Strada back-to-back in 4HI and 2HI... would be an interesting test.
- Mar 2013
- 6,160
January 21st, 2015 02:25 PM #19
Agree with Doc here. For the Mitsubishi Super Select system, 4H is different from 4HLc.
4H is "4WD, high range, viscous coupling, centre differential free for safe, highly stable driving on roads in virtually any conditions". 4HLc is "4WD, high range, centre differential locked for extra traction while traveling on rough roads or other low-grip surfaces at normal driving speeds".Last edited by Monty; January 21st, 2015 at 02:27 PM.
- Apr 2008
- 6,235
January 21st, 2015 05:12 PM #20Don't know of it's placebo as mentioned. But at the time it was raining continuously then, so the ground was wet. At higher speeds, while at 2H, I felt less in control of the fronts than I would've wanted. As if they were going to slide out upon turning due to the slippery road, which I suppose is the understeer mentioned. Upon shifting to 4H, it stuck to the road like glue, ran exactly the way I wanted, and cornered exactly where I wanted it to turn in without any drama.
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
