Brought my 2016 Montero GLS Premium to casa today for 5K PMS. I told them regarding the power steering shake or vibration I experienced when passing through humps, making u-turns and uneven pavement. Initially the SA said he's not aware but recommended me to report to the warranty department. Luckilly Iknow someone from the warranty team and when I talked to her m, he said that they are aware of this issue. The engr from the warranty team asked to to schdule an appointment. They will do replacement of the affected parts.
May issue pa lang ganito... I may need to closely monitor this scenario just in case I experience the same.
Luckily wala pa naman akong na experience na steering problem (so far). Mine is already at 9K, nabyahe kuna po ng Baguio, nadaan sa SCTEX/TPLEX on several occassions and also have tried short unpaved road, but so far so good.
Please update us kung ano po iyong mga parts na pinalitan after your appointment.
Thanks.
I am experiencing steering vibration when reaching the speed of 110 kph
Diamond motors chief sa may fairview commonwealth. They already replaced not the whole steering assembly but only the steering coupling.nawala na ung vibration durIng turns sa uphill and downhill and humps. Pero im noticing ung parang "alog" sa steering wheel when passing humps and unevennpvement.
whats the update from the thai and aussie forums/mitsu subsidiaries there regarding the issue?
nabibitin ang steering in some regular two way road pag mag U-turn. anyone experience this issue? parang bitin yung kabig for a bnew car.
Hi. Mitsubishi GLS owner here. I have been following this thread because I have experienced the same issues. I hear a knocking thud sound on my steering wheel when turning and on uneven surfaces. Reported it on my 1000 pms but Diamond motors say it's normal which is weird. Any news on where to go for this?
... and this is why the Toyota Fortuner will still outsell the Mitsubishi Montero Sport ... this and that hideous rear tail lights ...
what problems are you expecting?
can you list all of them?
I went to Mitsu last week and personally saw the memo/procedure gave by the HQ (probably memo from Thailand or Japan). Subject is "Reconditioning Procedure on Steering Lower Shaft of Montero QX with Knock Feeeling"
Ngayon naman problem ko may lumalangitngit sa steering wheel ko mismo.
Ayaw pa iconsider ni Mitsubishi na issue. As per customer complaints lang daw nila aaddress.
Kumusta na po ang issue na ito? Plan ko po sana bumili ng montero, well napapaisip ako if montero or altis ang kukunin ko nagaalangan tuloy ako dahil dito.
