Page 3 of 7 FirstFirst 1234567 LastLast
Results 41 to 60 of 128
    Nov 2014
    #41
    The "thug tug" sound as per Thai forums is normal. This is because of the collapsible steering column. Not sure if it's really normal.
    Well i just hope it's really normal. Though i only feel it lang namn sa mga Hard Turns.. naninibago kasi ako dahil sa Altis 2015 ko never feel that.. Thanks for the Response..
    Sep 2009
    #42
    Brought my 2016 Montero GLS Premium to casa today for 5K PMS. I told them regarding the power steering shake or vibration I experienced when passing through humps, making u-turns and uneven pavement. Initially the SA said he's not aware but recommended me to report to the warranty department. Luckilly Iknow someone from the warranty team and when I talked to her m, he said that they are aware of this issue. The engr from the warranty team asked to to schdule an appointment. They will do replacement of the affected parts.
    Quote Originally Posted by ramiel17 View Post
    Got My Gls recently, I noticed also the slight steering shake. More evident when passing thru uneven roads, even on speed bumps. I'm not sure if its steering feedback/road feedback. But definitely there's something of about it.
    I raise this with my agent before releasing my unit. He told me they haven't got any complaints yet
    Mitsubishi should release a technical service bulletin with regards to this issue. Since thai counterparts already acknowledged the problem also they've found the culprit.
    Do others have some feedbacks from mitsu?
    Jul 2016
    #43
    Quote Originally Posted by morbid29 View Post
    May issue pa lang ganito... I may need to closely monitor this scenario just in case I experience the same.
    Luckily wala pa naman akong na experience na steering problem (so far). Mine is already at 9K, nabyahe kuna po ng Baguio, nadaan sa SCTEX/TPLEX on several occassions and also have tried short unpaved road, but so far so good.
    Please update us kung ano po iyong mga parts na pinalitan after your appointment.
    Thanks.
    Aug 2012
    #44
    I am experiencing steering vibration when reaching the speed of 110 kph
    Apr 2012
    #45
    Quote Originally Posted by Aleman View Post
    balancing lang yan ng mga gulong. any tire shop with balancing equipment can do.
    Apr 2014
    #46
    *morbid29
    Saan casa ito. I have this kind of problem less that 3 weeks monty. Ramdam ko parati kasi pag igagarahe ko yung car left turn hump ang unang sasalubong sa kin. even pag maniobra at u turn
    Sep 2016
    #47
    I have GLS premium since June 2016. never had this experience.. if incase, alighment/balancing lang tires yan...
    Sep 2009
    #48
    Diamond motors chief sa may fairview commonwealth. They already replaced not the whole steering assembly but only the steering coupling.nawala na ung vibration durIng turns sa uphill and downhill and humps. Pero im noticing ung parang "alog" sa steering wheel when passing humps and unevennpvement.
    Quote Originally Posted by anivans_b View Post
    *morbid29
    #49
    whats the update from the thai and aussie forums/mitsu subsidiaries there regarding the issue?
    Nov 2016
    #50
    nabibitin ang steering in some regular two way road pag mag U-turn. anyone experience this issue? parang bitin yung kabig for a bnew car.
    #51
    Quote Originally Posted by EsYuBi View Post
    what do you mean, po?
    it's got a 5.6 m turning radius...
    Dec 2009
    #52
    Hi. Mitsubishi GLS owner here. I have been following this thread because I have experienced the same issues. I hear a knocking thud sound on my steering wheel when turning and on uneven surfaces. Reported it on my 1000 pms but Diamond motors say it's normal which is weird. Any news on where to go for this?
    Mar 2004
    #53
    ... and this is why the Toyota Fortuner will still outsell the Mitsubishi Montero Sport ... this and that hideous rear tail lights ...
    #54
    will the gt 4x4 have more problems?
    Quote Originally Posted by boybit View Post
    what problems are you expecting?
    can you list all of them?
    Sep 2010
    #56
    Quote Originally Posted by righthook View Post
    Mine is may konting parang alog. Papalitan ng citimotrs las pinas. Parts has just been ordered. Wla nmn problem daw maski byahe ako. In fact nabyahe ko for xa to surigao last monday ok nmn xa.
    Aug 2015
    #57
    I went to Mitsu last week and personally saw the memo/procedure gave by the HQ (probably memo from Thailand or Japan). Subject is "Reconditioning Procedure on Steering Lower Shaft of Montero QX with Knock Feeeling"
    Ngayon naman problem ko may lumalangitngit sa steering wheel ko mismo.
    Ayaw pa iconsider ni Mitsubishi na issue. As per customer complaints lang daw nila aaddress.
    Oct 2016
    #58
    Quote Originally Posted by pengmalups View Post
    Got mine reconditioned last week but the knocking sound is still there. Will bring it back to Mitsu Marcos highway for another round of testing on Monday and was advised to leave it for at least 3 days which sucks...
    Sep 2016
    #59
    Kumusta na po ang issue na ito? Plan ko po sana bumili ng montero, well napapaisip ako if montero or altis ang kukunin ko nagaalangan tuloy ako dahil dito.
    Aug 2015
    #60
    Quote Originally Posted by YMT75 View Post
    Hi there, updates please?
2016 Montero Sport Steering Issue
