Page 6 of 7 FirstFirst ... 234567 LastLast
Results 101 to 120 of 128
    Feb 2011
    #101
    Quote Originally Posted by ron_kimi View Post
    Hi I have a 2014 glx with 28T Kms on it. I just experienced that while running 100 kmh up i feel a strong vibration on the steering wheel when braking. But when i dont not apply on the brakes there is no vibration. Any tips on what could be the cause? I suspect it could be a warp rotor disc or worn out tie rod.
    Yup, this is a common issue for this model. It's the rotor disc if I remember correctly. Not dangerous (according to a specialist i consulted) but definitely irritating. hehe.
    You can opt to replace it but expect it to be back after some time.
    #102
    Warped rotor is likely.
    Jun 2010
    #103
    Quote Originally Posted by pobre24 View Post
    Thanks for the info sir can refacing the rotors solve the problem or do i have to replace them?
    #104
    The tok sound in the collapsible steering of my Mits Adventure was addressed by installing a hose clamp. 10 years had passed, never occured again.
    May 2008
    #105
    Quote Originally Posted by b0y37 View Post
    Sir, anong part ang sinecure niyo with hose clamp? Thanks
    #106
    Quote Originally Posted by blacksilver323 View Post
    Doon sa collapsible steering column. If I remember right, nababalutan ng plastic material yung steering column, eto yung "collapsible". Lagyan mo lang ng clamp para humigpit. Ill try to take a pic pag may time.
    Parang ganito yata sya, lagyan mo lang ng mas malaking clamp:
    Redirect Notice
    Jun 2011
    #107
    Hi guys. Naexperience ko na din tong knocking sound sa steering column lalo na pag uneven road. May i ask magkano na spend nyo parepair nito sa mitsu casa. Plano ko sanang paayos kasi nkakairita na. Thanks
    Redirect Notice[/QUOTE]
    Sep 2018
    #108
    Quote Originally Posted by ydrion View Post
    Redirect Notice
    [/QUOTE]
    May nakaranas ba ng ganitong issue sa 2018 model?
    Jan 2019
    #109
    Hello sirs! I had a 2012 Ford Fiesta with electric power steering that developed a severe steering rattle over uneven road. Ford was never able to fix it. Then I had a 2013 Kia Rio sedan also with EPS. KIA Ormoc changed the flimsy plastic rack bush inside the electric power steering column twice. Good only for a few months and the steering rattle came back. They also changed the steering electric motor, rattle still there. I sold the car after 5 years.
    Now i have the 2017 Montero Sport with about 16k kms on the odo. I feel a very slight rattle on the steering over uneven road at low speed. Mitsubishi Ormoc said its normal to have a slight rattle. Driving at high speed on highways, not a single rattle can felt; Steering is very smooth. EXCEPT it veers slightly to the right! As i read over the posts here, I realized this is not an isolated case and is a very common issue to this new Montero. I will have my Monty checked at the Mitsu shop tomorrow. I just hope this is covered by their warranty because as per inquiry, they said steering alignment would cost around P2,000. And I also hope they will resolve the issue.
    #110
    Feeling ko, this would fix ur problem.
    Basta EPS steering mo.
    Labor charges will be quite high, dissasembly is hard.
    Of course, find one that fits ur brand na car
    Mar 2019
    #111
    Quote Originally Posted by righthook View Post
    Hi. Mitsubishi GLS owner here. I have been following this thread because I have experienced the same issues. I hear a knocking thud sound on my steering wheel when turning and on uneven surfaces. Reported it on my 1000 pms but Diamond motors say it's normal which is weird. Any news on where to go for this?
    Had the same issue from the day my 2017 GT was released from CT Citimotors Makati. Thud appears when the car’s body rolls from side to side on uneven surfaces. Had it checked on my 1000km PMS. They explained the sound was coming from the design of the steering column due to the Montero’s telescopic steering feature. Service attendant mentioned about the type of lubricant used on the steering column tends to dry out, hence, the knocking sound.
    Lo and behold thud disappeared after the service. They did re lubed and tighten some bolts as I was told. No knocking sound since then. Hope this helps!
    Aug 2018
    #112
    Same issue po, Ang sabi sa akin ng SA ng mitsu ay papalitam ung buong steeringcolumn, tama ba yun? Thank you
    Mar 2019
    #113
    Quote Originally Posted by Jojo04 View Post
    If it's the SA who insists on replacing it to new, then why not as long as you won't break your wallet and the job is under warranty. Unless lubing and tightening won't work, replacement might be the better idea.
    #114
    strange that the same symptom is managed differently by the casas...
    Sep 2014
    #115
    doc, wag ka muna magpapaniwala sa mga latest posts, tignan mo post number. nag-post lang para dyan sa steering issue
    lakas ng Montero Sport ngaun, top-selling
    Uu nga naman doc... mababasag diskarte sa pag bili ni mini ng monte... hehe..[emoji3577]
    Aug 2018
    #117
    Quote Originally Posted by Razoshift View Post
    Sirs, baka may alam kayo na gumagawa with regards to steering column aside sa casa or san yung marerecommend nyo na casa para dito...
    thank you
    thank you
    zix performance on fb...
    Aug 2018
    #119
    Thanks sir.. 🙂
    Jan 2019
    #120
    Hi fellow Montero owners, I have been encountering a misalignment issue.
    I first noticed it a month ago. When I drive, the wheel inexplicably turns a bit towards right. I keep thinking maybe it's just my perception issue.
    But today, I just noticed that it is the whole steering column that's not aligned. Noticed it when I'm trying to change the height of the steering wheel.
    As you'll be able to see in the photos, when I try to adjust the steering wheel to the lowest possible position, you can clearly see that the right side is lower.
    Does anyone encounter this issue or is it just me?
    I'm trying to determine if it's normal or not.
    Thanks in advance.
2016 Montero Sport Steering Issue
