Page 63 of 135 FirstFirst ... 135359606162636465666773113 ... LastLast
Results 1,241 to 1,260 of 2693
    #1241
    Quote Originally Posted by kik0matsing View Post
    1. Ang alam ko wala.
    2. Sad to say walang warning light yan pero sa dashboard meron sya at hinde nga lang nagana(sa glsv meron d ko lang alam sa glx). Pero ung kay sir zixx napagana nya ung sa gtv nya. Although dapat meron talaga as part of a safety feature dapat pati kung may nakasakay sa passanger seat.
    3. Regarding sa autolock, mag autolock lang siya kapag nasa loob ka nang sasakyan, door closed at once inistart mo tsaka lang siya mag autolock. If naka open ung door tapos inistart mo you have lock it manually. Hinde siya nag autolock habang naandang tulad nang ibang sasakyan. Kahit ung adventure ss namin ganun din. . .
    Posted via Tsikot Mobile App
    As per Sir kik0matsing, walang alarm po once na naiwan yung susi sa off position, (ibang brand ng sasakyan ay merong buzzer/ajar warning), to remind the driver...may alarm man o wala po, a basic sense na once nababa ng sasakyan, remove the key automatically.
    Yun din, meron talagang indication sa monty ng seatbelt warning, pero naka-deactivate po ito, pero sa akin is no big-deal,
    once na nag-drive lalo kung nasa public road, automatic na buckle up for safety..
    Sa autolock, yun nga starting lang talaga mag-activate po yung autolock, once na binuksan, pag sara ulit ng pinto sa driver seat, deactivated na yung autolock, so kailangan i-manual lock, (yung old car namin is naka-feature na pag nakatakbo in a certain speed, activated ang autolock) medyo annoying, pero a good practice na rin, to aware na once na bumaba ng sasakyan, at bumalik ulit,
    basic instinct na dapat i-lock ang sasakyan before driving, (iwas sa technology dependent)
    #1242
    salamat sa reply mga sir, at least now I know na ganun pala talaga sya. This is my 3rd vehicle, the previous 2 were sedans and were all acquired as second hand pero may mga ganitong feature sya that is why I'm under the impression na standard dapat sya and considering that my MS is my 1st vehicle to be acquired as brand new, medyo odd lang na wala sa kanya yung mga ganitong feature. But it's ok, not a big deal naman. It's not being technology dependent, we're only humans hindi tayo perfect of course there will be times that these feature will be of great help for security and safety purposes.
    Thanks ulit mga sir
    Aug 2005
    #1243
    Quote Originally Posted by gtorres View Post
    hello mga sir,
    I have a GLX MT 2014, 2 months old palang. Ask ko lang and confirm kung ganito talaga yung sa GLX MT
    1.) Walang warning sound kapag patay na ang engine tapos binuksan mo yung pinto then naka suksok pa yung susi. Hindi ba dapat may warning sound ka maririnig para i-remind ka na naka suksok pa yung susi? or wala talaga sa GLX?
    2.) Wala po ba talagang seatbelt light/reminder sa dashboard? Kahit di ako naka seat belt while tumatakbo walang seat belt warning light ako na nakikita sa dashboard. Kahit during bago ko i-start ang engine wala po.
    3.) Yung autolock, sa driver side lang talaga sya? Hindi po sya nag a-autolock kapag tumatakbo na tapos tinapakan ko yung break pedal. Kailangan ko talaga sya i-lock sa driver side manually. Ganito po ba talaga ang stock ng MS or sa GLX po ito?
    Thanks in advance mga sir.
    1) Unfortunately, wala itong feature na ito sa GLX MT non-VGT (kahit sa GLX-V Limited M/T wala din) and we have to live with it. Unlike sa ibang vehicles (like the wifey's Vios 1.3G) meron nito, an audible alarm (beep) can be heard when you open door from inside while the key is still inserted.
    2) Wala ring seatbelt indicator sa instrument panel when the seat belt is not engaged to the driver or even sa passenger side. My wifey's Vios has this. Although the alarm won't sound, but after a couple minutes on the run, it will eventually activate. The only thing the MS GLX has is the door ajar indicator light and the alarm will activate after you have run on a distance from where you started when the door was ajar. Another thing, when you leave your car with the park lights on and the key is disengaged from the ignition, an alarm will sound as well.
    3) About the autolock, it will only engage when you step inside your car, all door closed, and key inserted and turned to ignition point. Otherwise you have to manually lock it. What I wished was there should have been a manual switch to either lock or unlock it from the inside. The weird this is, the alarm will sound if you close all doors, and lock it from the inside manually.
    #1244
    na drive ko sa Ilocos yung 2014 ford everest 4x4 nung tuesday as service and it doesn't have above features as well, pero parang sedan ang gaan ng manibela nya compare sa monty natin.
    #1245
    Quote Originally Posted by leinahtan View Post
    wow, thank you sir very informative sakin yung number 2. My last car was also a vios, a 2004 model and it has these features I'm asking that's why nag tataka talaga ko bakit wala sa MS pero ganun pala talaga.
    Apr 2012
    #1246
    Quote Originally Posted by vickoy1228 View Post
    talagang mabigat ang manibela ng Montero sir, sanayan na lang din...
    #1247
    hahaha oo nga sir pero ok lang naman sakin, nagulat lang kasi ako kasi ang gaan ng ford everest considering magkakasinlaki lang gulong nila
    Jun 2013
    #1248
    baka electric steering na ford everest sir?
    #1249
    Quote Originally Posted by lazza View Post
    not sure sir, pero yung satin minsan parang hawig sa pawis steering hehehe though kayang kaya naman
    #1250
    sakin wala naman reklamo si misis, considering na 22s pa siya on 285 45 tires.
    ang reklamo lang niya pag na-i-off ko yung throttle controller before niya gamitin, para daw stuck-up ang preno , hehehe
    Jul 2012
    #1251
    Kong mapalitan ang drive pulley ng steering pump to smaller diameter we can improve the pawis steering, kaya kaya Master Zix?
    Jun 2012
    #1252
    Quote Originally Posted by mangkas1178 View Post
    pila ako pag kaya mo sir zix
    Feb 2014
    #1253
    Basta ako ok lang sakin manibela nang monty. Mag iiba lang talaga ung feeling mo pag naka kotse ka lagi kaya ung sa iba nabibigatan sa manubela.
    Nov 2013
    #1254
    mabigat talaga steering, nanakit nga yung likod ko nung una hehe, tapos nasanay na din, increase tire pressure na lang ng konti sa harap laki na din ng ginaan..
    Jul 2014
    #1255
    One of my top choices. Wait and see muna ako mga sir later this year dahil mag uupgrade daw lahat ng suvs
    Feb 2007
    #1256
    ^and then next upgrade uli, then another upgrade- eventually you'll miss the times na na-enjoy nyo na sana with your should have been beloved Montero Sport! :D
    Sent from my Nokia5110i-VgT using Tsikot Forums
    Aug 2005
    #1257
    ako sa 2030 na siguro ulit bibili ng bagong montero. By that time lahat ng upgrades nandoon na.
    Jul 2010
    #1258
    Ako rin po sir by that time na rin po bibili ulit ng montero. Sana may anti-gravity na sya. Para kahit saan pede idaan(100 meters up of water depth specially) o kaya lumilipad na ang montero!hehe...😁
    Jul 2012
    #1259
    Quote Originally Posted by H3JRVILLAMOR View Post
    By that time ugod ugod na c mangkas, wheel chair nalang ko.
    Aug 2005
    #1260
    Kasama na sa freebies ng mitsu yun wheelchair when time comes he he. Ok peeps back to topic na tayo.
2014 mitsubishi montero
