Page 43 of 135 FirstFirst ... 333940414243444546475393 ... LastLast
Results 841 to 860 of 2693
    Dec 2010
    #841
    Thanks for all the replies. Really appreciated. Mga boss may marerecommend ba kayong casa na pwede magdala ng sariling oil? Pero di mavvoid warranty. May nabasa ako na pwede magdala. Nalimutan ko lang kung san hehee thanks!
    Posted via Tsikot Mobile App
    #842
    Quote Originally Posted by abramos View Post
    Pano po ba ang tamang break in? Sabi ni sir zixx biritin at batakin tlga sa highway. Yung iba naman i-baby daw ang engine at wag over rev. Any comments guys? Hehe
    Sir abramos
    Hataw agad, high speed run as possible, wag i-stay sa certain speed...
    avoid ang hard-launch, and over-rev,
    saka important to idle first the engine during warm up, para hindi ma-pwersa ang makina...(to circulate the engine oil and stabilized, and yung fuel/air mixture ay maging balance
    after warm up, kahit itakbo agad ng 120KMS....no problem
    congrats sir sa new ride! enjoy!
    Dec 2010
    #843
    Quote Originally Posted by playplugg View Post
    Sir abramos
    What do you mean by not over-revving? Hehehe kanina kasi sir may taxi na napakabagal sa harap ko. Naka 2nd gear ako tpos tinapakan ko silinyador umabot halos 3.8krpm. Na over rev ko ata si monty i think what you mean by over-revving is red lining hehhe(for peace of mind lang) whaha
    Feb 2014
    #844
    Basta huwag mo ibababad na mataaa rpm, ilipat mo agad sa mataas na gear. Hinde naman taxi or jeep yan, heheh tsaka dinig mo naman sa makina yan once over rev ka.
    Feb 2014
    #845
    Tsaka add ko pala, sakin ha hinde na ako tumitingin sa rpm nang dashboard ramdam mo naman kung need mag downshift at upshift ka. . .
    #846
    exactly sir, redline. para iwas early wear and tear sa makina and prolonged engine life.
    Apr 2014
    #847
    Chief abramos, ang shifting ko sa akin kapag within 2K-2.5k rpm sa 2nd,3rd & 4th gear, pero ang na notice ko kpag nasa 4th gear na, aabot ako hanggang 3K rpm before mag shift to 5th gear kasi ang feel ko sa engine, malata pa masyado kapag nag early shift ako to 5th gear.
    Parang yung 4th gear ng montero high speed gear na. Tama ba ang analysis ko mga expert tsikoters?
    Dec 2010
    #848
    Quote Originally Posted by miggymontero View Post
    Yes sir ganun nga po shifting ko. 2-3k lang. Pero kanina kasi nainis talaga ko sa taxi driver, open highway kasi sir pero 20km/hr lang ata takbo. Kaya medyo napa sprint si monty. Mula 20km/hr naging 70km/hr in 2nd gear hehe
    #849
    Sir miggymontero,
    best rpm na po ang 2000-2500RPM for shifting, (2nd-3rd-4th) going to 5th, at least nasa 80KPH above, pwede na, kasi sa 100KPH, nasa 2000RPM kung nasa 5th, lagpas 2K naman kung sa 4th, near 120 na kayo kasi ang max speed ng 4th is 135KPH..
    ok lang po yan sir abramos,
    di talaga maiiwasan mag-overtake lalo kung yung nasa harap nyo ay patulog tulog, or busy sa paghawak ng cp habang nagmamaneho...
    nangyari na rin po sa akin, yung araw mismo na kinuha namin yung unit, umabot sa 4000RPM in first gear, para makapag-break away sa traffic....
    Apr 2014
    #850
    Sir miggymontero,
    Chief playplugg, kapag naka 5th gear na, anu dapat yun max rpm na safe sa engine? Before lang ba mag redline?
    #851
    mga sir anu po b pwedeng i panglinis sa interior at engine ng monty?
    #852
    Sir miggymontero,
    as long as na hindi redline, safe naman ang operations ng engine, yun lang, the higher the RPM, mas malakas na syempre yung consumption ng fuel, saka kahit mag-top speed ang monty, hindi naman aabot ng redline..(not unless kung heavily modified)
    at least mga 2300RPM for cruising speed (120KPH* 5th) no problem yan... pero pasok lang nga sa severe usage, (change oil every 5000KMS) kung 100KPH naman * 2000RPM, fuel efficient at nasa normal usage (every 10,000kms change oil)
    depende sa driving style, kung economical type ba or performance driving...hehehe
    Pag VGT kasi, ramdam talaga ang turbo lag sa low gear, kung sa high gear naman, kung ipapasok sa 5th gear at 60KPH, nasa 1100RPM lang, ramdam ang lag, kailangan pag nasa 5th gear dapat ang takbo is around 85KPH above,
    pag dating ng 85KPH, kaya na ng 5th gear accelerate ng 100KPH in a short period.
    kung sa non-VGT, kaya na mag-5th sa 60KPH.....and problem lang sa non-vgt, from 80 to 100kph, medyo delay lang yung acceleration dahil sa lag, para iwas sa lag, paabutin talaga ng at least 100KPH sa 4th before shift sa 5th para ramdam yung acceleration.
    Apr 2012
    #853
    Quote Originally Posted by newbie2014 View Post
    sa interior at engine, punas punas lang. pwede din yung gaya ng armour all protectant na pwede sa leather, plastics, rubber. check mo sa diy shop o ace, meron mga pang interior at dressing ng engine. if you want a clean engine na parang bago, pwede ka magpa-engine wash at engine detail o DIY mo kung marunong ka ;)
    Sir miggymontero,
    Pag VGT kasi, ramdam talaga ang turbo lag sa low gear...
    hmmn, di naman sir, baka you mean sa low rpm. between 1800-2000rpm kasi palo ng boost ng vgt turbo. kapag naka sportronic o manual mode, kapag nasa lowest gear like 1 (o primera) sumisibat naman siya kada apak ng silinyador. kung nasa matic ka at naka D, pagarangkada mo naka 2nd gear siya kaya parang mabagal response. to lessen or eliminate the lag, invest sa throttle controller, you will be very happy sa response ng rig mo.
    Jan 2010
    #854
    Hi! I've been looking for a 7 seater SUV for the family and the Montero is on my list. Although, minsan lang naman yung need for 7 seats it's good na at least pag kailangan meron na. My daily mileage is very low around 10 Km and right now my current car is 4 yrs but with 17K Km only on the odometer. Would you still recommend the diesel variant or you think the gas variant is a better option over-all? thanks!
    Jun 2010
    #855
    Go for the gas variant since 10km lang naman yung biyahe mo. Iwas problema sa usok din.
    Quote Originally Posted by DAMaster View Post
    Jan 2010
    #856
    Quote Originally Posted by karag-karag View Post
    thanks! actually ang impression ko mas maraming kailangan i-maintain pag diesel na turbo like yung EGR, etc.. and parang di ko rin ma take advantage yung murang diesel kasi ang baba ng mileage ko.
    In GLS variant, pareho lang naman features ni diesel and gas right?
    Jun 2010
    #857
    Yup, same lang yung features nun. Okay pa gas kasi hindi maingay. Actually medyo malakas din sa consumption ko sa GLS-V pag sobrang traffic, nasa 6.5km/l lang ako kasi makati traffic.
    #858
    sir monty_GTV, MT po yung amin, yung lag, experienced kung early shift in low speed, kung dadaan sa humps, from 2nd gear, kailangan pa ibaba ulit sa 1st gear, unlike sa non-vgt, kahit hindi na ibaba sa 1st gear, kaya na tumakbo,
    to compensate it, medyo mabigat lang ang application sa gas pedal, from 1st, to 2nd, then sa 3rd gear, basta sufficient na ang speed, walang lag, 4th and 5th, kahit mababa na yung RPM, smooth acceleration na,
    not sure sa AT, never pa ako nakapag-drive ng AT for monty/strada
    Sir DAMaster
    kung daily usage, mas preferred ang diesel, kung talagang bihira naman gamitin, gas variant, yun lang V6, pero hindi complicated ang maintenance unlike sa diesel, medyo sensitive, ok din ang diesel dahil sa FC, basta tamang alaga lang po sa maintenance, hindi naman basta-basta masisira,
    yung recent car namin is 10yrs old na and for 70,000KMS PMS, 16KMS ang distance driving and once a week lang ginagamit, nadadagan lang ng extra KMS dahil sa mga business appointment or deliveries ng docs, kaya kumuha rin kami ng monty for upgrade and business purposes, and diesel ang kinuha namin, para sa mga appointment sa malalayong lugar..
    mas fuel efficient kasi ang monty pag dating sa long distance...
    since sa inyo po is 17K KMS sa recent car, and average kayo ng 5000KMS a year,
    at least makapag-change oil once a year, hindi na masisira yung sasakyan,
    lalo na kung low mileage....kung dalawang sasakyan, 2500KMS ang takbo ng bawat isa....medyo challenging kung paano paabutin ng mataas na KMS...hehehe
    sir karag-karag, mataas na po yung FC nyo kung sa makati traffic, MT po ba sa inyo or AT?!
    MT po sa amin, nasa 5.5KM/L ang FC ko lalo sa buendia area...at oras na ng rush hour, di maiwasan ang gitgitan kaya kailangan medyo arangkada lagi...hehehe
    Jun 2010
    #859
    Boss *playplugg AT yung amin. Sobrang baba naman nyan, mukhang grabeng arangkada yan ha. haha.
    Jan 2010
    #860
    Sir DAMaster
    Sir playplugg and karag-karag salamat sa mga inputs. ako din byahe ko daily manda<->makati kaya traffic talaga. I guess better option for me yung gas variant kasi ayaw ko din yung medyo complicated na maintenance unlike sa gas medyo kabisado ko na yung maintenance. Sa long drive siguro naman makaka atleast 10-12 Km/L naman ako sa gas variant. What do you think? thanks!
2014 mitsubishi montero
