Page 45 of 135 FirstFirst ... 354142434445464748495595 ... LastLast
Results 881 to 900 of 2693
    #881
    Quote Originally Posted by boytsiks View Post
    Nangyayari sa kin yan once in a while. May reset button yung HU natin. No need to re-start the engine. Back read ka na lang sir somewhere in the montero threads (2013 - 2014) nabanggit yung reset button na yan.
    Napansin ko lang, nangyayari lang sya once medyo sunod sunod pag pipindot sa HU (example palit song sa ipod, then activate gps than search songs again). Parang naghahang sya.
    Not really sure about the 2014 units, sa 2013 kasi wala ng battery yung steering controls ng HU.
    HTH
    Aaah yes. Yung maliit na bilog ata yung reset. Yup. True. Minsan habang umaatras ako, i oon ko radio then pindot pindot dun naghahang or nagkaka problem. Basta yung sunud sunod nga na pindot. I just take my time ngayon. Masyado ko kasi nasestress yung head unit e hehe . Nothing major naman kaya its not really a biggie
    Posted via Tsikot Mobile App
    Got Mazda?-http://www.MAZDAtech.org [SIZE="1"]est. 2000[/SIZE]
    got mazda 2? -> mazda2ners
    Jan 2014
    #882
    Quote Originally Posted by LLOY View Post
    Opo sir, may leak po siya. Na pansin ko po nung na flat ako at inalis ko yung gulong and yes, medyo bouncy na ang ride compared nung una. Stock parin po ang gulong ko never pa po ako nakapagkabit ng mags. Ok lang po ba ito dalhin agad sa casa without any reasons kung bakit nag leak? Di naman po ako nag off road, pure city/highway driving lang po.
    Posted via Ay****
    Sir yun monty ko is just 3months old, nagkaroon din leak yun shock sa front right side. Bought it to casa to check, without any questions asked pinalitan yun shock. Mga 4days after pa dahil sa availability ng parts.
    Sep 2013
    #883
    same situation here, brought my rig (4,300 in odometer) to diamond motors q.a. for checking due to ticking sound on rear side, when they found out that the rear right shock has leak they just replaced it w/o any questions. I hoped they replaced both rear shocks hehe...
    Quote Originally Posted by Saki View Post
    #884
    Quote Originally Posted by Reybeck View Post
    Try mong i turn off ang HU erwinlf. Pindutin mo ang volume control ng mga 5sec. And turn it on again. Works for me.
    Sir Reybeck, ask ko po kung i-hold ko po yung volume switch, will fully turn off the HU?! and same procedure po rin ba to turn it on again?!
    para before starting the engine, need to turn off the HU(MMID), para less load sa battery during start up and prolonged the life of the HU,
    Quote Originally Posted by caloyski5 View Post
    Salamat bro errr whats mmid ba?
    The HU....
    Sir Saki, glad to hear na pinalitan na yung shocks, sa soft ride kasi ng monty, minsan yung lubak hindi ramdam, may time na napasobra yung takbo ko at dumaan sa medyo mataas na humps, ramdam ko pero parang dumaan lang sa maliit na lubak...
    will inspect my monty pag nakauwi ako..
    BTW: yung common signs po ba ng shocks leak ay yung merong oil na lumalabas?! or ramdam na during driving?!
    Feb 2007
    #885
    Recent models does not have SW mounted battery anymore, don't know if it depends on models.
    MMID-Multi Media Information Display or just simply MID.
    Mitsubishi manual says its MMCS-Mitsubishi Multi-Communication System.
    Sent from my Nokia5110i-VgT using Tsikot Forums
    #886
    Sir prince777,
    Not sure if we have the same reference, the 2010 download version and sa website (2011)
    although sa thailand built yung majority ng monty sa pinas.
    sa global po ba ang reference?! or sa australia? (except sa russia kasi nasa 220 ang speedometer ang label)
    or meron mismo sa philippines?!
    Feb 2007
    #887
    Sir PP, indicated naman sa 2010 manual kung para saan bansa yung model, same as sa online manual. Kaya lang, dahil sa upgrades, other parts from specific models in other countries are being used as upgrades pa sa models natin.
    If you are referring to SW remote battery, i guess nag start in some 2012 models na wired na yung controls.
    Base sa pagkakaintindi ko sir MID is yung display sa taas at ang HU is yung nasa baba kung saan may lagayan ng CD o magplay-play ng CD.
    :D
    Dec 2010
    #888
    Anyone know how to install a gtv spoiler? Got one from hektorsky. And i dont know how to mount the clips. And if i should add silicone? Or clips are enough? This is what the spoiler looks like. But i got it unpainted for 2,500(resin color). Pretty sure its the same thing that casa sells for 9,000 they just wrapped it with cf stickos and then kaboom OEM price imageuploadedbytsikot-forums1399738809.668457.jpg
    Feb 2013
    #889
    [QUOTE=playplugg;2349273]Sir Reybeck, ask ko po kung i-hold ko po yung volume switch, will fully turn off the HU?! and same procedure po rin ba to turn it on again?!
    The HU....
    Yes sir, same procedure lang po.
    Aug 2005
    #890
    Quote Originally Posted by abramos View Post
    I had mine installed pero tinanggal ko rin kasi tumatama yung edge ng spoiler dun sa edge ng roof panel pag binuksan fully yung tailgate. Pag install nito, wrap mo muna ng 1 layer ng electric tape yung dalawang hook support that comes with the spoiler to prevent/avoid your monty's body paint from any scratches. Then hook them up on the top edge of the tailgate. Yung span distance between the hooks will depend on the span of spoiler holes where the hooks with protruding bolts will be secured. I-shoot mo yung protruding bolts ng hooks dun sa holes ng spoiler then secure it with nuts using a socket wrench. Then cover the holes with the cut circle chips that comes with the spoiler. Open your tailgate fully to access the hooks inside then secure it with mechanical screws which also comes with the spoiler package. Kung meron kang scrap rubbers (bike interiors or similar), cut 2 rectangles to size and insert it between the hook and the tailgate then secure the hooks as mentioned with the mechanical screws. This will prevent your tailgate finish from any dents or scratches when you tighten the mech screws. I suggest too to apply a 3m molding tape (cut to shape) on the center and ends of the spoiler that will sit on top of the tailgate panel to secure it firmly with the tailgate. For me, I won't need a silicone since there is nothing to seal it from water sippage. Plus the effort of silicone application and clean-up is a pain to do. Hope this helps.
    Jan 2014
    #891
    Quote Originally Posted by JOHN3:16 View Post
    I bought and claim the warranty at Diamond Motors too, at Greenhills Branch, mine has 4,700+km reading in odometer.
    Jan 2014
    #892
    Quote Originally Posted by playplugg View Post
    Based on my experience usually the oil leak is the most common symptom (visual), it bounces much at early stage, and thud sound while running when it worsened. With my monty I didn't feel the bounce first, nakita ko muna yun leak, then I realized di nga normal yun bounce nya.
    Apr 2014
    #893
    Hi, just asking ano yung switch in between the cigarette lighter port and USB port sa Montero Sport GLX 2014?
    Dec 2010
    #894
    Quote Originally Posted by leinahtan View Post
    Very well said! Two thumbs up. 👍👍
    Jan 2010
    #895
    sir DAMaster,
    for sure, alam nyo naman yung shortcut sa manda/makati, and yung mga isolated area na sobrang trapik...hehe
    ok na ang gas variant, maliban sa less maintenance, walang turbo lag, smooth ang acceleration, ang certain disadvantage ng gas variant, yung resale value later on....mababa ang appraisal, unlike sa diesel, mataas ang appraisal,
    kung long drive, di ko po sure kung ilang ang actual FC ng gas, possible, pasok na yan sa 10-12KM/L,
    yun lang, pag hinataw ang V6 engine, hataw rin ang FC, hehe
    sa diesel, 12-15KM/L, ang FC pag highway driving,
    not sure po kung meron mga owners dito ng V6 version...if ever na meron man, sana ma-share nila yung FC ng V6.
    sir playplugg salamat sa reply and info! sa mga kasama natin na naka gas variant, please share your experience sa maintenance and FC please. thx!
    #896
    Guys any news kung magtatagal pa for a couple of years ang current gen Motero? My current vehicle is a 2008 2.7 Gas ng Toyota Fort but planning to shift into diesel Montero Gls V. In a few days makukuha ko na yung unit but still seeking last minute advice on to getting it or not. Even in 2008 when I purchased the Fort my first choice was really Montero but during that time wala pang 4x2 variant that's why i ended up getting the fort. There are some rumors and news about the launch of the nxt gen challenger and triton. They said triton will be launched a year ahead then come japanese piscal year 2016 lalabas daw ang challenger. Should I trust that news or stay sceptical. Granted ma-launch ang next gen montero by 2016 as stated sa news iniisip ko baka 4x4 lang muna ang available and need to wait some more months for the 4x2. If that's the case then from my counting mukhang aabot ng 2 or more years ang hihintayin ko for that total new look of Montero. Any advice? Go ba or wait ako. Thanks in advance!
    #897
    Quote Originally Posted by justin_ View Post
    hello mga sir. planning to buy a montero this year. which variant do you recommend, glx or gls? out of budget na kasi yung gls-v 4x2 eh. i'm considering the glx because it's a diesel, but the toys of the gls, which are similar to the ones in the gls-v, are also enticing. how's does a gas monty fare in terms of fuel efficiency? is the gls worth getting simply because of the toys, never mind the gas engine? if ever, this will be the first time for us to own a diesel suv. previous cars were lancer itlog and civic fd. thanks mga sir.
    I was also thinking of getting the GLS V Gas ng monty the one with the V6 engine prefer ko talaga is gas since my current unit is a toyota fort gas pero i've decided na lang to get the gls v diesel instead. My reason is the re-sale value. Mukhang kaunti lang ang prefer ang gas para sa SUV, one indication of that came from the dealer mismo, sabi nila bihira ang kumukuha ng gas variants tha's why wala silang stock nyan sa casa per order basis pa.
    #898
    sir ask lang anyone po d2 na nakapagpakabit na ng hoodguard sa montero 2014.saan po at how much?
    Jan 2014
    #899
    Quote Originally Posted by iceman777 View Post
    mga sir anybody interested sa tailgate net pm me. thanks!
    http://i1267.photobucket.com/albums/...ps50d988a0.jpg
    Sir, how much?
    Apr 2014
    #900
    Ako din chief iceman, interested ako, pa-PM po yun price
2014 mitsubishi montero
