Normally Inav announces whenever updates are available from their website. You will just need to back up your sd card and download the new file.
sir wing tanung ko lang anu ung site ng INAV para maupdate?
FYI, There's already new update for GPS software version, just updated mine when i visited Diamond Greenhills for repair last tuesday.
sir saki anung version na po ung GPS nyo?
normal po talaga yan sir newbie2014,
1. not only the cabon deposit galing sa exhaust, pati na rin ang "carbon monoxide at fumes" galing sa exhaust,
kaya iwasan tumambay sa exhaust area....
2. it means yung engine ECU and the fuel injector amount control, properly functioning..kaya normal yun experience ng delay..
ang engine ECU ay merong sensors kung gaano yung application ng tapak sa accelerator pedal at dun sa compensation timing at control ng fuel injection...ayon din po sa magazine na nabasa ko...
ano po ba yung transmission ng GLS-V unit nyo po?! the AT po ba or the MT?!
same model variant po tayo pero sa amin is the MT version,
pero ang pahabol po doon sa magazine, merong drive train system protection control ang MT. (4WD)
control ni ECU is fuel injection amount para di lumagpas sa 3000RPM..
first and reverse gear, kung na 4LLc position
kung less than 5kms/or less ang takbo..
sir plugplayy gls-v 4x2 at po ung unit ko
Di ko na check personally, but according to the accessoeries person at diamond motors it was 2.5, now it's 3
sir may charge po b pa update ng GPS?how much po?btw kelan po b narelease unit m?sakin kasi last april 11 lang.
Sa pagkakaalam ko wala.
I just update mine by myself. Just to inav.ph, punta ka lang sa new updates, then choose OEM - factories installed.
I'm not sure kung meron ng specific update for 2014 Montero. Mine is 2013 so andun sya sa choices. I'm guessing that 2013 and 2014 have the same HU.
HTH
ask ko lang po.ung 2014 gps b nang montero ay knav na at hindi na sya inav?kasi ung samin po knav sya at hindi inav.ngaun ko lang po na notice.anyone po na ganito din ung unit nila?
mga sir tanong ko lang kung panong mag back up ng copy ng inav bago ko i update ang gps sd card ko...cheers
Hello, may naka encounter naba dito everytime na sa unang andar ko may natunog sa ilalim ng engine na parang nag aadjust or mag nag eengage? Pero pag naka andar na wala na. Pero pag nag park ako mga 10-15min tpos andar ulit same tunog ulit.
1month old ms at
you can only hear egr ticking sound 8-10sec after engine shut down
monty egr valve - YouTube
ask lang mga sir ung gls-v 4x2 at ba pwedeng palagyan ng headlamp washer?
Pano po ba ang tamang break in? Sabi ni sir zixx biritin at batakin tlga sa highway. Yung iba naman i-baby daw ang engine at wag over rev. Any comments guys? Hehe
Posted via Tsikot Mobile App
Uu agree ako dyan, kase para malaman mo din ung mga dapat iadsjust sa transmission pag nagpms ka sa 1k, sample lang ung adventure namen date sa nlex nasa 120kph parang naghihinge pa nang 6th gear pero nung binanggit ko un nung pms sa 1k ayun swabe na cya sa rektahan. . . Try mo ihataw ung takbo nya once in a while pero ingat ingat din...
Hopefully bukas or within this week marelease na din ung monthy namin, exited na cla. . .
