Results 981 to 990 of 2693
June 6th, 2014 09:55 AM #981
- May 2014
- 49
June 6th, 2014 10:23 AM #982
- May 2014
- 49
June 6th, 2014 10:43 AM #983Now, I'm confused. According to Mitsubishi di na daw kailangan break-in kasi ginagawa na raw sa factory. They said, don't carry heavy loads and don't push it too hard. May nakalagay naman sa manual about running-in (Break-in), not recommended daw yung short distances and heavy loads. I travel from Malabon to Mandaluyong which is around 22km-24km depending on which route I take so I was thinking malayo layo na rin yung byahe ko.
If indeed I need to break-in my monty what is the top speed and distance I should travel?
- Jun 2014
- 2
June 6th, 2014 10:52 AM #984Hi! First time buyer here! still looking for the best offer for MS. I'm not sure if it's more practical or we cud save more if we'll buy the unit in manila. we're from bacolod. any suggestion? have actually inquired here in bacolod . their DP is 165k, monthly is around 25k for 5years. that's under psbank. is this offer reasonable? Thanks!
- Jun 2014
- 2
June 6th, 2014 01:57 PM #985Hi Sir! i got almost the same quotation as that of obssessed. i'm hoping i cud get a better offer. can I ask for your SA's contact number sir? thank you.
- Nov 2013
- 109
June 6th, 2014 02:12 PM #986uy! bossing same route tayo hehe, no need to break-in na talaga kasi ginawa na sa planta yan,
ina agahan ko alis sa umaga para maka hataw man lang sa roxas, so far less than 4k pa lang tinakbo ng monty,
yung break-in kasi kunwari bago overhaul makina palit ng piston rings, valve springs, etc. recommended ng mga mechanics wag muna lalagpas sa 80kph ang takbo for first 1000km, para dahan dahan lumapat lahat nung rings at valve seats, tapos nun, pag walang nag usok, pde na hataw.
- Nov 2013
- 109
June 6th, 2014 02:39 PM #987actually this is my first diesel, lahat nang sasakyan namin gasoline, nung unang labas civic FD sabi ng SA 1800 makina pero 1600 lang daw consumption, so kuha ko, na salestalk kasi meron ako civic dimension na AT , potek ang lakas sa gas, after 2 and half years binenta ko din at palit jazz AT na 1500 ayun matipid, 9km/liter na, pero eto monty AT, nakaka 8.5km/liter lang (nilagyan ko kasi TC at crdi chips) pero malayo difference sa laki at sa liksi nya, so matipid talaga diesel, bukod sa mas mura per liter..
June 6th, 2014 05:30 PM #988
Pero yung oil nyan from factory sa thailand is for break-in talaga need to change oil talaga sa 1000 PMS. Haist sa kabila remapping ng ECU uso no need na ng chip. Galing!
- May 2014
- 49
June 6th, 2014 06:39 PM #989
- May 2014
- 49
June 6th, 2014 06:42 PM #990
Turbo timer yung feature na yan sa Everest? Sana default feature yan sa mga naka turbo na sasakyan.
0dometer problem
