Page 101 of 135 FirstFirst ... 5191979899100101102103104105111 ... LastLast
Results 2,001 to 2,020 of 2693
    #2001
    Quote Originally Posted by the_mechanic View Post
    hi sir harold13. Montero's optitron (gauge appearence), lights are off even naka start na yun engine, unlike other cars na kapag nag-on, illuminated na agad yun gauge mo. On montero's case nagagawan na ng paraan para well-lit na agad yun gauge, which normally done by the master himself, sir zixx. (correct me if im wrong sir zixx)
    +1 sir the_mechanic
    #2002
    my TV stop working hope lost connection lang sasabay ko na lang pa check sa 5k PMS ko, puede kaya itrade in yun para palit ako ng skytv, bossing zixx pm mo naman ako price? tia
    Dec 2009
    #2003
    guys help naman, san located transmission ECU at OBD port ng montero?
    Jan 2009
    #2004
    Quote Originally Posted by miko101130 View Post
    yung obd port try mo dito
    Driver's side, underneath dasboard,between the driver-side door and steering column area.
    Jan 2009
    #2005
    yung transmission ecu baka nandito, PM mo din si zix888 alam nya
    Jan 2009
    #2006
    eto picture
    Jan 2009
    #2007
    AUTOMATIC TRANSMISSION - Transfer-ECU
    Dec 2009
    #2008
    Quote Originally Posted by smuiv View Post
    yellow yung connector nyan module na nandyan. dalawang set ng molex connector.
    kung yan ang ECU ng transmission, nasan ang sa airbag module?
    Jan 2009
    #2009
    tignan ko sir kung may diagram hehe
    Jan 2009
    #2010
    eto lang nakita ko sir puede mo rin PM si zix888 kabisado nya yun
    Montero, Montero Sport
    APPLICATION
    TRANSMISSION APPLICATION
    Montero Sport 2WD ............................................ R4AW3
    Montero & Montero Sport 4WD .................................. V4AW3
    CAUTION: Vehicle is equipped with Supplemental Restraint System (SRS).
    When servicing vehicle, use care to avoid accidental air bag
    deployment. SRS-related components are located in steering
    column, center console, instrument panel and lower panel on
    instrument panel. DO NOT use electrical test equipment on
    these circuits. If necessary, deactivate SRS before servicing
    components. See AIR BAG SERVICING article in APPLICATIONS &
    IDENTIFICATION.
    DESCRIPTION
    Automatic transmission is a 4-speed electronically controlled
    transmission. Solenoids that control shift changes are located in
    valve body. Solenoids are controlled by a Transmission Control Module
    (TCM). TCM receives information from various input devices and uses
    this information to control shift solenoids for transmission shifting
    and lock-up solenoid for torque converter lock-up.
    An Overdrive (OD) switch is mounted on the shift lever. When
    OD switch is depressed to ON position, transmission will shift into
    4th gear when shift lever is in "D" position, and OD OFF light on
    instrument panel will go off. When OD switch is released to OFF
    position, transmission will shift into 3rd gear, and OD OFF light on
    instrument panel will illuminate.
    A pattern select switch is located near shift lever on center
    console. Pattern select switch contains a NORMAL and a HOLD operating
    position. When pattern select switch is depressed (HOLD position) with
    shift lever in Drive position, transmission starts in 2nd gear.
    Upshifts and downshifts will occur at a higher vehicle speed than with
    switch in NORMAL position. See MITSUBISHI R4AW3 & V4AW3 OVERHAUL
    article. Indicator light on instrument panel indicates pattern select
    switch is in HOLD position.
    Transmission is equipped with a shift lock and key interlock
    system. Shift lock system prevents shift lever from being moved from
    Park unless brake pedal is depressed. Key interlock system prevents
    ignition key from being moved from ACC to LOCK position on ignition
    switch unless shift lever is in Park. See MITSUBISHI SHIFT LOCK
    SYSTEMS article.
    Sep 2013
    #2011
    Question lng po about HU ng gtv.... nasaan po kaya yung rca out put ng HU? Meron ba ito front, rear and sub rca?
    #2012
    Hi,
    Mga sir magandang gabi itatanong ko po sana kase nagpplano po akong bumili ng sasakyan by April 2015 ang choice ko lang po talaga is either Toyota Fortuner or Mitsubishi Montero Sport. I never drive po kasi para sa mag-ina ko na gagamitin nila pag hatid at sundo sa school and gusto ko lang po itanong kasi i have no time to back read as i have working offshore pwede po ba kung may makakatulong sa akin na anu po ang Pros and Cons to between the two and last question is lagi ko kasing naririnig sa mother ko na pag automatic daw e mahirap kapag nasira or pangit daw ang automatic but i prefer po kasi AT sana kasi wife ko mag ddrive and newbie palang sya mag ddrive in case makabili na kami baka kukuha ako driver for 1 year para matuto sya at mahasa mag maneho... I hope anyone can help me here.. or i can talk thru email kung pupwede sana.. masyado limited po kasi ang connection ko dito...
    Maraming Salamat...
    Jan 2009
    #2013
    Quote Originally Posted by Noel Lanario View Post
    Hi,
    Maraming Salamat...
    Kung wife mo at new driver, AT para madalian sya. Considered Fortuner din, main reason napunta sa Montero yung sa visibility sa pag drive sa fortuner hirap ako kasi parang mababa seat maski adjust ko pa seat ng pataas hood nakiikita ko hirap itantya sa montero mas madali pati yung engine ng montero mas malakas. Resale value mas maganda fortuner pero ok naman din si montero.
    Jan 2009
    #2014
    Quote Originally Posted by Gabriel_Lorenzo View Post
    AVT yung HU
    Bili ka nito
    Rca Cable For Montero, Fortuner, Avt Oem Unit - Brand New For Sale Philippines - 63719611
    Kung gusto mo naman tanggalin HU mo
    Montero sport gtv - YouTube
    Dec 2009
    #2015
    guys pa share naman ng copy ng technical service manual ng montero, links? or sites?
    inaayos ko kasi yung montero ng uncle ko na nabaha, and its a pain to start with. thanks
    Sep 2014
    #2016
    Mga ka monty need HELP ask ko lng po meron bang naka experience dito na pag first open ng aircon may maasim na amoy tpos after 10 secs. Nawawala din? Mag 4 monts pa lng monty namin..thanks
    Jul 2012
    #2017
    Quote Originally Posted by babygemma View Post
    Sir try mo disinfectant spray "laysol" o "solbac" with bacteria, viruses, molds and mildew killer. Set blower to max. spray dash board suction port yong may fixed louver upper portion ng cold air discharge port on the far left and right. Yong sa likuran espray sa RH side na louver at sa RH side ng 3rd row sets yong lagayan above the ashtray holder o bottle holder, may opening yan. Next time let the blower ran for a few minutes after switching off the a/c compressor, the purpose is to remove any condensation on evaporator coils.
    Apr 2012
    #2018
    install a cabin air filter....
    #2019
    have this problem as well before and after basa basa, one of the suspected culprit is your car freshener, ayun tinanggal ko and the result is positive....wala na yung unpleasant smell.
    btw i have a cabin filter before magkaron ng smell
    #2020
    Hi,
    Maraming Salamat...
    i am no expert on subject and have no actual experience with Fortuner, i just relied reading the MS and Fortuner forums....after months of reading (jan 2014 kasi ako nag start mag plan to buy and i got the unit June 2014) i decided to go with MS GLX A/T, kasi MS ang angat sa net forumers. Medyo parang ang dyahe lang ngayun panay Montero na ang nasa daan When i am on the planning stage almost even pa ang nakikita ko sa daan, i have a game with my Son while driving, bilang sya ng Fortuner ako naman Montero and slightly lamang ang fortuner. Pero ngayun IMHO highly infested na ng MS ang daan and parking places, maybe 2 0r 3 is to 1 na. Again have no actual driving experience with Fortuner so my observation might be one sided so i don't know if it will aid you some help. It is my 6th car na ata, though first diesel and first a/t car....and i love it...
2014 mitsubishi montero
