Results 881 to 890 of 2693
May 10th, 2014 10:33 PM #881
Aaah yes. Yung maliit na bilog ata yung reset. Yup. True. Minsan habang umaatras ako, i oon ko radio then pindot pindot dun naghahang or nagkaka problem. Basta yung sunud sunod nga na pindot. I just take my time ngayon. Masyado ko kasi nasestress yung head unit e hehe . Nothing major naman kaya its not really a biggie
Posted via Tsikot Mobile App
May 10th, 2014 11:03 PM #882
May 10th, 2014 11:55 PM #883
same situation here, brought my rig (4,300 in odometer) to diamond motors q.a. for checking due to ticking sound on rear side, when they found out that the rear right shock has leak they just replaced it w/o any questions. I hoped they replaced both rear shocks hehe...
May 11th, 2014 12:00 AM #884
Sir Reybeck, ask ko po kung i-hold ko po yung volume switch, will fully turn off the HU?! and same procedure po rin ba to turn it on again?!
para before starting the engine, need to turn off the HU(MMID), para less load sa battery during start up and prolonged the life of the HU,
The HU....
Sir Saki, glad to hear na pinalitan na yung shocks, sa soft ride kasi ng monty, minsan yung lubak hindi ramdam, may time na napasobra yung takbo ko at dumaan sa medyo mataas na humps, ramdam ko pero parang dumaan lang sa maliit na lubak...
will inspect my monty pag nakauwi ako..
BTW: yung common signs po ba ng shocks leak ay yung merong oil na lumalabas?! or ramdam na during driving?!
May 11th, 2014 12:24 AM #885
Recent models does not have SW mounted battery anymore, don't know if it depends on models.
MMID-Multi Media Information Display or just simply MID.
Mitsubishi manual says its MMCS-Mitsubishi Multi-Communication System.
Sent from my Nokia5110i-VgT using Tsikot Forums
May 11th, 2014 12:41 AM #886
Sir prince777,
Not sure if we have the same reference, the 2010 download version and sa website (2011)
although sa thailand built yung majority ng monty sa pinas.
sa global po ba ang reference?! or sa australia? (except sa russia kasi nasa 220 ang speedometer ang label)
or meron mismo sa philippines?!
May 11th, 2014 01:08 AM #887
Sir PP, indicated naman sa 2010 manual kung para saan bansa yung model, same as sa online manual. Kaya lang, dahil sa upgrades, other parts from specific models in other countries are being used as upgrades pa sa models natin.
If you are referring to SW remote battery, i guess nag start in some 2012 models na wired na yung controls.
Base sa pagkakaintindi ko sir MID is yung display sa taas at ang HU is yung nasa baba kung saan may lagayan ng CD o magplay-play ng CD.
:D
Sent from my Nokia5110i-VgT using Tsikot ForumsLast edited by prince777; May 11th, 2014 at 01:25 AM.
May 11th, 2014 01:20 AM #888
Anyone know how to install a gtv spoiler? Got one from hektorsky. And i dont know how to mount the clips. And if i should add silicone? Or clips are enough? This is what the spoiler looks like. But i got it unpainted for 2,500(resin color). Pretty sure its the same thing that casa sells for 9,000 they just wrapped it with cf stickos and then kaboom OEM price
May 11th, 2014 07:54 AM #889
[QUOTE=playplugg;2349273]Sir Reybeck, ask ko po kung i-hold ko po yung volume switch, will fully turn off the HU?! and same procedure po rin ba to turn it on again?!
The HU....
Yes sir, same procedure lang po.
May 11th, 2014 08:02 AM #890
I had mine installed pero tinanggal ko rin kasi tumatama yung edge ng spoiler dun sa edge ng roof panel pag binuksan fully yung tailgate. Pag install nito, wrap mo muna ng 1 layer ng electric tape yung dalawang hook support that comes with the spoiler to prevent/avoid your monty's body paint from any scratches. Then hook them up on the top edge of the tailgate. Yung span distance between the hooks will depend on the span of spoiler holes where the hooks with protruding bolts will be secured. I-shoot mo yung protruding bolts ng hooks dun sa holes ng spoiler then secure it with nuts using a socket wrench. Then cover the holes with the cut circle chips that comes with the spoiler. Open your tailgate fully to access the hooks inside then secure it with mechanical screws which also comes with the spoiler package. Kung meron kang scrap rubbers (bike interiors or similar), cut 2 rectangles to size and insert it between the hook and the tailgate then secure the hooks as mentioned with the mechanical screws. This will prevent your tailgate finish from any dents or scratches when you tighten the mech screws. I suggest too to apply a 3m molding tape (cut to shape) on the center and ends of the spoiler that will sit on top of the tailgate panel to secure it firmly with the tailgate. For me, I won't need a silicone since there is nothing to seal it from water sippage. Plus the effort of silicone application and clean-up is a pain to do. Hope this helps.Last edited by leinahtan; May 11th, 2014 at 08:17 AM.
Lol daig pa mismo ng ford na may surplus parts mula sa mga katay o parts-out na units kahit papano.
China cars
