Page 176 of 197 FirstFirst ... 76126166172173174175176177178179180186 ... LastLast
Results 3,501 to 3,520 of 3938
    Feb 2007
    #3501
    Quote Originally Posted by cagekoni View Post
    Anyone want to share the base files of our 2013 monty gps software. Please? I have updated my software and what i got after the update are distorted maps on some spots.
    Posted via Tsikot Mobile App
    Have you tried to repeat the process sir?
    That's why a back file is a must in every update. Mine is 2011 model and i saved all the updates eversince.
    Sent from my Nokia 5110 using Tsikot Forums
    Aug 2013
    #3502
    sir toatz, pwede malamang yung 3mm aluminum. yung 1.5mm not sure baka pwede rin yun nga lang aluminum, baka sa sobrang init ng exhaust gas mabutas. stainless steel na lang sir hanapin mo para heat resistant at hindi kakalawangin.
    Thank Sir GTV. Ung 3mm n aluminum plate n ung ginamit ko at aun nakabit ko n rin at test run muna ng malayo layo pag may time.
    Apr 2012
    #3503
    Haha! Wag nyong sabihin sir di nyo alam magtanggal? :D
    Ibigay nyo na lang sa nangangailangan...
    seriously, no idea sir prince paano debadge. although may nabasa ako dati sa detailed image...I google ko na lang o check sa you tube
    Apr 2012
    #3504
    Quote Originally Posted by Toatz View Post
    welcome sir toatz, you can check kung wala na usok at mas maganda na hatak sa low rpm...goodluck
    Feb 2013
    #3505
    Yes sir prince777. Thrice already and all have same results. The first try must have been the real cause problem is i did not make a backup that's my problem.
    Feb 2007
    #3506
    Try nyo manual update sir cagekoni.
    Feb 2013
    #3507
    I already did sir prince777 but to no avail. I believe sometime in my first try i may have erased the original files. Thats why when i updated - thats all i have in my sd card - only the update files
    Jan 2013
    #3508
    wala naba may issue sa SW control nang HU sa mga GLS-v&GTV?
    i still feel bugged by it not working from time to time, i observed that it happens tuwing natatagtag ang unit either by matinding lubak or yung speed sensor strips sa mga kalsada. and when ever nawawala yung control sa SW the MID screen also freeze, hindi nag uupdate yung FC and compass doesnt move.. hayyz paid so much for an suv with a lemon HU.:mad2:
    Jul 2013
    #3509
    sirs, my abs light just came on. sa mga naka experience na nito at dinala sa casa, ano findings nila dun? also, yung pagcheck gamit ang scan tool nila eh may bayad daw kahit under warranty pa ang monty? tia!
    Feb 2007
    #3510
    Quote Originally Posted by watdafck View Post
    WTF! :D
    Walang bayad dapat yun!
    Findings will be determined after scan.
    Mar 2005
    #3511
    walang bayad yan as long as nakailaw kasi scan nila yan to know the problem.
    that happened to me before the rig's 15k or 20k pms (can't remember now which is which). the apparent cause was a faulty abs sensor. it was replaced relatively hassle free because of its warranty.
    Jun 2012
    #3513
    Mga sirs at sa mga nagpakabit na ng push engine start. okey pa po ba at wala nmn po ba kayong na encounter na problem after few months/years of using it? balak ko po kasi pakabit din. Hermes 1200B yata according sa napag tanungan ko latest daw nila.
    TIA
    Mar 2004
    #3514
    saka paano din ba magtanggal ng emblem na GTV sa likod at sa harap. i want to take out mine para maiba naman ;) lahat na nagiging V at GTV
    Use dental floss.
    Apr 2012
    #3515
    Use dental floss.
    thanks sir. saw it in you tube, hair blower saka dental floss lang pala ginagamit.
    #3516
    guys, pls help..
    may montero ako 2010 model a/t. problema ko, pag umaakyat ako tagaytay nag steady sa 3 ung drive kahit mag manual ako ishift ko ayaw. ano kaya ang problema? please help me guys.. thanks
    #3517
    Quote Originally Posted by jjnbo0322 View Post
    guys, pls help..
    adaptive tranny kasi tayo, so when na detect niya na palagi auto shift to a lower gear, mag fix yan. you need to rest, then re start. dapat before ka dumating dun sa hilly portion, sports mode na agad
    Jul 2013
    #3518
    sakto nga sir, lumabas sa laptop nila FL(front left) speed sensor. unfortunately, replacement was not hassle-free since wala daw available.
    salamat sa mga reactions jovill, prince777 hehehe yeps, wala daw po bayad :D
    Jun 2013
    #3519
    guys last week nag pa change oil ako sa talyer lang nag mamadali kasi, pano ba tanggalin ung pms sign ng montero natin? nag back read ako pero di ko na mahanap, saw that post pero nakalimutan ko pano. TIA!
    #3520
    Quote Originally Posted by zix888 View Post
    natural lang po ba un sir na mag kaganun? d ko na po ba para ipaayos?.
2013 Mitsubishi Montero Sport owners
