Page 197 of 197 FirstFirst ... 97147187193194195196197
Results 3,921 to 3,938 of 3938
    ^ mag bosch or baldwin oil filters ka na bro. It's A bit more expensive but they're definitely both more of a quality product naman compared to vic oil filters.
    Mar 2018
    #3922
    I bought mine F-196 in Petron where i did my oil change.
    Sent from my ONEPLUS A3003 using Tapatalk
    Dec 2008
    #3923
    Hi Sir Ravenblack.
    Recently got the fuel filter change at a nearby caltex station. They were able to use the F-193 I bought earlier. Dinaan na lang sa matinding pihit para mag-tighten ang fuel filter container para di mag-leak.
    Quote Originally Posted by RavenBlack View Post
    Sir baludoy, does baldwin have fuel filters for the montero also ?
    Thanks for the input guys.
    ^ yezzir. I use Baldwin model # bd 28 for my rig. Double filtration type sya
    Dec 2008
    #3925
    Hi.
    Got another question re Check Engine Light.
    Mine has been going ON / OFF intermittenly. Then for mga 2 to 3 months na naka ON all the time.
    Changed oil about a month ago, then fuel filter a week ago. Still ON ang CEL.
    Naka unioil naman ako most of the time. Sometimes CALTEX or PETRON.
    Bought also mga OBD2 scanners. The cheap blue ELM scanner, Autel MS309 scanner (mga mas mura) & BAFX bluetooth scanner (from amazon).
    All 3 scanners says my check engine light is OFF and there are no errors. But the CEL is ON.
    Anyone bought a scanner that worked well with Montero in general ? Also, where can i have it scanned aside from CASA ?
    Thanks in advance.
    Quote Originally Posted by kikoteng View Post
    Hi.
    Thanks in advance.
    zix performance.. hes a member here but I think hes busy with new toys. hes on fb too
    #3927
    Quote Originally Posted by phelicskit View Post
    The same thing happened to my Gtv. Has anyone solved this? TIA
    May naka-solve na po ba nito?
    Mar 2018
    #3928
    Anybody here tried to install a headrest for the middle seat 2nd row?
    #3929
    but you need load resistors for the turn lamps(leds),
    (diy ko lang)[/QUOTE]
    Hi Zix,
    Pwede po malaman kung paano ang connection ng diy na load resistor sa mismong system na?
    Kahit simpleng diagram lang po...
    Nag palik kasi ako ng LED ngayon, naging fast blinking na..
    #3930
    Quote Originally Posted by teng55 View Post
    (diy ko lang)
    Hi Zix,
    Bro- You put one in series with each of your signal lights.....
    (+) ---signal light---- load resistor---- (-)
    #3931
    Thanks po... akala ko kasi parallel sya icoconnect... pero di ko muna tinuloy...
    #3932
    Connecting it in parallel with the LED bulb will effectively lower the R - even lower than the current LED bulb resistance.
    Bro - you need to increase the resistance as seen by the circuit and the capacitor,- and so you place it in series with the LED bulb/light. Just cut the wire just before the socket and connect it; Works on either of the [2] lines
    Have not really tried it,- just theory based on this...
    T=RxC...
    Nov 2013
    #3933
    Quote Originally Posted by zix888 View Post
    wala talaga siya illumination
    binuksan ko na yan para lagyan eh
    kaso masyado risky, need to remove the clear plastic on top then put a hole in the black plastic para mag pass thru ang light. ended up illuminating yung knob guide
    Sir, what kind of bulb illuminates the PRND letters? T5 type bulb ba? Napundi yung akin and gusto ko rin buksan at palitan
    Jul 2006
    #3934
    honestly bro, pag ikukumpara mo yung quality ng panonood sa oem na tv tuner and tv plus, eh david and goliath ang diprensya. believe it or not, dami nako nakabitan ng tv plus na may oem tv tuner na
    Sir, been looking for a link kung paano mag install ng TV plus sa 2016 Monty GLS - audio lang kasi lumalabas when I connect to the auxiliary. Hope you can help. Salamat
    Mar 2018
    #3935
    Make sure that the aux cable you are using is AV. Try this. TV Plus to Car Monitor AUX Socket Direct Cable GZ-85 3.5mm AV Baby to Baby Plug 1.5meters | Lazada PH
    Sent from my SM-G975F using Tapatalk
    Jan 2024
    #3936
    Quote Originally Posted by Nelson Cabrega View Post
    Calling out the owners of the brand new 2013 Mitsubishi Montero Sport to share anything about their new Montero.
    I have an question/issue with my 2013 montero. Specifically the power side mirrors… when I activate my power side mirrors the passenger’s side mirror folds open to its correct position while my driver’s side mirror folds open too much, it folds open to about 180 degrees but when I press the button to fold the side mirrors back in, both side mirrors fold in just fine only when they fold out the driver’s side folds out to 180 degrees while the passenger side mirror folds out just fine. Is there a way synchronized the side mirrors without having to open up the driver side mirror? Thank you.
    May 2008
    #3937
    Hi Incy, nabali na yung stopper niyan kaya open wide na siya. Dati, nangyari na sa Montero namin yan. Pansamantala, hinahawakan lang namin kapag nag-open para tumigil sa desired angle hanggang pinalitan na rin namin ng replacement side mirror. We asked casa about repair, palit buo rin ang suggestion kaya naghanap na lang ng cheaper alternative online
    Sent from my Xcover Pro using Tsikot Forums mobile app
    #3938
    Quote Originally Posted by blacksilver323 View Post
    also,
    the banawe QC folks might offer a cheaper solution...
2013 Mitsubishi Montero Sport owners
