Page 179 of 197 FirstFirst ... 79129169175176177178179180181182183189 ... LastLast
Results 3,561 to 3,580 of 3938
    #3561
    nakakatuwa naman.........
    OB, pasok!
    Posted via Tsikot Mobile App
    Apr 2013
    #3562
    Quote Originally Posted by dj ian View Post
    Sir tanong lang, sa filtration ba kelangan ba ng "laws of gravity"?
    At ilan ang napag aralan mong laws sa gravity sir?
    Correction sir law of gravity pala.
    Sent from my iPad
    Sep 2011
    #3563
    Quote Originally Posted by Bengbeng View Post
    Turbo going to occ, checked my hose na naka connect sa manifold ko dry eh, so blow by gas flows from turbo to occ ended in manifold, pero sana na fifilter na nalahat sa occ, para malinis si manifold.
    Sent from my iPad
    Hmmm, Correct me if Iam wrong but blow by gases for our OCC comes from the engine. Yung setup ng OCC is a one way flow (engine > OCC > pre turbo > turbo > IC > intake manifold) Oil lubricating our turbo bearings, I believe does not come in contact with the blow by gases or the air intake. Yung blades ng turbo yes ( exhaust and air intake) but the oil lubricating the turbo should be sealed
    Feb 2007
    #3564
    Some good read here..
    http://oilcatchcan.com
    Happy Birthday sir Butch! ;)
    Sent from my Nokia5110i using Tsikot Forums
    Jul 2013
    #3565
    Quote Originally Posted by butchyboy View Post
    im confused sir ano po ba talaga official flow ng gas sa OCC >_____<
    Apr 2012
    #3566
    Quote Originally Posted by RF02 View Post
    kung walang OCC:
    blow by gas (with langis) > papasok sa air intake line > turbo compressor side > intercooler > intake manifold
    kung may OCC:
    blow by gas (with langis) > OCC > papasok sa air intake line > turbo compressor side > intercooler > intake manifold
    so yung OCC ay inilalagay lang para saluin yung langis na kasama ng blow by gases para di makarating sa intercooler at intake manifold. HTH
    Sep 2011
    #3567
    Oil Catch Cans | Everything you need to know and more!
    Maraming Thank You Sir Prince
    Jul 2013
    #3568
    kung walang OCC:
    kung may OCC:
    thanks sa info sir buti malinaw na hehe
    Apr 2014
    #3569
    sir normal po ba ang smoke sa dip stick ng montero sports? thank you.,
    #3570
    sir zix, parang katulad yan nung "pedal box" ng DTP. Just in case ba madali lng maka order syo? paki pm kung magkno. thanks..
    Nov 2013
    #3571
    May tanong lang ako sa alarm ng 2013 MS GLS-V. Naka-connect pala yung alarm sa lock/unlock button sa driver's side door kaya kapag nagalaw mo iyong button kahit bukas yung sasakyan, nag-aalarm minsan. Paano i-disable yung function na ito? I mean gusto ko lang yung alarm na hindi konektado sa lock/unlock switch sa driver's door. Thanks.
    Sep 2013
    #3572
    Hello Montero Boys.....
    Hope everyone is enjoying the Holy Week break...
    Ask ko lang if meron nakapagkabit ng Bosch Europa sa ating rigs using the stock horn wiring?Had my old europas transferred to the montero.... no long horn bursts, just the usual "beng-beng"...
    one was right behind the mitsu logo on the grill and the other one below it beside the intercooler...
    first observation was malakas sya compared when it was in the car... sounds great on the montero.
    I first changed the stock horn to a bosch EC6 but found it parang kulang and marami kapareho, the old europas have been in the old camry for almost a decade but still sounds malakas.
    Salamat mga sirs
    Jun 2013
    #3573
    gud pm mga sir 10000 km na monty ko san po ba murang mag pa change oil sa parteng bacoor cavite po place ko at anong brand magandang full synthetic oil....tia
    Jul 2013
    #3574
    good day mga sir! anong brand ng Coolant po ang magandang gamitin? TIA mga sir!
    Apr 2012
    #3575
    Quote Originally Posted by LLOY View Post
    yung oem coolant ng casa ang nakakarga sa akin so far ok naman check out brands like royal purple ice, prestone, shell, Caltex, castrol, meron pa yung mga waterless lifetime coolant sa diy at ace.
    Jul 2013
    #3576
    ok lang ba sir kung top-up lang na kahit anong brand ang ihalo? 9months na ang monty di pa napapalitan ng coolant, medyo nasa minimum level na siya. baka kailangan pa pong i-flush?
    Apr 2012
    #3577
    nasa manual naman sir anong km siya need palitan. di ko na matandaan anong PMS pinalitan yung unit ko.
    Jul 2013
    #3578
    nasa 8.500 kms palang yung monty sir, natatakot lang ako baka mag overheat siya anytime before 10kPMS. hehe
    Apr 2012
    #3579
    don't worry sir, di naman mag-overheat basta ang makina natin not unless matuyuan ang radiator. pwede top-up mo na lang distilled water to reach yung tamang level niya sa coolant reservoir. iirc, sa 20k PMS top up lang then sa 40k PMS na yata napalitan coolant ko. better check the manual na lang sir.
    btw, other casa have a policy to put a seal sa radiator caps. as per explanation daw, merong nag-overheat na unit dahil naubusan ng coolant dahil loose yung cover, hindi naisarang mabuti.
    Jul 2013
    #3580
    don't worry sir, di naman mag-overheat basta ang makina natin. pwede top-up mo na lang distilled water to reach yung tamang level niya sa coolant reservoir. iirc, sa 20k PMS top up lang then sa 40k PMS na yata napalitan coolant ko. better check the manual na lang sir
    Salamat sa advice sir! Will do it first thing in the morning.
    Lastweek din kase muntik na rin masira yung battery, nakulangan din ng fluid yung battery. Kaya medyo alert na po ako ngayon. :D
    Posted via Ay****
2013 Mitsubishi Montero Sport owners
