Page 186 of 197 FirstFirst ... 86136176182183184185186187188189190196 ... LastLast
Results 3,701 to 3,720 of 3938
    Jul 2014
    #3701
    Hi members, ask ko lang kung pano matatanggal yung scratch sa windshield? medyo malalim sya eh, baka may remedy rather than to replace it? also, okay lang ba na tinanggal ko yung antenna ng monty? Thanks!
    Jun 2008
    #3702
    No...got my plate after 4 months from my SA and my sticker was also given to me by my SA also. By the way, got my monty at Citimotors Las Pinas...
    Quote Originally Posted by whitemonty2014 View Post
    Sir rb1_fernandez, delivered din po ba yun sticker nyo thru LBC? yun sa akin kasi December 2013 binili/registered then dineliver yun plates nito lang June 2014, pero walang stickers , ganun din ba yun sa inyo? nauna muna yun plate tapos stickers or sabay nyo na recieved yun plate and stickers?
    Jul 2013
    #3703
    Sir it happened din sa akin ito using Petron Turbo gamit ko, twice na nag CEL, at first pinalitan ng fuel filter at 9kms, at recently lang 15kms sabi sa Casa fuel filter n nman daw, they even suggesting na we have to pull down the fuel tank for cleaning. Most likely baka sa Petron Turbo talaga. Sir, question, have you experienced it again (CEL)? what Diesel na gamit mo?
    By the way, sorry if may mali ako using terminologies - newbie here.
    Jul 2013
    #3704
    Guys, need your help here..Sumasakit na ulo ko nitong Check Engine (CEL) dahil daw sa marumi na ang fuel filter - been refueling sa Petron Turbo Diesel ever since.
    - I experienced it as early as 9km mileage and had it computer scanned (P1,200++) and changed the fuel filter (P1,400++) sa Citimotors - not sure the exact amounts charged.
    - And now recently, a day after kinuha ko from Citimotors for the PMS 15k, I experienced it again (CEL) and the agent told me it's the fuel filter again! and they even suggested na to pull down the fuel tank.
    Since these things for sure will cost me a lot, can you guys help me figure out alternative ways of fixing this without voiding the warranty?
    - Like, scanning & changing the fuel filter sa Rapide or other reputable shop? at tanggalin na rin yong CEL? etc..
    By the way, I apologize in advance for bka mali yong terminologies that I'm using or maybe my issues were already answered on some other thread - newbie.
    Thanks a lot for the help.
    Apr 2012
    #3705
    Sir Choi, if you will read back on our montero forums, a good number of owners did experience the same in using petron turbo diesel. Mine is running at 11k kms but didn't have problems with filter yet as I'm using Unioil which is Euro 4 compliant. Others purchased an OBD2 scanner to check on their own the cause of CEL and perform DIY replacement of fuel filter. Hope this help.
    Posted via Tsikot Mobile App
    Jul 2013
    #3706
    Thanks Sir Wing for your time to reply on my inquiry.
    Lastly, any suggestion kung kailangan ba to pull down yong tank as early as 15k mileage? Also, If ever I decided to perform the scanning na lng OUTSIDE the Casa (Citimotors) (just to make sure) then replace the fuel filter there as well - kaya din burahin yong check engine light?
    Feb 2007
    #3707
    It would just take an OBD scan tool to know what caused it and remove the CEL. I suggest na kung ayaw mo sa casa, pa sked ka rin kay zix for this job.
    Kung recurring CEL due to FF, palit na kayo ng Gas at Gas station hanggat maaari. Observe muna kung mag CEL pa rin after fuel brand change.
    Pull down ng Fuel Tank is your last step.
    Sent from my Nokia5110i-VgT using Tsikot Forums
    Jun 2012
    #3708
    Quote Originally Posted by choii View Post
    di kaya nakahoy fuel filter mo for the 2nd time?
    Aug 2014
    #3709
    Sir zix, makukuha ko na sa tuesday ung monty ko sa marilao bulacan casa. Papa sched na sana ako ng egr blanking, air filter and kng ano pa dapat upgrade na pasok sa budget. Pa send nmn sir price list ng recommended mo n upgrade. Tnx sir.
    *all wala pa po ako alam sa monty as I will be upgrading from a hatch ford car. Ano po ba difference ng 2013 model to 2014 na gls v. Baka kasi machambahan ako ng loko sa casa. TIA
    #3710
    Quote Originally Posted by maru01 View Post
    Nagpm ako as inyo sir. Kindly check. Thanks
    Jan 2013
    #3711
    Bro pasok to sa lemon law Republic Act No. 10642 | Official Gazette of the Republic of the Philippines
    You should ask for a permanent solution for this and the cost should be free
    Nov 2013
    #3712
    kaso yun nga yata sir ang suggestion ng casa, palitan nya yung Fuel station nya kasi madumi kaya mabilis mag bara filter kahit bagong palit pa,
    Quote Originally Posted by aragon58 View Post
    Jan 2013
    #3713
    Oo nga, kasi euro 4 ang recommended for montero sports
    #3714
    During my 1k PMS I asked the mechanic what are the common issues they encounter. Ang sabi din sa akin is yun ngang fuel filter really resulting to check engine. Meron nga daw instance wherein they actually found rust inside the tank.
    How that could have happened their guess was:
    1. From the gas station. Yun nozzle mismo pag nagkarga ng gas might have rusted part (daw).
    2 Impurities of the diesel itself (euro 4 dapat).
    He also suggested to avoid low fuel levels for long stretches bec the air that displaces the fuel inside the tank may lead to corrosion.
    Frankly I take these with a grain of salt except for Euro 4 diesel since this specifically indicated in the manual.
    Jul 2010
    #3715
    Sir Zix, pa PM name ng prices ng cabin filter at EGR plates. Nagkakabit ka ba sa bandang Alabang or Las Pinas area? TIA
    Dec 2013
    #3716
    Sa 40K PMS ko, 7 cans of TOP 1 SDO ginamit. Checked my engine oil level sa umaga, lagpas max hole sa dipstick. Binawasan ko na ng 600ml. Kinabukasan, nagcheck uli ako pero abot pa rin max hole. Natry ako after magbawas ng oil nagstart stop ako ng engine then check ng dipstick nasa gitna yung level. Magbabawas pa ba ako?
    #3717
    Quote Originally Posted by Geronimo Valino View Post
    for reference lang bro, from 10k-100k kms nung monty ko, 6 cans lang lagi gamit ko, sakto every checking ko in the morning. always sa umaga ang check, overnight hindi umandar
    Dec 2013
    #3718
    Quote Originally Posted by zix888 View Post
    Check ko uli bukas master. By the way, ano pala suking oil gamit mo? PaPM din pala mga new upgrades sa Monty natin. Egr blanking, k&n filter at occ pa lang meron ako galing sayo. Para mapag ipunan na at parating xmas bonus. Hehehe.
    Jun 2012
    #3719
    mga sir baka po may nakagawa na po sa inyo neto. pinalagyan ko kasi ng cover ung side mirror ko kaso after two years
    pinasukan ng tubig ung part lens ng signal light. kaya naging yellowish na cya.
    balak ko ng tanggalin mismo ung pinalagay kong cover. question is ano kaya pwedeng pantanggal neto nakadikit po kasi cya ng 3M thanks
    Aug 2014
    #3720
    Quote Originally Posted by MonteroGLSV View Post
    Goo Gone. Available sa True Value and Ace. Bilis lang yan matanggal.
2013 Mitsubishi Montero Sport owners
