Page 169 of 197 FirstFirst ... 69119159165166167168169170171172173179 ... LastLast
Results 3,361 to 3,380 of 3938
    Jun 2012
    #3361
    Need help guys, need ko ipa repair ung rig namin kasi nabagsakan ng gate. So far ang nakikita ko lang na malapit is Brothers Auto Concept in Las Pinas(5500php lang daw babayaran) and Genspeed Paint and Smash Repair Inc. Sa brothers walang picture ng gawa nila (credited lang ng insurance namin) sa Genspeed naman maraming pics at mukang ok. Need lang ng personal inputs baka meron senyo nakapag pagawa na sa kanila or kakilala or if may ma sa suggest kayo na iva vouch nyo na ok gumawa. First timer here. I live in the south. TIA!
    Note: Nag post na ko sa Detailing thread no reply for at least 2 weeks.
    Heres the pic of the damage: http://tsikot.com/forums/mitsubishi-.../index514.html
    Feb 2007
    #3362
    Bakit sa ibang topic napupunta yung link? :/
    Casa is always my prepared shop when it comes to insurance repairs...
    Sent from my iPad using Tsikot Car Forums
    Sep 2013
    #3363
    Mga peeps, nakita ko ito sa previous thread pero walang description.
    DSC05555.jpg Photo by sss44ph | Photobucket
    1. Ano ang tawag sa assembly na ito?
    2. Ano ang adavantage/disavantage kung naka-install sa unit?
    3. Saan makakabili nito?
    Thanks,
    Apr 2012
    #3364
    Quote Originally Posted by RainierMendoza View Post
    Thanks,
    1. oil catch can
    2. read mo mga previous post, marami na discussions about OCC
    3. pm mo si sir zix
    Jun 2013
    #3365
    Quote Originally Posted by katsupoy View Post
    Mga sir ano po gamit nyo na radiator coolant?ok lang ba prestone? And paano mixture? Thanks
    Repost ko lang po ulit. Thanks
    Mar 2013
    Jan 2013
    #3367
    Mga sir, im looking for leather seats for my monty, meron po ba kayo massugest na shop, how much po?, yung sa ace hardware kasi di maganda yung quality ng leather, patulong mga papps, salamat
    Nov 2013
    #3368
    Quote Originally Posted by aragon58 View Post
    Sir, try mo seatmate, i'm not affiliated with seatmate, but one satisfied customer of seatmate here. Search mo lang Sir, they have an online website , contact details.
    Hope this helps
    Sep 2013
    Jan 2010
    #3370
    Quote Originally Posted by rover2027 View Post
    good morning tikoteers! o.t. lang po
    experience last friday na hindi gumana ung auto shifting ko nasa 2500 rpm na and yaw pa rin pumasok sa second gear so i tried manual gumagana siya but when i revert back to auto ayaw nya mag auto shift.tapos maya maya nag appear na check engine.scan it and yields report of P1901-POWERTRAIN,for mitsu it says A/T fail (engine timeout).and for mazda it says torque converter clutch circuit intermittent.however when im about to drive again it shifted back to normal again in auto mode but still check engine still there tried to reset it about 2 times with engine running and with engine shut off but key in ON position.but to no avail.and then i finally get it a rest.after that it reverts back to normal again.by the way im using torque apps.with bluetooth obd2 scanner.
    This same and similar incident also happened to my montero this morning while in UP Diliman, the ECU triggered a CEL..... Transmission won't up shift automatically, engine rpm already at 2000 rpm, normally my transmission automatically up shift when it reaches 1600 to 1700 rpm, swabe lang kasi ako mag-drive for FC economy.... ano po kaya ang root cause nung problem na yun?
    Jul 2013
    #3371
    Quote Originally Posted by rmsoriano View Post
    Mga sir nangyari din sa akin to with my strada. Kutob ko yung pagtanggal yata ng obd scanner na naka ignition yung car.. i tried to reset, bumalik din one time, reset again then d na bumalik. Ganun din sa shifting, delayed pero bumalik lahat sa dati.
    Sa service manual may mga diagnosis dun for P1901 pero one is AT ECU malfunction.
    #3372
    Quote Originally Posted by dj ian View Post
    nangyari samin yan, using android apps + elm. maraming errors na lumabas pero nung sa laptop wala na naging problem
    Mar 2012
    #3373
    Quote Originally Posted by zix888 View Post
    so far so good pa naman boss yun sa akin using android apps + elm. very helpful naman on my case.
    #3374
    Quote Originally Posted by the_mechanic View Post
    good for you sir!
    Apr 2012
    #3375
    hmmmn, nakaka-trigger din pala ng CEL ang ELM at android apps. meron din ako obd2 ako pang android at pang iphone pero di ko pa nagagamit. baka yung sa iphone na lang ang gamitin ko...
    #3376
    we used torque on note3 with elm nung nangyari yon
    Jul 2013
    #3377
    So sir, ano yung problema, yung mismong ELM? Di ko na rin sya ginamit mula nag kaCEL ako. Baka naman hindi safe gamitin. Vgate sa akin yung mga nakikita sa sulit.
    Sir zix, laptop na ba gamit mo? Yung mismong MUT3 na? And bat dito sa amin walang supply pump correction learning sa laptop ng casa? Small injection quantity learning lang ang meron.
    #3378
    kelangan lang naman ang supply pump correction learning when SCV is replaced or supply pump replaced. nagpalit ka na ba ng any of these 2?
    Jul 2013
    #3379
    Sir yung scv lang. Pero wala daw sila SPCL. SIQL lang daw.
    #3380
    bundled sa mut3 nila yan ah, baka hindi lang alam nung gumawa
2013 Mitsubishi Montero Sport owners
