Page 12 of 294 FirstFirst ... 289101112131415162262112 ... LastLast
Results 221 to 240 of 5877
    Apr 2012
    #221
    Only thing i got yesterday.
    Apr 2008
    #222
    The Mirage was pretty spacious when I sat in both the driver and passenger seat. Am 5'10" and around 285, so I am really big. The legroom was really good.
    I certainly hope that the price will remain the same since this will surely be a hit. Targeting the TOL manual version with all the cool toys for its price range.
    Jun 2012
    #223
    ^ agree. this will be a hit. pumasok kami ng 2 friends ko sa likod, dalawang 5'7 isang 5'9 na medyo mataba, sakto lang. comfortable kami. not too cramped. sana kayanin ng mitsu ang demand at magkaroon ng standard discount para lalong bumaba price
    #224
    Quote Originally Posted by nrthstr View Post
    where'd you get that? i didn't see that!
    May 2008
    #225
    kpag nagpareserved daw po may free nyan at tshirt last PIMS.
    May 2008
    #226
    Is it true na yung reservation is till the show only? And they may not be availed on their usual branches?
    pwede po sa mga dealer branches, til october 31 yung early bird reservation, may chance pa manalo sa Jan 31 ng another mirage as raffle.
    #227
    It would be strange for the Mirage not to have ABS considering it has dual airbags. Car companies usually remove the airbags first then ABS if they wanted to lower the price. Back read a page or two, the MMPC brochure they gave out indicates there will be ABS+EBD for GLS models.
    Thanks Walter for making the correction. Yes I missed this in the flyer, so GLS has the ABS/EBD feature! Which makes the pricing all more attractive !
    #228
    2012 Mitsubishi Mirage (codename EL = Entry Level)
    Price (as of August 16, 2012 * PIMS 2012)
    GLX MT - 498K
    GLX CVT - 548K
    GLS MT - 588K
    GLS CVT - 638K
    Specifications based on the brochure handout:
    Engine 1.2-litre three-cylinder engine (3A92)
    Fuel System ECI-MULTI
    Displacement 1193 cc
    Bore x Stroke 75 x 90 mm
    Compression Ratio 10.5 : 1
    Max. Output 78 PS / 6000 RPM
    Max Torque 100 N-m / 4000 RPM
    Fuel Tank 35 Liters
    Fuel KPL 21 kms per liter (*MMC test results usig EU Combined Cycle)
    LxWxH 3710x1665x1500
    Wheelbase 2450mm
    Ground Clearance 160 mm
    Turning Radius 4.4 meters
    Curb Weight: 820 to 850 kgs
    Tranny Gear Ratio 3.545 to 0.804 (5MT) / 4.007 to 0.550 (CVT)
    Final Gear Ratio 4.055 (5MT) / 3.757 (CVT)
    Tires & Wheels
    GLX 14" Steel with Full Wheel Cover and 165/65 R14 Tires
    GLS 15" Alloy with 175/55 R15 Tires
    Suspension
    GLX MacPherson Strut Coil Spring
    GLS MacPherson Strut Coil Spring with Stabilizer
    Steering
    GLX 3-Spoke Urethane
    GLS 3-Spoke Leather Wrapped
    Aircon
    GLX Manual Control
    GLS Full Auto with Climate Control
    COLORS
    Lemonade Yellow Metallic
    Pop Green Metallic
    Majestic Red
    Medium Blue Metallic
    Savannah White
    Cool SIlver Metallic
    Eisen Gray Mica
    Pyrenese Black
    Standard Items (GLX & GLS)
    Front Dual SRS Air Bags
    Front 3P ELR Seatbelts with Pre-Tensioner and Adjustable Seatbelt Anchor
    Multi-Info Display (trip computer)
    INVECS-III CVT or 5-Speed MT
    235 Liter Cargo Space
    Rear Wiper & Washer
    Rear Window Defogger
    Roof Mounted Antenna
    LED Type 3rd Brake Lamp
    Laminated Green WIndshield
    Side Impact Beams
    Child Proof Lock
    Additional Features (GLS only)
    ABS + EBD Braking System
    Rear Tonneau Cover (hard top)
    Keyless Operation System + Engine Start/Stop Button
    3rd Rear Seat 3-point ELR Seatbelt
    High Grade Fabric Seats
    Rear Spoiler
    Fog Lamps
    Some reviews from the net...
    Mileage 4.1L/100km fuel economy using 91 RON fuel
    Part of the requirement of a car getting an Eco-Car tag is that its fuel consumption needs to better than 5.0 litres/100 km (or 20 km/l), and the car has to meet Euro 4 emission levels. The Mirage’s 1.2 litre MIVEC engine has a fuel economy of 22 km/litres (or 4.5 l/100 km, if the online converters are right) and emits only 120 g/km of CO2.
    Suspension - The suspension is neither feathery nor harsh. The system is a standard MacPherson front and torsion beam rear. What is important is that Mitsubishi has been able to dial back the body roll to make this small car chuckable around the corners without going out of sorts. And it feels stable no matter the kind of corners you throw it into. Tight hairpins, long sweepers and S-bends are executed with high scores !
    Drag Co-Eff 0.29
    Tranny Invecs III CVT 0r 5MT
    GLS - DVD/Satellite, Bluetooth, Leather Steering Wheel
    STD - Power windows, climate control, 6 airbags, ABS/ESC, Fog Lights
    The Mirage comes with the standard cup holders, glove compartment and door pockets. Seats are wrapped in fabric, there’s the usual air conditioning and four-speaker stereo system.
    Rear Seats - The rear seats are surprisingly spacious, with great head and legroom. They can easily accommodate four adults with a fifth possible if the need arises.
    Total legroom for the Mirage is slightly more than 1,640 mm, which is more than the Swift, Mazda2 and March; only the Yaris gives more room to stretch !!!
    Mar 2012
    #229
    Hey guys have you notice the Mirage display * PIMS, baliktad yung push button for entry na dapat sa driver's side napunta sa passenger side. Baka di pa nila na-aadjust for Philippines left hand drive set up.
    here's the picture of Thailand Mirage right hand drive with the small black push button use for locking/unlocking the car located in the driver's side obliviously.
    Driver side with black push button
    Passenger side with no push button, only key hole entry
    Here's the youtube video to see what i mean.
    I checked all the pix and vids I got at PIMS baliktad pa nga. Have you notice the same?
    Ma-correct kaya ng Mitsu ito before shipping the finished units here in the phils?
    Quote Originally Posted by joeycaro View Post
    GLX MT - 498K
    GLX CVT - 548K
    GLS MT - 588K
    GLS CVT - 638K
    Fuel Tank 35 Liters
    Wheelbase 2450mm
    Tires & Wheels
    Suspension
    Steering
    Aircon
    GLX Manual Control
    COLORS
    Pop Green Metallic
    Majestic Red
    Savannah White
    Eisen Gray Mica
    Pyrenese Black
    Rear Wiper & Washer
    Side Impact Beams
    Child Proof Lock
    Rear Spoiler
    Fog Lamps
    Drag Co-Eff 0.29
    Maganda talag specs for that price!
    Nice post sir.
    Mar 2012
    #231
    Quote Originally Posted by carchase View Post
    yes i got mirage eco bag, tshirt and the miniature mirage car shown in the picture
    Mar 2012
    #232
    hehehe my SA got the wrong information sabi nya saken hanggang sa exhibit lang daw yung promo (or intentionally he lied to me para maka-reserved na ko) but ok lang naman magre-reserve naman talaga ko and instead of 10K reservation fee I only gave 1500 and the rest i will pay it in the dealers office before oct. 31.
    Good thing na-confirm mo ito bro carchase, para mabalikan ko yung SA ko na mali yung info nya sa PIMS. I have something against him that I can used for future favor or di kaya freebies hehehe
    Aug 2008
    #233
    Quote Originally Posted by calix0305 View Post
    it was mentioned on this forum na yung yellow at yung white-foiled mirage are RHD units kaya baliktad talaga yun. na check niyo ba sir yung Green unit na display kung baliktad din sir? LHD yun green.
    May 2008
    #234
    Nakita ko lang sa mga pictures ng mirage thailand, pati passenger side may may hole. Di ko mapansin kung button or keyhole.
    Aug 2008
    #235
    Driver's side and yung hatch yung may button for keyless entry for the proximity key. yung passenger side naman yung may keyhole , you can use if ever mawalan ng battery/madamage yung proximity key, you can take out the physical key from the proximity key and unlock the door manually.
    May 2008
    #236
    Yung green color mirage pansin ko sa mga pictures sa PIMS, black push button sa left driver side, keyhole only for right passenger side. correcct me if im wrong...
    Apr 2012
    #237
    Like! Like! 👍
    Mar 2012
    #238
    Quote Originally Posted by ratchet23 View Post
    I see. I checked again the pix I got * PIMS. yeah the green mirage's push button was already on the driver's side where it should be. check this shot of mine from PIMS and notice the small black button at the driver's side.
    case closed.
    Jun 2012
    #239
    Guys need help nagpareserve na kami last sunday, But I am still thinking of the best color for me please need your inputs. We will be getting the GLS these are the colors options Lemonade Yellow Metallic ,Pop Green Metallic,Medium Blue Metallic I am a guy by the way and this will be my first car. What do you think are the best upgrade options for the gls Thanks
    Apr 2012
    #240
    Quote Originally Posted by wutangclan_79
    Color n kinuha ko in the Gls was black, 2nd option red. Dark, black, coz for me elegant tignan.
    Lively mga color choices mo, with your options id go for the opposit ng ideal ko, yellow =p
2013 Mitsubishi Mirage
