Page 168 of 345 FirstFirst ... 68118158164165166167168169170171172178218268 ... LastLast
Results 3,341 to 3,360 of 6900
    Apr 2008
    #3341
    AFAIK meron na lumabas na may sunroof made in Russia yata yon GLS 5seater and dual battery and rain sensing baka nanduon pa sa old forum ng MSCP yung pics niya
    I saw one yesterday "p" plate
    Mar 2012
    #3342
    Quote Originally Posted by zix888 View Post
    http://www.youtube.com/watch?v=3bQiE2iGPpI
    *zix888 - how did you totally turn off the hu in the video? Sorry - couldn't see it clearly on the video.
    Mar 2012
    #3343
    Quote Originally Posted by green eagle View Post
    Never mind, Partner. Saw the link in a previous post already - DIY mo pala. Galing mo talaga!
    just got our montero sport gls-v yesterday. so far so good. it's the first time we've acquired a diesel vehicle so i guess there's some adjustments to be made.
    btw, anong diesel fuel ang gamit niyo? and totoo bang or/cr comes together w/ the new plates? mukhang matatagalan pa iyon kung ganun
    Aug 2011
    #3345
    I got my or/cr even without plate yet. It's a proof na talagang nagbayad na yung casa for registration. Blank lang yung nakalagay sa plate number field.
    Sent from my iPad using Tapatalk HD
    Jan 2012
    #3346
    ^^ Well seaoil offers euro 3 diesels while unioil offers euro 4 diesels. I use seaoil since it is the nearest in our place. But i only fill up my tank with these gas stations.
    caloi: so you got yours (or/cr) when you got your montero?
    carwhacko: ano equivalent niyan sa mga big three products? wala kasi sa amin malapit na mga seaoil and other "smaller" players
    Jan 2012
    #3348
    Where do you live boss? Hmm actually the big three players offer euro 2 diesels only.
    Mar 2012
    #3349
    Quote Originally Posted by dhinster View Post
    This is the instruction about SIQL test na pinakita sakin ng SA when they solve my emission problem. So far since that fix, very much ok ang emission ng MS ko. Base on my Odo nakatakbo na ako ng almost 12K..
    Advice ko sayo sir, do this test first before anything else na pagawa sayo. Gumastos kasi ako sa pagbaba ng fuel tank dahil ang initial findings nila sa MS ko is about fuel contamination daw ng water. But after this pull down ng tank mausok pa din dati ang MS ko.
    http://i1155.photobucket.com/albums/...u/0af759fa.jpg
    http://i1155.photobucket.com/albums/...u/04e3fbe6.jpg
    http://i1155.photobucket.com/albums/...u/db32969a.jpg
    Hi dhinster,
    Ask Ko Lang, when they did pulled down your fuel tank did you also replaced your fuel filter?
    Apr 2011
    #3350
    Quote Originally Posted by Big buzz View Post
    Hi dhinster,
    Yes Big Buzz, when i got low power and heavy smoke problem before. They did replace also the fuel filter and SCV (suction Control Valve). But after all those done, still mausok pa din dati ang MS ko.
    Until they do SIQL procedure everything went well. This is free procedure ng casa, so my suggestion to everyone with this issue is better do this SIQL first than to spend money for other fix suggested by them.
    Still upto now very responsive and no black smoke ang MS ko.
    Apr 2011
    #3351
    Hi Mangkas1178,
    Thanks for this. I did found the PDF file, very informative in understanding our Engine 4d56.
    Here's the link for others who may want to download.
    http://samgor.ucoz.ru/_ld/0/5_L200_2.5DI-D.pdf
    Quote Originally Posted by mangkas1178 View Post
    Sirs, may problema na po kayo sa usok at tunog ng makina ng monty nyo? Try po e Google ang small injection quantity learning dyan mabasa nyo ang procedure and periodic ng SIQL. May downloadable pdf manual ng L200 Triton na kaparehas ng monty.
    #3352
    SIQL is done when fuel related parts are replaced. katulad sa case mo na pinalitan ang scv, hindi talaga pwede na walang siql, nakalimutan nila gawin yun nung pinalitan scv mo
    Jun 2012
    #3353
    Hello! ok lang po bang magpa-gas ng montero sa Caltex ayos lang po sya? ung Bank na pinagkuhanan ko ng loan ay may free 5,000 sa Caltex.
    Aug 2011
    #3354
    mga tsikooters at monty owners kindly check po ung mga gas tank nyo for possible "rust". My silent recall ang gas tank ng montero. Pag na contaminate ng kalawang ang gas tank nyo mag check engine siya. Hope this help our fellow monty owners. Paki confirm na lang po sa mga service advisor natin.Thank you god bless
    Nov 2011
    #3355
    Saan po nakakabili nung "V" sa baba ng gls? 2011 model kasi sakin kumukupas na..
    Jul 2012
    #3356
    Quote Originally Posted by clairenceh View Post
    Sa casa po meronyan. Call your SA.
    Sep 2012
    #3357
    share ko lang montero sport 2012 test drive sa vietnam
    [ame=http://www.youtube.com/watch?v=QBJ6MVvUd44&feature=fvwrel]Test drive Pajero Sport 2012 with H.Masuoka in Hanoi - Vietnam - YouTube[/ame]
    Jul 2003
    #3358
    yun Gls-v pwde ba pa fit Oem hid fm GTV?
    kahit yun buong headlight assembly, plug and play?
    or get a 2nd set GLS-v headlights then pa gary's retrofit
    this early i want to invest on the lights kaya baka hindi ako masaya pag pa install lang ng Hid kit sa gls-v.
    Yun 2008 camry palang ang na drive ko na HID, wala ng iba. I currently use Phillips Vision plus and Osram nightbreaker (tumagal buhay kasi kabit ko pag out of town lang ako).
    thanks
    #3359
    2013 Montero Sports will be released on October. GLS-V A/C controller will be same as GTV, wipers will have sensors which will automatically turn-on when it rains. (at may mga iba pang pagbabago including sa seat adjuster). For those who are planning to buy now, antay muna tayo ng 1 month pa.
    Jun 2012
    #3360
    ^ how did you know sir? kakabago lang ng specs nitong 2012 ah. may price increase?
2012 Montero Sport Owners
