Page 171 of 345 FirstFirst ... 71121161167168169170171172173174175181221271 ... LastLast
Results 3,401 to 3,420 of 6900
    Aug 2003
    #3401
    Quote Originally Posted by chico1206 View Post
    Good morning po. Just want to ask montero owners if they are willing to pay around 12k for a new dual exhaust tailpipe assembly? (your old muffler and tailpipe assy will be surrendered to you and shall be replaced with a brand new one) servicing will only take approx 45 minutes.
    conducting a survey po. =)
    yes, as long as this muffler is/has:
    1. stainless steel, or same steel quality as stock (basta it won't rust easily)
    2. larger diameter
    3. engineered to have maximal performance gain (to be coupled with performance chips and high flow air filters)
    4. bolt on (nobody likes the sight of pipes being welded under the vehicle, who knows what those sparks can hit)
    5. not too noisy compared to stock
    6. assurance of high quality craftmanship
    7. dual pipe still allows fitment of hitch receiver
    if the following are assured, why not? let us know..
    #3402
    baka typo lang. yung 2012 gls-v ko 5at naman sya. or baka naman 4at yung 2013 model?
    #3403
    Picked up my Montero Sport GTV at the dealer this afternoon. Thanks to Lyonell of citimotors for facilitating the release
    Jun 2012
    #3404
    Ask ko lang, tumabingi ung antenna ko sa taas nung pag tanggal ko ng car cover, though working siya, masakit sa mata kasi tabingi at ang pangit nya tingnan, tinanong ko sa casa, worth 680 daw. May nabibili ba sa labas nito? Tried bending it by hand, pero ayaw, mukang splint ang kelangan para dumiretso ulit.
    Share lang. May nakita akong Gls V Limited sa casa kanina, iba ung front at rear bumper, and ung side panels is iba rin which is mas malapad, with spoiler(not CF) and ung headrest nya is with monitor(hindi ung malapad na headrest monitor na nilalagay ng casa). More on aesthetics lang nadagdag. 178hp parin
    Aug 2006
    #3405
    Quote Originally Posted by 4XFOUR View Post
    napansin ko sa mmpc brochure, dati ang gls-v ay 5AT pero ngayun naging 4-AT, bakit kaya?
    oppssss! just browse their site, binago ulit ang spec back to 5at...
    Baka lumang brochure yun, 5AT ang GLS-V since late 2011
    Yung GLX non-VGT ko ang 4AT ...
    Though at my low budget of 1268K . . . sulit pa rin
    Jul 2012
    #3406
    Quote Originally Posted by mar04 View Post
    Sir sa pagkakaalam ko that is with 20" lenso intimidator, body claddings, headrest monitors. Package sya worth 200k+ Not sure sa exact figure pero yung ang natatandaan ko. 2012 model pa rin sya, fully accessorized lang.
    #3407
    Quote Originally Posted by ek2jayvee View Post
    2. larger diameter
    2. larger diameter all the way sa downpipe...
    Aug 2003
    #3408
    Sir pwede generic antenna. May mga members kami sa MSCP nangayari din same situation because of the car cover. they opted for the shorty antenna para sure di na mababali. Pero reasonable na yung PHP 680.
    Jul 2012
    #3409
    Sir share lang ko lang po; stock parin gamit nyong wiper? Magpahid ng tire block (rain harry) sa blade para d kumayod sa windshield. May curing pa to ng rubber blade d madaling mag brittle. Linisin po muna ang blade bago apply.
    Jun 2012
    #3410
    San kaya meron sir nung generic na antenna and how much? Funny thing nung tinanong ko sa casa kung magkano, uutal utal pa yung sa parts department, mukang nag iisip pa kung magkano ibibigay saken.
    May 2012
    #3411
    Mga SIRS! tanong ko lng po...during weekends lng po kc ngagamit ung monty..na experienced lng namin pag everytime na switched on the engine then ON the fan, parang my mabahong amoy? ung tipong parang panis na labahan ung amoy?! pero pagka on na ng aircon maya maya mawawala na amoy.. for 2 weeks na pong ganito un.. dati wala naman ganun.. anu po kaya un? TIA..
    Jun 2009
    #3412
    Quote Originally Posted by sirhcacal View Post
    Sir same exprnce sa tingin ko ganun talaga pag matagal na di nagagamit nasanay na din ako sa bad odor pero pag every other day mo naman sya nagagamit oks naman
    Sent from my iPad using Tapatalk HD
    #3413
    madumi na o me fungus sa aircon sir. put moisture absorbers in the car pag naka stock ng matagal sa garahe, and before putting your a/c off, run it on fan mode for a while bago i-off completely para mawala yung moisture sa evaporator.
    Sep 2012
    #3414
    hi MMS owners. Saan po bang Mitsubishi center/dealer/branch merong pinaka-extensive stock ng original Mitsubishi accessories? PLanning to pimip my sport gtv.
    Jul 2012
    #3415
    *sirhcacal, sir try mo e spray ng lysol disinfectant ang blower suction habang na andar. be sure na may proper ventillation ka habang nagspray. maganda buksan lahat na window at may electric fan na naka tutok sayo at wear a face mask baka mauna ka pa sa papatayin na bacteria, viruses at iba pa.
    #3416
    Quote Originally Posted by dhinster View Post
    Yes Big Buzz, when i got low power and heavy smoke problem before. They did replace also the fuel filter and SCV (suction Control Valve). But after all those done, still mausok pa din dati ang MS ko.
    Until they do SIQL procedure everything went well. This is free procedure ng casa, so my suggestion to everyone with this issue is better do this SIQL first than to spend money for other fix suggested by them.
    Still upto now very responsive and no black smoke ang MS ko.
    Boss san po kayo nagpagawa nitong SIQL na to? citimakati seems to be unaware of this.
    #3417
    Quote Originally Posted by zix888 View Post
    SIQL is done when fuel related parts are replaced. katulad sa case mo na pinalitan ang scv, hindi talaga pwede na walang siql, nakalimutan nila gawin yun nung pinalitan scv mo
    Sir zix888 requirement ba tong SIQL upon replacement of SCV? Had my SCV replaced asked the SA about SIQL he doesn't know this, after got my units SCV replaced may kadyot pa din and jerking sa low rpm after each jerk bumubuga either black or white smoke. Then dinala ko ulit sa kanila, after ko dalin wala na yun jerking and kadyot plus the usok so far nung inuwi ko nung friday... Does this mean na SIQL na din? di lang alam SA yun term?
    #3418
    Quote Originally Posted by normyline22 View Post
    yup, its a must basta replaced ang scv. hehe, buti walang kasamang tingin sa langit tapos kamot sa ulo
    #3419
    Quote Originally Posted by rap2_tan View Post
    Madalas kasi mangayari. Parang kanina on our way to antipolo. Malaking tulong kasi yung voice instruction. By 5k pms siguro pacheck ko na.
    Sir baka unintentionally nahihinaan niyo voice niyo... It could happen like this... habang nagraradyo kayo feeling niyo malakas hihinaan niyo siya dba? sasakto salita na voice nung gps instead radyo mahinaan yun gps voice nahinaan niyo... the next day akala ganun ulit gusto niyo naman lakasan radyo sumakto ulit sa pagsasalita ni gps ang mangyayari lalakas boses ni gps... WHILE THE GPS IS SPEAKING SAKTOHAN NIYO YUN VOLUME ILAKAS (kunyari la kayo marinig, off niyo radyo then open gps sabay birit volume pataas saktohan niyo yun "system activated" or pwede rin calculate kayo route pagka-click niyo ng GO ilakas niyo agad volume sasakto naman kayo dun sa "calculating the route, please drive safely" try niyo po :D
    #3420
    naku meron kasamang tingin sa langit yan sabay sulat papel... at banat ng "ano yun sir?" so how do I ask them to do this in a simple term? SIQL lang ba talaga? hehehe... nagpalit ako scv ngayon eh 17k... okay lang kaya sa 20k na pagawa ito? or may downside?
2012 Montero Sport Owners
