Page 170 of 345 FirstFirst ... 70120160166167168169170171172173174180220270 ... LastLast
Results 3,381 to 3,400 of 6900
    Jul 2012
    #3381
    Hi guys. Please advice on what will be the best way to do on a faded portion/ spot on the car dashboard. I left my car in sa parking lot for 6 days na nakakabit yun the steering wheel lock. Nun pagtanggal ko nun lock parang nasama yun coating, leaving a spot sa dashboard. Your suggestion/ help is much appreciated. Thanks in advance.
    Sep 2012
    #3382
    ask ko lang, yun bang manual trans matigas ba talaga clutch? anyone can compare sa innova d4d clutch kung sino matigas at malambot, eto lang kasi nadrive ko na bago maliban sa old Nissan Frontier 4X4..
    salamat....
    Apr 2012
    #3383
    Quote Originally Posted by chico1206 View Post
    Good morning Montero owners.
    i just want to ask a question, and your honest opinion is much appreciated.
    would like to know if you will patronize replacing your standard single tailpipe to dual split type tailpipe for a more sporty look.
    the idea is to replace your standard muffler assy with a new one. servicing will probably take about 45mins. therefore, you can bring home and sport your new montero with a dual tailpipe na.
    price range is about Php12,000.00 (give or take)
    PS
    this is a price survey as requested by a supplier.
    let us know what you think.
    thanks!
    if you change it from muffler to tailpipe, its purely for aesthetic or sporty look
    if you change from downpipe to tailpipe, then it must have some increase in performance. as sir zix mentioned, it will also depend on the type of the new muffler to be installed. another thing to consider is the size of the exhaust pipe, keeping the 2" stock and changing just the muffler i think will not give you any gain in performance. to aim for additional performance, you may want also to increase the size of your exhaust pipe from 2" to probably 2.5" or 3".
    Sep 2012
    #3384
    Good morning po. Just want to ask montero owners if they are willing to pay around 12k for a new dual exhaust tailpipe assembly? (your old muffler and tailpipe assy will be surrendered to you and shall be replaced with a brand new one) servicing will only take approx 45 minutes.
    conducting a survey po. =)
    Sep 2012
    #3385
    Quote Originally Posted by zix888 View Post
    basta bolt on sir why not. this will improve your mid and high range acceleration. pero syempre ano klase yung muffler, sana kasing tahimik din ng oem.
    yes sir, bolt on un. =) ung muffler naman OEM finish un. mas tahimik =)
    Sep 2012
    #3386
    Quote Originally Posted by butchyboy View Post
    pwede siguro kng aesthetic lng concern nung customer, but I think it would be better if you have something to show to the customer na gains aside from the looks if ever there is one. Like kng my hp gains, dyno sheet; kng mas ok tunog o mas quite my sample Ka nung unit, etc.
    sir, thank you. nag tanong na ako sa engineer kung meron bang implications sa performance ng sasakyan ang pag palit ng muffler, sabi naman nila, technically wala daw. pero sa tunog, per actual sampling, mas tahimik daw nung pinalitan. sa usok naman, sabi, mas advantageous ang dual tailpipe kase imbis na focused sa isang exhaust lang ang usok, nahahati sa dalawa, so ang effect daw ay mas diluted ung usok. (kung dati parang maitim, divided into two na, kaya parang nababawasan ung itim ng usok in effect)
    Sep 2012
    #3387
    Quote Originally Posted by Bugoy King View Post
    Sir mataas po ang planta ng mitsubishi sa cainta. kahit magbaha sa kalsada ng cainta ng lampas tao di aabot sa mga warehouse at production plant ng mitsu ang tubig elevated to ang mga ito. nakapasok na ko sa planta nila dahil dito previously nag work ang uncle ko.
    mejo maganda ang lugar ng mitsubishi sa cainta. kase hindi inaabot ng baha... kaya nga nagtataka kame bakit nagtayo ng HONDA dealership dun, e ung side na un ng cainta e lumulubog kahit konting ulan lang. =)
    Sep 2012
    #3388
    Quote Originally Posted by clairenceh View Post
    Saan po nakakabili nung "V" sa baba ng gls? 2011 model kasi sakin kumukupas na..
    hingi ka sir sa dealer mo, libre lang yan..
    #3389
    Hi sir. If we are talking about only a few hp gain from this new assembly (usually 5hp more or less from previous experience) then I find it expensive. Unless they can show us the data and a considerable power gain then I would think otherwise.
    #3390
    Quote Originally Posted by 4XFOUR View Post
    salamat....
    sir hindi naman matigas ang clutch ng monty. I've tried the innova d4d and I would say i can't find any difference.
    #3391
    Well guys, the new Toyota Fortuner is out...now fitted a Variable Nozzle Turbo (VNT) which bumps the hp to 144*3400rpm vs. GLS-V's 178hp*4000rpm. Torque is now up to 343Nm vs GLS-V's 350Nm...torque range is almost the same.
    But wait.... the new Fortuner still DOES NOT have:
    1. Disc brakes at the rear
    2. 5-speed AT
    3. Paddle shift/Tiptronic
    4. GPS
    Sep 2012
    #3392
    Quote Originally Posted by efpu View Post
    2. 5-speed AT
    4. GPS
    kanina mga 4 na brandnew 2.5 fortuner nakita ko edsa wala pa plaka..... ang kaso walang mga hood scoop.... d nakapag antay ng vnt equipped 2.5 with hood scoop... sayang, 102hp vs 144hp laki deperencya nun, ang dko alam kung malaki din difference sa price... kung bibili kayo vnt fort sana nxt year nalang kc baka upgrade nanaman paunti unti... rear discbrake ngaung month, next month 5 speed auto n so on, version1 ver2 ver3 ver4 etc....
    Apr 2012
    #3393
    sa montero kaya? ano kaya ang next na upgrade nila?...kung i-base nila ang upgrade sa mga monty users ay baka ang lalabas ay super montero version na...
    upgrades common to monty users...
    1. with performance chip - para 20%-40% more power
    2. with water-alcohol injection
    3. with sprint booster
    4. with oil catch can
    5. with washable air filter
    6. with turbo timer
    7. with 2.5" exhaust system and dual tips
    8. with 20" or 22" wheels fitted with nitto tires
    9. audio brand should be either DLS, Focal or Morel (with A-pillar fitted seps, 4 or 5ch amp and a subwoofer)
    10. all fitted with oem front honeycomb grill and with spoiler (lahat ng model gawin ng mukhang gtv )
    11. lahat carbon fiber coated ang engine hood, manibela pati dashboard
    12. with std. tonneau cover sa likod
    13. with std. roofrack
    14. with angel eyes headlights
    15. with bosch europa horn
    16. with std. headrest monitor
    17. with o-sulee spring cushion
    18. with engine on/off switch
    19. with keyless entry
    20. with HU either pioneer or kenwood
    21.
    22.
    ano pa kaya?
    Jun 2012
    #3394
    2. 5-speed AT
    4. GPS
    may GPS na ang fortuner. except for the M/T
    #3395
    6. with turbo timer
    21.
    22.
    ano pa kaya?
    malamang pati presyo i-upgrade din nila pag ganito hehe
    Sep 2012
    #3396
    Quartz brown madness..
    Hopefully mailabas ko na mamaya yung isa dyan in God's will..
    Sent from my XT910 using Tapatalk 2
    Jul 2012
    #3397
    Sir. paki include;
    1. turbocharger cooling at turbine side.
    2. turbocharger washing on both turbine and compressor side.
    3. intercooler cooling water independent from engine jacket water.
    4. engine oil glazier o lubricating oil purifier.
    Jun 2012
    #3398
    mag kano na ba ang montero sports ngaun??
    Jul 2012
    Sep 2012
    #3400
    napansin ko sa mmpc brochure, dati ang gls-v ay 5AT pero ngayun naging 4-AT, bakit kaya?
    oppssss! just browse their site, binago ulit ang spec back to 5at...
2012 Montero Sport Owners
