Mga sirs, pwede ba sa monty natin yung baldwin bd7028? May room ba sa engine bay to accomodate its longer length and wider width than its little brother bd28?
Posted via Tsikot Mobile App
Mga bro, is there a way I can remove the lower honeycomb grill without dismantling the front bumper? Pa-guide naman mga bro. Thanks.
ask ko lang sir kung tama ba o OP na ung quotation TIA:
13,868 (30k pms) (hihingi ko pa breakdown)
-change oil
-wheel align(plan ko sa labas na lang o dyan nlng sa casa?)
-egr cleaning(no need kasi blanked na since 22k)
-gear oil change
I might use the Top1 SGO pag dumating na sa PMS when the gear oil requires changing.
http://top1oil.com.ph/?p=45
monty gtv - YouTube
set the ac to max blower setting and thermostat max setting. you should be hearing this distinct sound when the aux fan engages. (full speed). when its busted, slow motion na yan
Sir ask ko lang po, kasi pmnta kami ng mcdo southwoods kanina, almost 3kms ride lang ok naman aircon malamig. Tapos nung pagkakain namin, pag start ko ng engine hindi nalamig ung aircon pag binubuksan ko parang hangin lang tsaka tapos biglang may kakaibang tumutunog sa unahan ko. Nawawala pag pinatay ko ung aircon, ano po kayang problema? Samantalang bago po kami pmntang mcdo galing po kaming longdrive from quezon city to binan laguna ok na ok naman po siya non. Btw im using montero sports glsv 2012 a/t. Maraming salamat po.
Thanks Master Zix sa guidance and sa epektus... Finally installed and as expected.. very responsive engine.
