Page 233 of 251 FirstFirst ... 133183223229230231232233234235236237243 ... LastLast
Results 4,641 to 4,660 of 5006
    Apr 2013
    #4641
    Quote Originally Posted by zix888 View Post
    atty yung monty mo ka-classmate nung monty ko (1st batch gtv), kaya supermonty din yung sa inyo
    Boss pa pm yung prices ng throttle controller natin at auto dimming rear mirror. Tnx boss.
    Jul 2004
    #4642
    Nakow, yung Monty ko ay all stock pa rin and still very enjoyable, hehehehe
    Kahit baterya ko stock pa rin and still very good as per the latest battery test
    Nov 2013
    #4643
    definitely cooler ac output. imagine how big our condenser is, and only 1/4 of it is covered by the fan. plus this will prevent high pressure due to busted fan(since there is only 1 fan on oem set up), since there will be another fan backing up.
    planning on connecting it side by side with the primary fan.
    Ok ito bro zixx
    #4644
    Quote Originally Posted by matiase View Post
    Ok ito bro zixx
    iba talaga may addtl aux, tried and tested. natuwA monty ko
    Apr 2012
    #4645
    Excited to see this on my next check up with the dentist....
    Posted via Tsikot Mobile App
    #4646
    2nd aux fan
    monty gtv - YouTube
    Jul 2012
    #4647
    2nd aux fan
    monty gtv - YouTube
    Sir Zix nasa isang relay at fuse yong dalawa o naka bukod ang fuse at nasa isang relay lang. Ano po ang diameter ng maliit.
    Sent from my GT-I9100 using Tapatalk
    #4648
    Quote Originally Posted by mangkas1178 View Post
    separate relay. 5.5" aux fan oem ng fieldmaster. at least mitsu pa din
    #4649
    Zix, wala yung shroud nung fan? Malaki tulong nun sa air flow. Para hindi sabog yung flow ng air.
    Sent from my Nexus 7 using Tapatalk 2
    #4650
    wala space for that bro. since additional lang naman siya, unlike sa FM na talagang part siya ng oem system, okay na. malakas siya for a small fan. denso motor
    Jun 2013
    #4651
    hi sirs may idea ba kayo kung saan nakakabili ng foglight cover? isa lang sa left side/driver side ganito
    Sep 2010
    #4652
    sir meron ako nakita nyan sa ebay from thailand yung seller.
    Quote Originally Posted by Coolgrease View Post
    Feb 2007
    #4653
    ^^ yung black and silver po ba sir? Magkaiba kasi part number nila.
    Sent from my Nokia5110i-VgT using Tsikot Forums
    Jun 2013
    #4654
    Yup, driver side na foglamp cover.
    May 2011
    #4655
    This is actually correct. I did the same thing sa subic prado ko before nung ginawa kong dual a/c, 2 aux fan para hindi mahirapan ang primary. 15k din ata sa casa ang replacement aux fan.
    Master zixx, Hindi ba kasya yung pang Benz an 11 blades? Tahinik kyung at manipis... Or you really opted for Mmc oem? Sabay sila nag in nung primary? So ang power nakay primary (sya lang may thermoswitch)
    #4656
    Quote Originally Posted by eyepon View Post
    if your aux fan is not wider than 6", pwede, walang problem if makapal, enough space for that, yung max diameter , yun ang critical, kasi hindi kasya. tried fitting 8" sanden aux fan, hindi papasok. separate relay yung aux fan, same source nung oems
    Feb 2007
    #4657
    Inquire kayo sa casa sir kung magkano then let me know. ;) baka may mahanap tayo na mas mura.
    Jun 2014
    #4658
    Quote Originally Posted by monterick View Post
    Mga Ka-Monty do you have "kalampag" in your dashboard? It is very irritating considering that the car is new! Mine is a GLS-V model bought only last February of this year.
    I removed everything in the glove compartment and center console, but the "minor-yet irritating clanking" is still there. For those who experienced the same, what solution did you make or what recommendation can you give?
    The sounds seem to come from all over the dashboard. Meron sa may mga gauges, meron sa may MID, at parang meron din sa may aircon controls. Pag daan mo sa unpaved road, dinig na dinig mo at ramdam mo sa steering wheel.
    Another issue is the steering wheel, may sound din na parang "robotic" as described by one of the forumer here. I had it checked already, and the casa told me that they put some grease, but the sound is still there up to now.
    I asked these questions para pag balik ko sa casa, may idea na ako ng mga ipapagawa at hindi lang aasa sa mga technician nila. Time consuming at very inconvenient kasi ang pabalik balik lang sa casa then wala naman sila solutions to the problems. Thanks in advance mga gurus!
    Were you able to find answers to this issue, bcoz i have the same experience?
    Jun 2014
    #4659
    Quote Originally Posted by Manfred Marpa View Post
    Ako rin, me rattling sound sa dashboard. GLX-AT model sa akin, April this year lang. Sa akin naman sa airbag passenger side, katabi ng HU
    Jun 2013
    #4660
    Hi sir, nakabili na pala dad ko sa casa 500. Thank you for the replies though
2011 Mitsubishi Montero Sport [continued]
