Page 235 of 251 FirstFirst ... 135185225231232233234235236237238239245 ... LastLast
Results 4,681 to 4,700 of 5006
    Jul 2010
    #4681
    Sir how do we know if the aux fan is already busted thru visual inspection, or any sound changes? How much & where we can get it cheaper?
    Posted via Tsikot Mobile App
    #4682
    Quote Originally Posted by joemelr View Post
    visual inspection makikita mo na dapat full speed ang aux fan when ser to max blower speed/max setting of thermostat
    btw marami tayo dumating nito(above pic)
    May 2009
    #4683
    Quote Originally Posted by zix888 View Post
    Sir natry ninyo gamitin, or idrive gtv ninyo with that reading in the tpms? Magself update yan after 20minutes of signal loss
    Hi! same problem with my tpms...ano po ginawa nyo para mag back to normal ang tpms readings?Thank you in advance
    May 2009
    #4684
    Quote Originally Posted by md_alcapone View Post
    my fellow GTV owners, did you experienced this on your MID? it just happen this morning. any idea how to return this to normal?
    Hi!same experience with my tpms...ano po ginawa ninyo para mag back to normal ang readings? thank you in advance
    #4685
    Quote Originally Posted by doc.rod View Post
    sir check the fuse ng module, yung black box with small antenna. located under the dash, side ng power side mirror control. trace back the socket that is plugged in, may makita ka fusebox. sakin busted yung fuse nung nagkaganyan yung screen.
    May 2009
    #4686
    hi sir zix888...ok ang fuse and power ng tpms module...transmission lang talaga ng signal ang problem...try ko remove overnight neg. batt. terminal..then test tom. am.
    #4687
    ok. then try to do a learning mode after. might help
    #4688
    aussie style!!!
    Apr 2013
    #4689
    aussie style!!!
    Bagong epektos boss?
    Apr 2012
    #4690
    Nice looking rotors Master Zix!
    #4691
    Quote Originally Posted by Bengbeng View Post
    by order
    Jul 2012
    #4692
    by order
    Magkano po Sir? Isang sukat lang ba ang front and rear?
    Apr 2012
    #4693
    Quote Originally Posted by mangkas1178 View Post
    I think sa front lang pwede mag upgrade ng rotors unless you will also upgrade your brake calipers sa rear.
    Jul 2012
    #4694
    Quote Originally Posted by wing211 View Post
    Oo nga pala parang may drum pa ang rear.
    Apr 2012
    #4695
    Even sir on those models already with rear inline caliper brakes...
    #4696
    new rear pads, * 98k kms.
    just a guide/basis for everyone.
    baka kasi sabihin on your 20k pms palitin na brakepads. btw my front pads were replaced * 70k kms
    Feb 2007
    #4697
    Has anybody renewed their registration recently?
    How much was the total charges?
    Thanks
    Sent from my Nokia5110i-VgT using Tsikot Forums
    anong brand iyan bro? maingay na din kasi iyong amin so maybe kailangna na din soon
    Jun 2012
    #4699
    Sir zixx kailangan na magpalit rotors sa 100k?
    Kailan po ba ang tamang palit ng brake pad without sacrificing the rotors. Kasi yun nga. Sinasabi ng casa palit na. Haha
    #4700
    oem mitsu bro. sa umpisa maingay pero once lumapat na, okay na. meron tayo if you want
2011 Mitsubishi Montero Sport [continued]
