Na back up nyo po ba yung SD Card nyo bago yung update?
Posted via Tsikot Mobile App
sir mechanic gaano kahaba ang sd extension cable...48cm pwedi na ba..??
Sir Jalen, my sd extension came from sir prince. di ko lang din kasi alam kung gaano kahaba yun. as mention earlier by sir zixx, may tamang paraan ng pagpapadaan sa loob and eksakto lang yun haba ng extension considering yun position of the sd card slot as posted by the master himself sir zixx.![]()
ganda nito boss...
my guide or instruction kaba kung paano baklasin yun panel na eto. my assignment kasi ako this week (DIY), Im replacing the switch I made dun sa DRL and put it here. May nabili ako kasing switch na push button, na pwede dito ilagay. problem ko lang e pano eto baklasin na hindi masisira.![]()
hi. can someone send me the files dun sa sd card ng gps? only the files outside the 2 folders... meron na ako nung files galing sa inav, so only small files. kaso naformat kasi yung card, so nawala yung iba. thanks... kindly send sa mikeko879*yahoo.com. thanks.
yes, i am going to winterpine pag ayaw. medyo la pa kasi akong time. salamat sa tutulong.
Mga sir may malaking problema ako. A/T yung montero gls ko.
Nagloloko yung transmission niya. Ganito po..
While in "Drive" mode, bigla siya nagiging "Neutral".
Dashboard display: From "D" suddenly nagiging "N".
Autostick/Stickshift: Nakalagay parin sa "D" pero naka Neutral na yung mismong transmission.
This usually happens when I'm driving below 40km/h and when coming to a full stop.
I tried searching the net regarding shifting problems and gear slipping, and saw that it might has to do with transmission fluid or worst, the transmission wearing out.
Nangyari na ba sa inyo to? As much as possible ayoko iderecho sa Casa to, for sure masakit-sakit sa bulsa yun.
Hoping may makatulong sakin.
Thanks!
Newbie here in this forum. A little history on my 2011 glsv. got it at a 2nd hand car dealer at 18tkm last june 2013 without a manual and warranty handbook. Had it pms at 20tkm and 30tkm at casa nearby my area, they recommended replace front brake pads on my next pms. Now at 33tkm the abs warning light on my guage is on. Anyone here shops with obd scanner where i can opt to go for diagnostic? Planning to go out of casa for my coming pms. Inputs will be much appreciated. Tia
Dami ko ntutunan sa forum na to.. Puyatan sa backreading ng mga posts..
I changed my ATF earlier, for maintenance purposes and hoping sana di na mangyari yun.
Will look at that.
Thank you!
Mga bos, anyone here knows how to go about these faults:
[U1102] [Mitsubishi] ASC/TCL/ABS timeout/Not equipped
[P1769] [Mitsubishi] Stop lamp switch
After clearing the faults on Torque it says:
2Gray fault codes might only be clearable by the ECU itself after 'N' fault-free drive cycles have completed
Does this mean i have to use the car for a certian period for the ECU to clear it?? (I havent drove it after clearing the faults though, its my coding day)
Any inputs will be much appreciated, newbie here trying out DIY diagnostics and to turn off the ABS warnjng light on my dash..
Sirs/Mams goodevening.
May alam ba kayong shop aside from casa that sells the mitsu emblem? The one na nasa harapan ng montero.
Ours got stolen 2 days ago. Ginamitan ata ng screwdriver/knife.
If you have extra/accessories, paki PM ako sirs/mams.
Baka magustuhan ko haha.
Thanks!
BTW im selling my old oem fmic ng montero lahat kasama pati pipings. 2013 model yung akin kaya sariwa pa, 12k lang tinatakbo ko. Pm me if interested. Salamat.
Sent from my iPad
Haha akala ko may spammer na! :D
Yung matataas na mileage at walang OCC sigurado maramin oil yang IC nyo kaya kunin nyo na, mura lang yan for sure! ;)
Sir Beng sent you a pm.
Sent from my Nokia 5110 using Tsikot Forums
