Page 173 of 251 FirstFirst ... 73123163169170171172173174175176177183223 ... LastLast
Results 3,441 to 3,460 of 5006
    Aug 2003
    #3441
    just got a 2nd hand late 2010 gls a/t. I noticed that pag naka idle siya at mag rev ako, yung headlight niya lumalakas ang intensity. Could this be a problem with the voltage regulator? The battery is new, 1 month old pa lang. Also, napansin ko na pag paakyat at liliko sa isang kanto, it will shift (upshift ba tawag?) from 2nd to 1st gear, but sometimes the car jerks as if there is a delay during the upshift. Hindi ito normal, di ba?
    Oct 2011
    #3442
    Mga sir kailangan ko lang advice,opinyun niyo.....ang full synthetic oil pinapalitan every 10k, paano kung hindi gaano ginagamit yung sasakyan ilang buwan bago mag pa change oil? Salamat po.
    Jul 2012
    #3443
    JUST WOULD LIKE to confirm:
    is it true na walang stock ang planta ng Mitsubishi ng Montero Sport Non VGT Manual transmission?
    been to most dealers here in NCR, wala daw talaga. just would like to confirm from people who plan to purchase this said variant
    Aug 2007
    #3444
    Sir Prince777, how much po SD extension?
    Feb 2007
    #3445
    Quote Originally Posted by blazeken View Post
    PM sent sir..
    Jan 2008
    #3446
    Thingking of getting this type of TPMS but not sure if compatible.
    Hi just new here, just assume a late 2011 Montero GLS-V, studying all its features, I see that the unit were not installed with TPM sensor, reading through here I found that GLS-V were actually not equipped. Researching for a suitable sensor in the net i found this link.
    http://www.mitsupartsworld.com/Endea...tsb1131001.pdf
    Asking Casa how much a set cost, it is 15K for the whole set. Does anubody also have plan of installing on their GLS-V a TPMS? can i get some info. please.
    Feb 2007
    #3447
    ^ if you can ask the model number of the TPMS sir much better. I would assume that the OEM sensor was supplied by one of the taiwan suppliers, just like the AVT HU.
    Dec 2010
    #3448
    Quote Originally Posted by Archi View Post
    Hindi na po kailangan, sundin nyo na lang po ang 10k.
    Aug 2012
    #3449
    mga sir wala ata stock ngyn glx non vgt. mag 2 weeks na ko mag antay unit ko from citimotors makati.
    Aug 2012
    #3450
    mga sir need your help. newbie here just want to ask what might be the problem and what particular part po montero ito? may oil leak po kasi. and am i in the right thread? thanks in advance
    Aug 2012
    #3451
    #3452
    Quote Originally Posted by mrtn View Post
    hindi po sir makita yung pic, para masilip kung bakit may leak
    Aug 2012
    #3453
    [IMG][/IMG]
    Aug 2012
    #3454
    btw sir zix thanks for the fast response
    #3455
    just replace the hose , okay na yan
    Feb 2010
    #3456
    Hi Guys, For those who are interested to buy a Montero Sport VGT. We are giving additional 40k cash discount for Montero GLS-V 4x2 , 50k additional cash discount for Montero GTV 4x4. for more details, you can contact me at 0922-838-9641. thank you!.
    Aug 2012
    #3457
    sir mukhang hindi po sa hose nanggaling ang leak, pinipisil ko hose pero hindi lumalabas dun oil. I think dito sa ibabaw nang gagaling here's the pic from top [IMG][/IMG]
    #3458
    nangyari din kasi yan sa FM ko before, pinalitan namin yung oil seal nung nasa kinakabitan ng hose, yun pala hindi dun, after mapalitan may leak pa din. pagmainit na pala yung hose tsaka unti unti nagleak. ayun palit hose lang pala
    Aug 2012
    #3459
    sana nga sir sa hose lang if sa hose lang talaga ako na magpapalit before ipasok sa casa by wednesday for 20 kms check up. para bawas gastos will post the result thanks sir zix
    #3460
    clean the area muna before palit ng hose, para makita din talaga kung san galing yung kumakatas na oil
2011 Mitsubishi Montero Sport [continued]
