Page 171 of 251 FirstFirst ... 71121161167168169170171172173174175181221 ... LastLast
Results 3,401 to 3,420 of 5006
    #3401
    Zix, san mo nakuha yung extra 2 oem clamps mo hehe hanap nga ako sa binondo ng hydraulic shops. Ngayon na kailangan ko ng hydraulic shop hindi ko maalala san meron
    #3402
    CB sa surplus shop nung tropa, hanap hanap lang nung ka size, luckily meron naman
    Jun 2011
    #3403
    Quote Originally Posted by zix888 View Post
    normal. install oil catch can to eliminate it
    Sir zix, what is the benefits of installing OCC to the engine?
    Jul 2012
    #3404
    mga sir i just got my unit. 2012 gls-v 4x2. tanong lang po tungkol sa headunit, ung video ko from itouch hindi nya nadidisplay pero may sound. ano po kaya problema nun? d b pwede ung itouch?
    #3405
    Quote Originally Posted by perrydel View Post
    So why does somebody need an Oil Catch Can Tank ? The reason is, that the valve rings do not create a perfect seal. If they did the pistons would not be able to move up and down. Because there is a tiny gap between the cylinders and the pistons, a little bit of pressure is able to escape into the valve cover area. At the same time burnt oils are also escaping into the valve cover area. This is called "blow by". This stuff is nasty and does enter the valve cover area and will escape into the PCV line (red arrow).The PCV line will recycle these burnt oils into the turbo /intake (yellow arrow)which will go into the intercooler. this will start to coat the inside of the intercooler with oil, and reduce the heat exchange efficiencies. Of course, the intercooler works best when the interior surfaces are nice and clean.
    we put OCC to trap these nasty oil, making the whole system pretty clean. yun nga lang you have to drain the can, like in my case, once every 12000kms kasi compact lang yung size ng OCC ko eh
    Aug 2006
    #3406
    1) download and extract this file on your pc, Free large file hosting. Send big files the easy way!
    2) remove the head unit cover, here is how,
    Montero sport gtv - YouTube
    3) remove the the sd card ( upper left portion of the lcd monitor )
    4) copy/paste all the files you downloaded into sd card, replace all. Insert the sd card back, and assemble the head unit cover back and you are updated.
    Bossing, puwedeng pa-post uli ng files for the SDCard? expired na raw sa sendspace yung URL eh
    Salamat po
    Sep 2011
    #3407
    Quote Originally Posted by SRGuy View Post
    Mukhang important nga yan OCC, bakit kaya di pa sinama yan sa stock engine?
    Gusto ko din magkabit pero baka after ng warrantly period na lang. Or kung madali lang, baklas muna bago pumunta ng casa :D
    Maraming sabi sabi at kuro kuro sa internet kng bakit walang OCC ang mga engines natin, ang most accepted ay
    kung yung nga mag change ng mga filters eh nakakalimutan o di nagagawa lalo na daw siguro magdrain ng OCC. I dont know if the risk > benefits kng nakalimutan idrain OCC vs. walang OCC.
    BTW if i remember it right may mga previous car models na may OCC, kalimutan ko lng kng sino.
    May 2011
    #3408
    Heads up again guys, Map update 2.2 is now available for your downloading pleasure.
    *macstar, updates are now available at iNav website New Updates
    Quote Originally Posted by macstar1 View Post
    Salamat po
    #3409
    i thought yung speed sensitive variable intermitent wiper eh sa fastest setting lang ng INT, meron pa rin pala sa next setting of INT, engaging naman when reaching 100kph
    Nov 2011
    #3410
    Mga boss tanong lang kung saan makakabili ng murang accessories. Yung gtv cf spoiler at rear bumper garnish (silver)? o mas maganda pag paint?
    Aug 2006
    #3411
    Quote Originally Posted by jayteecie View Post
    Boss, 2012 Non VGT AT yung MS ko eh. Wala yata siyang kasama na SDCard.Sapat na kaya na i-copy ko lang yung 2 folders from downloaded compressed file, into a newly (FAT) formatted SDCard?
    Mar 2012
    #3412
    I own a 2011 gls-v MS and I am just a recent follower of this forum.
    I find this particular thread highly-interesting & informative & my kudos to the very knowledgeable, resourceful & helpful active members to the forum.
    This is the first time I own a turbo-diesel run engine - in fact, the first time I drive a turbo-powered vehicle.
    I realize our engines have certain peculiarities particularly as to it being powered by a turbine.
    I am not sure if my question has been tackled already in past threads but may I inquire on the use and the necessity of an auto turbo timer?
    Is it a necessary equipment?
    If not, do we need to idle the engine for so many minutes prior to turning it off after a long trip?
    Thank you.
    Jun 2012
    #3413
    Quote Originally Posted by green eagle View Post
    Thank you.
    yes you need to wait for a couple of mins before turning off the engine. if this will give much inconvenience for you, then turbo timer will give a big help
    #3414
    Thank you.
    this will be your basis, if you live and drive around the metro, no need for turbo timer. if you drive by nlex/slex often, you have to put one. thats what my fully automatic turbo timer logged.
    #3415
    winterpine inav said they are uploading the 2.2 update, and will be ready for download later today
    Mar 2012
    #3416
    Quote Originally Posted by clairenceh View Post
    The original of the gtv rear spoiler is supplied and retailed by Winterpine. I don't think it's made of cf - it's merely wrapped in decal with cf design. It's good enough for me.
    Not sure if they retail the rear bumper garnish as well.
    #3417
    just updated my map to 2.2.
    May 2012
    #3418
    Wala naman issues yung maps niyo? Haay, sa Non VGT kahit ginamit na namin yung file may issues pa rin yung maps. Anong file kaya yung kulang para magdisplay nang maayos ang maps?
    Jul 2012
    #3419
    Sent you PM sir..
    bro pm me the price of SD extension also or text me it to me. 09178154682.
    thanks,
    Aug 2006
    #3420
    Sent you PM sir..
    Chief, pa PM naman ng price ng SDCard Extension...
    Saka magkano aabutin kung samahan ko na rin ng pakopya ng iNav SDCard at pakabit ng SDCard Extension? Panday sira ako eh ...
2011 Mitsubishi Montero Sport [continued]
