Page 143 of 251 FirstFirst ... 4393133139140141142143144145146147153193243 ... LastLast
Results 2,841 to 2,860 of 5006
    Jul 2004
    #2841
    Quote Originally Posted by zix888 View Post
    Goodbye battery!!! ( on my steering wheel audio remote )
    montero sport gtv 2011 - YouTube
    ito din ang gusto kong DIY
    #2842
    Pa suspense pa sir Zix ha!
    Share naman the DIY!
    Thanks..;)
    Sir madali lang yung diy nung sa battery, LM-317T and resistor to get a 3V output. Ang problema lang sir na nakikita ko for 2011s is yung kinuhanan ko ng supply ay galing sa harness nung cruise control ko. Kelangan palit pa kayo ng clockspring just to get power supply.
    Jan 2012
    #2843
    Quote Originally Posted by Edgar Ranara View Post
    gud evening sir ask ko lang sana kung bakit ayaw mag function ng remote control ko sa steering wheel para sa car stereo... bago po naman yong battery but still not working.. can you please help me on this matter.. many thanks po.. my montero sport is glxv 2011 model.. thanks
    hellow sir.. you need to reset the remote control steering para gumana siya ulit... try mo hold ung + and - na sign sa steering wheel den dapat naka off ung car.... then hold mo siya + - and negative den try mo paandarin ung engine then may maririnig ka na tunog na toot .. nagrestart na un.. then try mo kung gumagana na siya ulit. pag hindi pa.. restart m ulit until it works....
    Sep 2011
    #2844
    Sirs, goodmorning po.
    Ask ko lang, paano po inaadjust ang valve clearance ng Montero Sport?
    Conventional type ba siya na we need to open it up and tighten it using screws/wrench?
    Thanks.
    Feb 2007
    #2845
    Thinking of getting the 12V supply to the ignition.
    Found this cuircuit, will check kung pwede..
    #2846
    The problem bro, from the ignition going to the steering wheel , without the connection thru the clock spring, the wire will get twisted as you turn the wheel
    Feb 2007
    #2847
    There should be a power source on top of the clock spring, am thinking of the horn switch. Ito siguro pwede pero kailangan yung circuit is small enough to be hidden behind the cover..
    #2848
    Option mo lang bro is the airbag line, hindi ko kasi ginalaw yung line na yan baka mag srs warning eh. I already checked the horn, grounding lang lang siya, walang supply
    Apr 2011
    #2849
    Sir zix888 may cruise control ba 2011 gtv o pinakabitan nyo po? If yes, san po pwede magpapalit?
    #2850
    Quote Originally Posted by dohcvtec View Post
    Wala po cruise control yung 2011 gtv, diy ko lang. , bought the parts online. hindi pa kasi alam ng casa and winterpine how to install and make it work kaya no choice. Had to do some connections sa ecu to some connectors . yun yung critical sa diy ng cruise control
    Apr 2011
    #2851
    Grabe ang talent nyo sir. Kelan kaya pwede magpakabit sa kanila sir? Pano warranty nyo sir?
    #2852
    Have to check muna sir if your monty is compatible. Any wiring naman na done out of casa, (kung casa ang tatanungin) sigurado void ang warranty. Will post some vids on how it works on 2011gtv, tamang tama may long drive na naka schedule.
    Jan 2011
    #2853
    bro, got my parts yesterday for my Cruise and Paddle DIY. got it from my contact, really good price. just need some spare time to finally complete these DIYs. did you use a puller ba to remove yung steering wheel? Will do these along with the corner sensor and ASTC switches but pang ibang functions ko na lang gagamitin itong mga ito. Yung corner for the rear camera activation na lang even when at 'D' tapos yung ASTC, reserve ko na lang muna for the WA after the warranty expires...will post pics tomorrow...
    #2854
    Quote Originally Posted by tuazon7 View Post
    Pm me sa pricing bro. Ganyan din yung current diy ko, always sonar off illuminated, then pagreverse, tsaka mawala yung illumination. Yung astc, 2 lamps yun, red astc symbol and amber astc symbol with the "off" sign, bahala ka na mag assign kung san mo type. Mine is also waiting pa kung san ko isasabay if hindi matuloy yung astc diy ko. Were you able to do your seatbelt lamp, may kasama kasi tayo na naka glsv, hindi niya mapa illuminate eh
    Jan 2011
    #2855
    yun seatbelt hindi pa din, baka sabay ko na lang sa Holy Week Holidays...yun sa combination meter indicators, oo nga bro dami walang naka-abang na lamp, last DIY ko na lang yun sa meter, unahin ko na muna mga switches, buti na lang yung cruise control meron ready...
    Bro, yung inalis mo yung steering wheel mo, gumamit ka ba ng puller pa? TIA. sa procing bro, PM na lang kita...
    Jan 2011
    #2856
    sharing my 'new' keyfob...
    Jan 2011
    #2857
    sharing the corner sensor switch installation...
    Jan 2011
    #2858
    Thanks bro
    after installing the cabin filter...
    #2859
    Baka may extra ka niyan, type ko yan, ala lang ako makunan eh. No need for steering wheel puller bro, madali lang bunutin
    #2860
    Neat bro. Maybe by the end of the month i will get my cabin filter and occ, excited na, nangagati na kamay ko , hehe. Nakita mo pala yung slight rusting, baka magtuloy bro, agapan mo na
2011 Mitsubishi Montero Sport [continued]
