Page 93 of 124 FirstFirst ... 4383899091929394959697103 ... LastLast
Results 1,841 to 1,860 of 5006
    Nov 2006
    maraming factors bro brrooommm kaya naging mausok. una, talagang mausok ang montero, di ka nagiisa check mo sa casa mo kung may in-adjust sa ECU mo regarding fuel delivery. pwede rin due sa fuel, baka nagpalit ka ng dating ginagamit mo. baka madumi na rin ang EGR mo, di kasi yan lilinisin ng casa unless i request mo. may proven solution para mawala ang usok, blanking or blocking the EGR, basa ka na lang sa mga posts dito sa montero threads about blanking...
    Sir Monty_GTV salamat sa tip at dalhin ko muna sa casa today tong unit ko and back read muna ako dito sa forum para mag karoon ako ng kaalaman sa montero natin..........at magandang umaga sa lahat ng tsikoters
    Sep 2005
    well...after 8k kms on blank EGR, nag check engine light monty ko....what do you think guys seems to be the problem? no limp mode btw...
    Apr 2012
    Quote Originally Posted by ali_diego View Post
    check your fuel filter...
    Sep 2005
    nangyari din sayo yan sir...kelangan paba pa reset? thanks...
    Sep 2010
    yes sir kung fuel filter nga kailangan i pa reset.
    Sep 2005
    Quote Originally Posted by iceman777 View Post
    sa casa lang ba pwede pa reset ito sir? thanks..
    Apr 2012
    yes sir, nag CEL din nung 23k odo yung unit ko, pinalitan lang yung fuel filter filament kasi madumi na
    wala naman kailangan i-reset sir, saka ano ba yung dapat i-reset???
    Feb 2007
    ^ baka yung fault code na gusto ma erase sa ECU.. ;)
    Sep 2005
    reset...i mean para matanggal yung CEL sir....sorry kung mali mali yung ginagamit ko na term..hehehe...
    mawawala din ba CEL after mapalitan ng bagong fuel filter? thanks...
    pm me your mobile. para we can check what actually caused the CEL
    Apr 2012
    Sir Prince777, where do you bring your keys para magfit in keyfobs? Any shop recommedations?
    Sir Ali/Zix, please keep us posted on the CEL issue and its cause para maiwasan nun iba. Thanks.
    Sent from my SM-N9005 using Tsikot Forums Mobile App mobile app
    Sep 2005
    GUys, we have a shock absorber that can improve the ride of your montero. to lessen the "tagtag" of your vehicle.
    its from the same factory of ironman Australia. send me pm po for inquiries
    God bless
    09228238823
    Feb 2007
    Quote Originally Posted by wing211 View Post
    Most I've known are DIY's. Others brought them to suking keymaker. Have not made your keyfob yet sir?
    Sent from my iPad using Tsikot Car Forums
    Sep 2005
    PROBLEM SOLVED guys... removed negative terminal sa battery...clean MAF sensor...while drying up my MAF sensor, i change the fuel filter...then kabit ulit MAF sensor then kabit ang battery then paandar monty...then Boom! wala na CEL... diko pa sana schedule magpalit ng fuel filter and clean MAF sensor..anyway...lucky me....
    Apr 2012
    anong fuel filter ng montero mo sir, yun bang detachable type or yung may filter casing na at filter filament na lang ang pinapalitan? mabuti naman at na-solb agad problema mo. mga consumables gaya ng fuel filter ay kahit wala pa sa schedule kung talagang madumi na ay kailangan na palitan.
    Sep 2010
    Ayus sir buti na ayus nyo na, yung sa model namin kase kailangan pa i pa reset. 2012 model pala sakin.
    Feb 2013
    mga sir baka alam nyo yung dimension ng blanking plate
    pati na yung laki ng butas paki send naman. tnx
    Apr 2012
    Quote Originally Posted by ricciboy View Post
    much better siguro sir tanggalin mo yung metal gasket sa may egr pipe then yun mismo ang gawin mong pattern para eksakto. pero kung kagaya kitang nasa overseas at balak mong gumawa, pwede na yung drawing w/ dimensions kung may makapagbigay dito. umeksakto lang center to center at diameter ng butas saka tama ang lapad at ma-cover buong butas ng egr pipe ok na. saka na tabasin yung excess para di halata may blanking...
    Jan 2010
    sir ricci, please check this....
    Feb 2013
    Quote Originally Posted by rmsoriano View Post
    sir maraming salamat sa drawing , ngayon kasi ang magandang panahon para gawin ang plate dahil kumpleto gamit dito para pag uwi ko salpak nalang
2011 Mitsubishi Montero Sport [continued]
