Page 194 of 250 FirstFirst ... 94144184190191192193194195196197198204244 ... LastLast
Results 3,861 to 3,880 of 5000
    Sep 2004
    #3861
    Quote Originally Posted by RF02 View Post
    thanks sir walter try ko po yan bukas :D
    *ctrlaltdel
    wala pong tweeter yun model ng strada natin eh.. kung mapapansin mo sa brochure 4 speakers lang dalawa sa harap dalawa sa likod...
    uu mabilis talaga lalo na sa 2k rpm pataas.
    hehe kaya pala. abang lang pala yung space doon. here's my new ride:
    Aug 2003
    #3862
    I just sent in my ride for 45k pms. Nireklamo ko rin na minsan may choke sa low rpm of 1k, tapos over 2k rpm yung makina parang pasulpot sulpot ang tunog, yung parang may surge, pero the rpm is steady. Anak ng ewan, the findings was kelangan palitan ng valve kit ang scv. 15k plus pa man din ang hayop na yan na napakaliit. Plus 1600 labor. And gusto pa nila palitan ang fuel filter. I told them kakapalit pa lang nila sa fuel filter. When they checked the filter, malinis, so hindi na pinalitan. I noticed the low rpm choking since last year, akala ko kasi kulang lang sa apak dahil it happens at 1k rpm. Mitsu gave me 10% discount, di daw siya kasama sa rainy day promo nila.
    My warranty lapsed just this april. Hanep talaga. Overall, mas mataas ang maintenance cost ng strada ko kaysa sa hilux ng kamag anak ko bought 1 month apart with similar odometer readings.
    Mar 2012
    #3863
    Quote Originally Posted by altec View Post
    did they also check tha fuel tank if may contamination(water)? I had the same problem before. yun pala contaminated nang water yung last fuel sation ko na pinag-kinargahan.
    Jun 2009
    #3864
    magpa-2nd opinion ka muna Sir...ano gamit mong fuel? sa akin 80k kms(3yrs) no choking,scv issues.palit fuel filter every 25/30k.shell v-power fuel ko. kung malapit ka sa el-dorado cubao,hanapin mo si jay...sya naglinis ng egr ko.hinde ako pumuntang casa.
    Jun 2013
    #3865
    Quote Originally Posted by CtrlAltDel View Post
    Congratz, sir! Palit na agad ng gulong para mas pogi!
    Jul 2013
    #3866
    Sir at 45km reading, napalinisan mo na intake manifold? Kasi ganyan din sa akin, palit scv wala pinagbago thenni decided to clean my egr pipe, intake manifold myself. Then nagblank na ako egr.. ngayon ok na,,
    #3867
    Mga sir ask lang po Feb. 2012 ang strada glx namin pero last time sa labas na namin pina change oil meaning wala na kami warranty..
    Nagka problema kasi wiper namin yung pinaka high speed switch lang ang gumagana yung sa may timer at normal speed ayaw gumana ng wiper
    tapos pag ginamit ko yung high speed na wiper at saka ko off yung wiper bigla hinto din yung wiper kung san gawi ako nag off ng wiper switch kaya
    tantsahan pa pag off ng wiper para lang huminto sya sa normal standy positiion nya.2nd question kasabay nya nagloko yung headlight ang problema
    naman pag naka dim at bright ako mahina ilaw sa left side pero nakikita ko naka ilaw naman left headlight yun nga lang sobrang hina.. 3rd question po
    yung sa panel natin pag naka on yung ilaw medyo naka ilaw yung bright indicator sa panel pero konti lang.. Ano po kaya problema? Makikita kaya
    problema sa computer diagnostic ng mitsubishi? thanks po Oliver of Bulacan
    Jul 2013
    #3868
    Quote Originally Posted by Linoleic View Post
    sir question po,
    yun stock mags po ba namin na ganyan pwedeng lagyan ng 265/75/16?
    ayaw ko pa kasi sana palitan yun mags yun goma lang sana uunahin ko para maging masculine tignan si strada :D
    Jul 2013
    #3869
    Quote Originally Posted by kingtooth View Post
    Opo sir dalhin na dun asap.. claim ka warranty kasi wala kinalaman yung change oil mo sa electricals mo.
    Apr 2010
    #3870
    *kingtooth
    question 2&3 might be related. first thing to check is your HL bulb. subakan mo i reseat. o kaya pagpalitin left & right.. kung bulb problema, wear & tear yan. w/ regards to warranty, yong mga items na nag fail kasi nde nila na check supposedly sa PMS baka mahirapan ka i claim. pero yong iba, ma claim mo pa rin. like yong wiper, dapat ma claim mo yon.
    Apr 2010
    #3871
    *altec
    I agree with Ian, first and less costly thing to do first is clean your egr and intake manifold. at your km run, due fir cleaning na rin talaga yan.then clean your MAF sensor *AND* connector. Let us know what will happen.
    egr blank and occ are good stuffs too. but not directly related to your issue. though it can avoid similar in the future. i got blank pala if your interested. hehehe.
    Jul 2013
    #3872
    mga sir saan po bang shop pwedeng magpa-blank?
    hindi ko kasi kaya i-diy eh
    Jul 2013
    #3873
    May mga katsikoteers po tayo nagbablank.. get 1 from them and paguide ka na lang pano ilagay kung malayo ka sa locations nila. Kung slot type yung blank plate nila, like what i did, 2 nuts lang yang luluwagan then slot mo na lang.. malaking bagay naka blank ka para maiwasan yung soot build up sa egr pipe at manifold.
    Aug 2003
    #3874
    Ano yung nagblank sa egr? Tinanggal?
    #3875
    Quote Originally Posted by dj ian View Post
    diba mga sir basta lumagpas kana ng PMS nila lalot ibang langis at filter na nagamit sira na warranty mapa engine o electricals man?
    Quote Originally Posted by ezrydre View Post
    *kingtooth
    Sige sir try ko ulit baklasin headlight bulb kung bulb na nga sira.. Try ko kasi nuon kaso gabi ko sinubukan hanggang sa tinamad nako ituloy
    kasi nahirapan ako dukutin bulb sa right side hindi tulad sa left side maluwag yung area na yun. Sir ano pala yung reseat? reconnect ng bulb socket ba yun? feeling ko kung hindi may shorted baka sira na yung wiper switch ko at bulb.. Pero diba ang bulb pwede naman di sabay mapundi ang low at high beam nya? sorry dami ko mga tanong..
    Apr 2010
    #3876
    sir, reseat, tanggal tas balik ulit. hehehe.
    if you have other electrical addons try to check the grounding.
    Apr 2010
    #3877
    egr blank on strada/montero ay sasaraduhan lang yong tubo na dinadaanan ng usok na papuntang intake. egr delete yong tinatanggal na yong egr assembly. la pa ko alam gumawa nyan sa strada/montero. me mga sensors kasi na apektado. sa D4D ng toyota me nag de-delete ata. me available pa kong stainless steel 1.5mm blank plate. sa interesado pm na lang.
    Jul 2013
    #3878
    sir question po,
    up lang po mga sir :D
    Jun 2013
    #3879
    ^^^Di ko lang sure boss.. Pero before parang may nabasa ako na nag palit ng gulong tapos yung stock rims pa rin gamit nya nya.. Inquire na lang kayo sir sa mga tire shop para sigurado...
    Guys, advisable ba na iblank agad ang egr kahit bago pa ung sasakyan? sigurado void agad yung warranty nun right? If ever mag light yung check engine, mawawala ba yun pag tinanggal yung pangblank?
    Mar 2012
    #3880
    judging from the size of tire na ikakabit mo i guess na 16" din yung stock mo. If i'm not mistaken yung rim mo is 16x6. yung minimum safe width sa tire size na gusto mo is 7 ata so parang di pwede yung size na gusto mo sa stock 16"rim.
    I posted the same question sa tscp fb page. The guys(mga naka blank na) told me na if possible wag muna and sagarin na muna ang warranty. Dahil i'm sure dami na namang issue ang casa nyan if they found out the blanking plate. But if your not worried about warranty issues then its your call.
2010 Mitsubishi Strada [continued 2]
