Results 3,871 to 3,880 of 5002
- Jul 2013
- 193
September 14th, 2013 12:37 PM #3871
- Apr 2010
- 131
September 14th, 2013 12:41 PM #3872*kingtooth
question 2&3 might be related. first thing to check is your HL bulb. subakan mo i reseat. o kaya pagpalitin left & right.. kung bulb problema, wear & tear yan. w/ regards to warranty, yong mga items na nag fail kasi nde nila na check supposedly sa PMS baka mahirapan ka i claim. pero yong iba, ma claim mo pa rin. like yong wiper, dapat ma claim mo yon.
- Apr 2010
- 131
September 14th, 2013 12:46 PM #3873*altec
I agree with Ian, first and less costly thing to do first is clean your egr and intake manifold. at your km run, due fir cleaning na rin talaga yan.then clean your MAF sensor *AND* connector. Let us know what will happen.
egr blank and occ are good stuffs too. but not directly related to your issue. though it can avoid similar in the future. i got blank pala if your interested. hehehe.
September 14th, 2013 12:57 PM #3874
mga sir saan po bang shop pwedeng magpa-blank?
hindi ko kasi kaya i-diy eh
- Jul 2013
- 193
September 14th, 2013 01:07 PM #3875May mga katsikoteers po tayo nagbablank.. get 1 from them and paguide ka na lang pano ilagay kung malayo ka sa locations nila. Kung slot type yung blank plate nila, like what i did, 2 nuts lang yang luluwagan then slot mo na lang.. malaking bagay naka blank ka para maiwasan yung soot build up sa egr pipe at manifold.
Tsikot Member Rank 3
- Aug 2003
- 1,251
September 14th, 2013 03:03 PM #3877
diba mga sir basta lumagpas kana ng PMS nila lalot ibang langis at filter na nagamit sira na warranty mapa engine o electricals man?
Sige sir try ko ulit baklasin headlight bulb kung bulb na nga sira.. Try ko kasi nuon kaso gabi ko sinubukan hanggang sa tinamad nako ituloy
kasi nahirapan ako dukutin bulb sa right side hindi tulad sa left side maluwag yung area na yun. Sir ano pala yung reseat? reconnect ng bulb socket ba yun? feeling ko kung hindi may shorted baka sira na yung wiper switch ko at bulb.. Pero diba ang bulb pwede naman di sabay mapundi ang low at high beam nya? sorry dami ko mga tanong..
- Apr 2010
- 131
September 14th, 2013 09:46 PM #3878sir, reseat, tanggal tas balik ulit. hehehe.
if you have other electrical addons try to check the grounding.
- Apr 2010
- 131
September 14th, 2013 09:54 PM #3879egr blank on strada/montero ay sasaraduhan lang yong tubo na dinadaanan ng usok na papuntang intake. egr delete yong tinatanggal na yong egr assembly. la pa ko alam gumawa nyan sa strada/montero. me mga sensors kasi na apektado. sa D4D ng toyota me nag de-delete ata. me available pa kong stainless steel 1.5mm blank plate. sa interesado pm na lang.
high idle RPM at engine start
