Page 192 of 250 FirstFirst ... 92142182188189190191192193194195196202242 ... LastLast
Results 3,821 to 3,840 of 5000
    Jan 2011
    #3821
    Quote Originally Posted by RTS View Post
    If you are near Visayas Ave. S4 Hub auto shop doon ko pinalagay yung sa akin na Oil Catch ,also a member of Strada Club.
    Yes Boss, punta ako dun next week..Sana madali lang ikabit ang Oil Catch Can
    Ganun po ba ka importante ito sa Strada natin?
    #3822
    Quote Originally Posted by soyti75 View Post
    this is trapped on my occ , 4000kms travelled.
    btw i have a bolt on type (custom made bracket) occ for strada and monty. quick release type for PMS. 5 mins install/uninstall
    Apr 2010
    #3823
    Sharing.... EGR cleaning + blank * 17.2K km DiD 2.5 non-VGT
    just like not there.
    and I got some more... 1.5mm stainless steel plate
    #3824
    Quote Originally Posted by ezrydre View Post
    Are you willing to sell the extra plates sir?
    #3825
    plus 1.
    btw eto effect niyan on 2.5 nonvgt
    egr blanking on monty 2.5 nonVgt - YouTube
    eto naman on 2.5 vgt
    montero sport gtv egr blanking - YouTube
    Apr 2010
    #3826
    *nivraarvin
    PM sent...
    Jul 2013
    #3827
    mga sir, twing ilang km po ba need gawin yun egr blanking?
    Mar 2012
    #3828
    Quote Originally Posted by RF02 View Post
    isang beses ka lang mg blank na egr sir. unless you plan to remove it again for some other reasons and install na naman uli.
    Apr 2010
    #3829
    If you can blank right after you left casa the better. However, take note that this procedure will void your warranty. Also, for some, this gives check engine light, and *may* cause limp mode. Hence, better make an internal arrangement with your SA not to put on book this mod. Slotted blank is best for easy install and removal. OBD2 tool at hand is a great help.
    HTH.
    good morning tsikoters.
    Sent from my S3 using Tapatalk 2
    Aug 2009
    #3830
    Mga sir tanong ko lang nawawala ba ang wheel alignment pag nalubak ka ng medyo malalim or na humps ka? ako kasi na humps ng mga 40-50kph with 3 passengers aspaltado kasi and kakulay ng kalsada at umuulan pa kaya diko napansin and after that parang napansin kong nagiba pakiramdam ko sa manibela & the next day medyo may kabig na sya sa left or is it dahil nagpapalit ako ng 20" rims with 265/50/20 tires? sa mga nagpalit na dyan ng 20" rims nagpa wheel alignment ba kayo after or wala namang nagbago sa handling ng rig nyo? thanks mga sir..
    Aug 2009
    #3831
    mga sir isa pang tanong, pagba nagpa camber eh may mavovoid na warranty? nung nagpacamber kasi ako dati ng kotse may inacetylene at kinikil sa may pinagkakabitan ng turnilyo kumbaga pinalaki yung butas.
    Mar 2012
    #3832
    Quote Originally Posted by lakers24 View Post
    dapat pag palit mo nang bigger tires and rims w/ lift nag pa camber/toe alginment kana kaagad. yan usually ang ginagawa after changing into a different size of tires and a lift. about sa lubak nman, i dont think na masisra na ang suspesion just by a few lubak lang. i tried to run 80-90kph on 4H sa light to meduim unpaved road but ok naman and wlang naging probema sa wheels ko. just bring your rig to a trusted casa for wheel balancing and alignment.
    Mar 2004
    #3833
    Please recommend where we can buy EGR blanking plates and Oil Catch Can. Thank you.
    Aug 2009
    #3834
    Quote Originally Posted by D3nb3r View Post
    thanks sir, actually hindi naman po ako nagpa lift, change rims & tires lang and ung humps na nadali ko medyo mataas at medyo mabilis din ako nun. Galing ako Master Fix sa evangelista (recommended kasi sa ford ranger forum na ok daw sa bigger tires sa pick up) and ang camber result
    -1 sa left & +9 sa right kya need daw i camber kasi lagpas sa +5 tolerance kaso mahahalata daw sa casa pag nacamber na & baka warranty issue
    kaya hindi ko muna pinagawa observe ko nalang daw muna pero sa wheel align ok naman ang result within tolerance daw. btw 500 lang wheel align sa kanila & 2.5k camber w/ wheel align pero sa iba 1.2k wheel align at 1.8k camber pero patingnan ko din muna sa mega motion sa banawe
    baka dun naman wheel align lang lumabas hindi ok hehe .
    Jul 2013
    #3835
    Sarap ihataw si strada na naka egr blanking ano mga sir? Pero paano sa emission testing, kahit di na kaya alisin yung blangking plates, ok lang? Kasi pansin ko lang parang tumapang yung amoy ng exhaust gas mula nagblank ako. Lalo na sa cold starts..
    Apr 2010
    #3836
    Just renewed my registration last month.
    Emission test with EGR blank is 1.12. 2.2 max required ng LTO. That's on Petron Diesel Max. No 2T.
    #3837
    recently upgrade my rim and tires
    ROH 16"
    Cooper ST Maxx 265/75/16
    Mounted
    Jun 2013
    #3838
    Walang sayad to Sir? Naka-lift po ba?
    Quote Originally Posted by killer_eyes View Post
    #3839
    Quote Originally Posted by fourstring View Post
    sir di ko pa masyado nasusubukan eh...
    sa u turn sa edsa walang sayad, pero sa parking namin sa bahay paabante walang sayad, pag paatras na pababa pag liko meron sa mud guard.
    di pa sya lifted, naka sked pa lang ipalift baka next week or in two weeks time, inaantay pa yung lift kit
    Jun 2013
    #3840
    Saan ka magpapalift, sir? Magkano aabutin kasama lift kit? Plano ko din sana magpalift para makapagpalit ng bigger tire.. TIA
2010 Mitsubishi Strada [continued 2]
