Page 384 of 501 FirstFirst ... 284334374380381382383384385386387388394434484 ... LastLast
Results 3,831 to 3,840 of 5002
    Apr 2010
    #3831
    If you can blank right after you left casa the better. However, take note that this procedure will void your warranty. Also, for some, this gives check engine light, and *may* cause limp mode. Hence, better make an internal arrangement with your SA not to put on book this mod. Slotted blank is best for easy install and removal. OBD2 tool at hand is a great help.
    HTH.
    good morning tsikoters.
    Sent from my S3 using Tapatalk 2
    Aug 2009
    #3832
    Mga sir tanong ko lang nawawala ba ang wheel alignment pag nalubak ka ng medyo malalim or na humps ka? ako kasi na humps ng mga 40-50kph with 3 passengers aspaltado kasi and kakulay ng kalsada at umuulan pa kaya diko napansin and after that parang napansin kong nagiba pakiramdam ko sa manibela & the next day medyo may kabig na sya sa left or is it dahil nagpapalit ako ng 20" rims with 265/50/20 tires? sa mga nagpalit na dyan ng 20" rims nagpa wheel alignment ba kayo after or wala namang nagbago sa handling ng rig nyo? thanks mga sir..
    Aug 2009
    #3833
    mga sir isa pang tanong, pagba nagpa camber eh may mavovoid na warranty? nung nagpacamber kasi ako dati ng kotse may inacetylene at kinikil sa may pinagkakabitan ng turnilyo kumbaga pinalaki yung butas.
    Mar 2012
    #3834
    Quote Originally Posted by lakers24 View Post
    dapat pag palit mo nang bigger tires and rims w/ lift nag pa camber/toe alginment kana kaagad. yan usually ang ginagawa after changing into a different size of tires and a lift. about sa lubak nman, i dont think na masisra na ang suspesion just by a few lubak lang. i tried to run 80-90kph on 4H sa light to meduim unpaved road but ok naman and wlang naging probema sa wheels ko. just bring your rig to a trusted casa for wheel balancing and alignment.
    Mar 2004
    #3835
    Please recommend where we can buy EGR blanking plates and Oil Catch Can. Thank you.
    Aug 2009
    #3836
    Quote Originally Posted by D3nb3r View Post
    thanks sir, actually hindi naman po ako nagpa lift, change rims & tires lang and ung humps na nadali ko medyo mataas at medyo mabilis din ako nun. Galing ako Master Fix sa evangelista (recommended kasi sa ford ranger forum na ok daw sa bigger tires sa pick up) and ang camber result
    -1 sa left & +9 sa right kya need daw i camber kasi lagpas sa +5 tolerance kaso mahahalata daw sa casa pag nacamber na & baka warranty issue
    kaya hindi ko muna pinagawa observe ko nalang daw muna pero sa wheel align ok naman ang result within tolerance daw. btw 500 lang wheel align sa kanila & 2.5k camber w/ wheel align pero sa iba 1.2k wheel align at 1.8k camber pero patingnan ko din muna sa mega motion sa banawe
    baka dun naman wheel align lang lumabas hindi ok hehe .
    Jul 2013
    #3837
    Sarap ihataw si strada na naka egr blanking ano mga sir? Pero paano sa emission testing, kahit di na kaya alisin yung blangking plates, ok lang? Kasi pansin ko lang parang tumapang yung amoy ng exhaust gas mula nagblank ako. Lalo na sa cold starts..
    Apr 2010
    #3838
    Just renewed my registration last month.
    Emission test with EGR blank is 1.12. 2.2 max required ng LTO. That's on Petron Diesel Max. No 2T.
    #3839
    recently upgrade my rim and tires
    ROH 16"
    Cooper ST Maxx 265/75/16
    Mounted
    Jun 2013
    #3840
    Walang sayad to Sir? Naka-lift po ba?
    Quote Originally Posted by killer_eyes View Post
2010 Mitsubishi Strada [continued 2]
